Old 03-17-2018, 04:01 PM   #1
waninae39's Avatar
2017 22' Sport
NCR , Ontario
Type of solar connector on the As roof
What is the type of connector for the 3 port on the top of AS 22FB
i think that only one port has wires.
there were no connectors when we bought the 2017 as 22FB
is the top connector one of these
if what type
are they female or male
Name:	types of slar connectors.JPG
waninae39 is offline   Reply With Quote
Old 03-17-2018, 05:04 PM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Usually the two wires are stubbed off near a skylight or fan under the skin. Hopefully the factory splurged and put tape over the ends of the wire......
Old 03-17-2018, 05:26 PM   #3
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
if what type
They are SAE connectors, the same Zamp connectors as near the battery box. The roof box is a combiner box where you can plug in three panels and the are combined to one wire to the interior of the trailer.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 03-17-2018, 08:39 PM   #4
waninae39's Avatar
2017 22' Sport
NCR , Ontario
thank you
why cant AS show these in their user manual
also, are the std and heavy duty the same and fit together, they look no different
Old 03-17-2018, 08:51 PM   #5
thank you
It sure of differences. You might be able to fine them at Canadian Tire.
Ray B.
Old 03-18-2018, 12:05 PM   #6
bigfoot390's Avatar
1999 30' Excella 1000
Chatham , Virginia
There were just 2 wires taped off on my 1999 excella. Easy to just look and see.
bigfoot390 is offline   Reply With Quote
Old 03-18-2018, 07:18 PM   #7
2014 25' FB Flying Cloud
Fitchburg , Wisconsin
I don't think you need connectors.
I bought factory solar on our 2014 FC25FB. They daisy-chained the panels using a box on the bottom of the panels to weather proof the wire nuts to make the connections and to connect to the lead-in wire. It was all 10 AWG. The roof entry was an L-shaped tubular connector with a lot of calk that was installed before the interior skin when on--it had a nut on the inside. This is all past tense because I recently replaced the whole thing with two 100 watt panels and 4 AWG cable from the roof to the new controller. The new roof entry is a combiner box from amsolar.com. They have some useful videos about how to use their products.
I didn't use any connectors on the new installation either.
If you think you may be changing the panels then connectors may be worthwhile but the combiner box makes that the screwdriver job.
BillfromWI is offline   Reply With Quote
Old 03-19-2018, 07:14 AM   #8
ateric1's Avatar
2017 16' Sport
Miller , Missouri
On my sport 16 they are all connected. I just put 150 watts of panels on the roof and used two of the connections. They are SAE connectors. A simple MC4 to SAE connector is all you need. My question to those that have used the SAE connectors is, do they stay plugged in? They are VERY easy to unplug. I was hoping that they snap in but that's not the case. I was thinking about running a small bungy cord around the combiner box and through the connectors to hold them in place.
Eric
ateric1 is offline   Reply With Quote
Old 03-21-2018, 10:14 PM   #9
waninae39's Avatar
2017 22' Sport
NCR , Ontario
i found these on amazon
ten of MC4 f/m pair with pins ready to be wired for $14
waiting for spring to install my new 160W solar, solar converter and new li-ion BB battery
Name:	ten MC4 connectors.JPG
Old 05-19-2018, 07:27 AM   #10
bigfoot390's Avatar
Chatham , Virginia
Electrical tape. 1999 31í Excella.
Old 05-19-2018, 08:36 AM   #11
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
It is best if you purchase a heavy duty size 10 AWG SAE connector to use with solar connections. Many SAE connectors have very thin wire that you would not want to use with solar. I used one of these from Amazon: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 cut it in half to make two connections to my Zamp rooftop box. The positive wire used the rubber squared edge side on the SAE connector and the negative used the bare round side on the SAE connector. The solar wiring schematic in my owners manual showed the Zamp box with positive and negative indicated as I described them. On my 2017 FC25FB, the factory pre-wires were strapped to the battery cables right next to the positive and negative bus bars which made connecting the solar controller very easy when following Airstream's wiring recommendation.
2018 Globetrotter 27Q, 29 nights 4,435 miles, 600W Solar, PD4655L, Duracell EGC2 Batteries, ProPride, 16" Michelin's, Champion 3400W Dual-Fuel, 2019 F250
Sold: 2017 Flying Cloud 25FB, 316 nights 40,150 miles, 400W Solar
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Type 3 Glass Bar in a Type 2 Hinge rasmuw Windows & Screens 0 12-09-2013 11:18 PM
Wire Type from Roof Solar Panels to Controller CA_Tallguy Generators & Solar Power 19 12-05-2012 04:07 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 08:09 PM
What Type of Restoration is Your Type? ankornuta General Repair Forum 16 11-21-2005 05:13 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 08:20 PM
