03-17-2018, 03:01 PM
2022 25' Flying Cloud
NCR
, Ontario
Type of solar connector on the As roof
What is the type of connector for the 3 port on the top of AS 22FB
i think that only one port has wires.
there were no connectors when we bought the 2017 as 22FB
is the top connector one of these
if what type
are they female or male
03-17-2018, 04:04 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Usually the two wires are stubbed off near a skylight or fan under the skin. Hopefully the factory splurged and put tape over the ends of the wire......
03-17-2018, 04:26 PM
2017 25' International
Niagara-on-the-Lake
, ON Canada
if what type
They are SAE connectors, the same Zamp connectors as near the battery box. The roof box is a combiner box where you can plug in three panels and the are combined to one wire to the interior of the trailer.
Ray B.
03-17-2018, 07:39 PM
NCR
, Ontario
thank you
why cant AS show these in their user manual
also, are the std and heavy duty the same and fit together, they look no different
03-17-2018, 07:51 PM
Niagara-on-the-Lake
, ON Canada
thank you
It sure of differences. You might be able to fine them at Canadian Tire.
Ray B.
03-18-2018, 11:05 AM
1999 30' Excella 1000
Chatham
, Virginia
There were just 2 wires taped off on my 1999 excella. Easy to just look and see.
03-18-2018, 06:18 PM
2014 25' FB Flying Cloud
Fitchburg
, Wisconsin
I don't think you need connectors.
I bought factory solar on our 2014 FC25FB. They daisy-chained the panels using a box on the bottom of the panels to weather proof the wire nuts to make the connections and to connect to the lead-in wire. It was all 10 AWG. The roof entry was an L-shaped tubular connector with a lot of calk that was installed before the interior skin when on--it had a nut on the inside. This is all past tense because I recently replaced the whole thing with two 100 watt panels and 4 AWG cable from the roof to the new controller. The new roof entry is a combiner box from amsolar.com. They have some useful videos about how to use their products.
I didn't use any connectors on the new installation either.
If you think you may be changing the panels then connectors may be worthwhile but the combiner box makes that the screwdriver job.
03-19-2018, 06:14 AM
2017 16' Sport
Miller
, Missouri
On my sport 16 they are all connected. I just put 150 watts of panels on the roof and used two of the connections. They are SAE connectors. A simple MC4 to SAE connector is all you need. My question to those that have used the SAE connectors is, do they stay plugged in? They are VERY easy to unplug. I was hoping that they snap in but that's not the case. I was thinking about running a small bungy cord around the combiner box and through the connectors to hold them in place.
Eric
03-21-2018, 09:14 PM
NCR
, Ontario
i found these on amazon
ten of MC4 f/m pair with pins ready to be wired for $14
waiting for spring to install my new 160W solar, solar converter and new li-ion BB battery
05-19-2018, 06:27 AM
Chatham
, Virginia
Electrical tape. 1999 31’ Excella.
05-19-2018, 07:36 AM
2018 27' Globetrotter
Apollo Beach
It is best if you purchase a heavy duty size 10 AWG SAE connector to use with solar connections. Many SAE connectors have very thin wire that you would not want to use with solar. I used one of these from Amazon: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 cut it in half to make two connections to my Zamp rooftop box. The positive wire used the rubber squared edge side on the SAE connector and the negative used the bare round side on the SAE connector. The solar wiring schematic in my owners manual showed the Zamp box with positive and negative indicated as I described them. On my 2017 FC25FB, the factory pre-wires were strapped to the battery cables right next to the positive and negative bus bars which made connecting the solar controller very easy when following Airstream's wiring recommendation.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
