Old 06-28-2011, 08:06 PM   #61
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We bought the Honda 2000 Companion first as well. And we got the parallel cables at the same time (about $40), thinking that no matter where were were and needed AC there's likely to be someone with another Honda 2000 and if necessary we could double up and whoever gets to use the AC is the designated party trailer! We bought the 2nd (regular) Honda this past spring...used it this past week in the AZ mountains and they worked great.
Note that you need an adapter for the Companion's 30-amp twist & lock outlet so your standard AS shore power cord can attach. (There's a black one shown on the Companion in the picture below... there are different brands, of course.)
We use a Rubbermaid 24 gal Action Packer to haul...the handle of the 2000 happens to fit into one of the grooves on the inside of the lid and holds it steady, and there's room for accessories, etc. We use it for one of the Hondas, with all the accessories, manuals, extra oil, cables, etc...then just use a cover for the other one...
Name:	Rubbermaid 24-gal Action Packer.jpg
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 08-20-2011, 07:42 PM   #62
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
I have read many of the threads concerning solar and generators. our new AS will come with factory solar however based on everything I have read a generator also appears to be necessary especially to run the AC if boondocking or at a site without electric. I have seen where most have either the Honda 2000 or Yamaha 2000 in parallel but I have not seen any comments on the Yamaha EF 2400ISH. Will it run the AC. Its output is rated at 2000 watts and is certainly less expensive then 2 Hondas or Yamahas. Any advice is greatly appreciated
urnmor is offline   Reply With Quote
Old 08-20-2011, 09:11 PM   #63
UAPachyderm's Avatar
2004 28' International CCD
Birmingham , Alabama
I'd consider the equally light Honda 3000 Handi over the Yamaha 2400. Watch this ... http://longlonghoneymoon.com/2011/07...r-triple-fail/
UAPachyderm is offline   Reply With Quote
Old 08-20-2011, 09:41 PM   #64
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Yamaha 2400 owner.
Hi, I own a Yamaha 2400 portable generator and the main reasons for buying it were because I wanted one generator that could run my 11,000 BTU air conditioner and be able to lift it by myself. Sean's case is unusual and somewhat non-believable. A piece of metal got sucked through the carburetor after more than two years of use. Dealers don't have to give goodwill extensions, but they do from time to time. My BMW dealer couldn't fix our car right when it was under warranty; I certainly wouldn't ask them for a good will anything. Two Honda 2000's are the most popular set-up. Honda and Yamaha are the best there is. All of my motorcycles were Hondas, but when it came to buying a generator The Yamaha 2400 made the most since to me. One Yamaha 2400 is a little bit more money than one Honda 2000 and way less than two Honda 2000s. The Honda Handi is a stripped down Honda 3000 at a higher cost. If you want a 3000 generator buy the Honda or Yamaha 3000 models, but wear a back brace because they are heavy.
Note: In defense of Sean, a repair shop should never return a machine in pieces with pieces missing. [story one sided]
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 08-24-2011, 06:03 PM   #65
2008 28' Safari SE
Punta Gorda , Florida
What do you do to protect your generators from the rain?
John Dibble
2008 Safari 28
mysecondjoy is offline   Reply With Quote
Old 08-24-2011, 06:19 PM   #66
"Cloudsplitter"
John,
This works for us....
Old 08-25-2011, 01:23 PM   #67
Bixby , Oklahoma
So I have the same decision to make. I am fine with either Yamaha or Honda, whichever has the best price (except I can't seem to find an extended fuel kit for the Yamaha). But my big question is this, and perhaps my mind is fuddled with all the spec's I have been reading, but won't a duel 2000 watt setup double the sound? Does it not increase the noise pollution above the generally accepted 60 db?
Truebrit is offline   Reply With Quote
Old 08-25-2011, 02:23 PM   #68
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
Found the Yamaha EF2000is today for $989.00 here in Albuquerque. Haven't asked if the are cheaper in pairs.
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 08-25-2011, 03:13 PM   #69
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I purchased both companion and a regular wwith a extended run kit.They are easy to pack,lightweight and very quiet.They sip fuel.They power my 15000 btu ac unit when paralleled.You always get what you pay for and Honda has always been good stuff...........
I am very pleased
Old 08-25-2011, 03:36 PM   #70
"Cloudsplitter"
Truebrit,
As I understand it....no the loudness would not be doubled.
Think of the generator as the POWER thats creating the 60 decibels (noise).
Every time you double the power (two generators @ 60db each) you will get approximately 3db increase.
Any sound engineers out there????
Old 08-25-2011, 03:55 PM   #71
steverino's Avatar
2018 30' Classic
Ivins , Utah
Well I'm an electrical engineer, not a sound engineer, but I've dabbled in audio. It makes sense to me if you have one toy making x amount of noise, then you fire up another identical toy, you are making up to twice the noise, ignoring phase effects which may produce some noise cancellation effect. Due to the logarithmic scale used to measure sound pressure, results in a 3 dB gain.
steverino is offline   Reply With Quote
Old 08-26-2011, 11:10 AM   #72
Bixby , Oklahoma
Thanks for the input guys. I have made the decision chose the 2 Gen solution. I ordered the combo package EU2000i, companion EU2000i with Parallel cables and RV plug Adapter from wisesales.com. Including the free shipping plus shipping insurance and double boxing the total came to $1929.81. Even with the extra cost of shipping insurance this price beat all my local dealers by almost $500.00.
Old 08-26-2011, 12:24 PM   #73
Alumaholic's Avatar
Images: 36
You done good! Happy generating and inverting!
Ken L
Old 08-26-2011, 06:53 PM   #74
... the total came to $1929.81.
But did they include a flux capacitor?
Old 08-26-2011, 07:23 PM   #75
Steelegood's Avatar
2005 31' Classic
Cleveland , Tennessee
Hey TBRich:
Originally Posted by TBRich View Post
We use a Rubbermaid 24 gal Action Packer to haul...the handle of the 2000 happens to fit into one of the grooves on the inside of the lid and holds it steady, and there's room for accessories, etc. We use it for one of the Honda's, with all the accessories, manuals, extra oil, cables, etc...then just use a cover for the other one...
Thanks for the useful information re: the tote. However I've been looking for the 24 gal. action packer tote w/o success. I found one but the handles are on the front. You stated that the handle of your generator fits inside one of the grooves on the lid. After buying one action packer (latch on the front) I can't get the generator into it except left to right whereas the handle does not fit in any groove b/c it sits in the wrong direction, and leaves little room for anything else. It's impossible to get it to sit facing front to back w/o forcing it to turn? Do you have the same problem, and force the generator to fit front to back, so as the handle will fit in one of the grooves? so you have room for accessories for the generator?
Thanks for your helpful information. I've never used a portable generator and am excited to have one! Your comment about extra cables was also terribly helpful information. Additionally, no one ever mentioned I would need an adapter for the twist lock plug. Again more useful information. Any other comments you could give me would be greatly appreciated.
Thanks, Terry.
I know you think you understand what you though I said, but I'm not sure that what you heard is what I actually meant!
"If you don't know where you are going, any road will take you there." Lewis Carroll
AIR #38011
TAC TN-4
NOVA
Steelegood is offline   Reply With Quote
Old 08-27-2011, 09:39 AM   #76
2005 19' Safari
GLENDALE , AZ
We got ours at Lowes: Shop Rubbermaid Plastic 24 Gal ActionPacker® at Lowes.com=
Home Depot indicates that they sell them, but we were unable to find one in stock at their stores in our area.
Old 08-27-2011, 01:15 PM   #77
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I looked at the Honda 2000's but went with the 3000. It has elect. start, large fuel cap., the lowest db rating and I don't have to lift it. I have a chain hoist in my barn so I just back the truck under and raise the gen. up a couple of inches. Move the truck out and lower the gen. on a heavy duty cart and push it out of the way. The gen. goes in the truck bed at the beg. of the camping season and stays there until we put our Safari away for the winter. I chain it in the truck bed. If I had to lift it I would have bought the 2000's. Having only 1 gen. just seems to be 1 less thing to worry about. By the way, it will run our air all night long before it needs filling so I don't have to mess around with an external tank.
ID:	138812   Click image for larger version
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 08-27-2011, 04:33 PM   #78
tkowalyk's Avatar
2013 27' FB Classic
Clermont , Florida
Images: 11
I just purchased the Yamaha EF2000is for $890 (with a $100 discount at checkout) at http://www.yamahagenerators.com/
Free two day shipping, no tax. I purchased the generator Wednesday afternoon, and it arrived Friday.
I chose the Yahama based on a review from Camping Life Magazine. The recommendations from Camping Life are usually right on...like my new Yeti Cooler.
The Yamaha was rated higher than the Honda due to easier starting and a gas shut-off. The negative rating...you need to remove two screws to remove the cover.
It took 10 minutes to fill the oil and get it running.
Tom & Lori
2013 27 FB Classic Limited
2019 Ford F250 King Ranch 6.7L Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 08-27-2011, 05:37 PM   #79
"Cloudsplitter"
Terry,
The 24 gal AP should look like this, the 2000i drops right in no problem.
Name:	HONDA CONVERSION add vid pix2-3 006.jpg
Old 08-28-2011, 01:15 AM   #80
2005 19' Safari
GLENDALE , AZ
Robert Cross, I see a "binder clip" on what looks like the fuel line. Do you use this to run the carburetor bowl dry before storage? Is the darker green tubing something that you installed, or is that the way the generator came from the factory? (I assume it is softer or more flexible than the greenish yellow tubing.)
We used to have a boat with a 70 hp outboard, and we always disconnected the fuel line and let the engine run dry before we took it out of the water. That way, the carburetor never got gunked up.
I saw where Yamaha recommended this, but hadn't figured out the modification details on how to do it on our Hondas (fuel shut-off valve, extra fuel line, mounting hardware, etc.). Obviously, I was overthinking this; and the binder clip is a much simpler solution.
multiple, generator
2000 Excella Silver Threads 1997 -2001 Excella 10 10-05-2020 03:56 PM
Honda EU3000iS vs. Yamaha EF3000iSE/B pickerdd Generators & Solar Power 13 07-02-2017 09:47 AM
wiper blades 2000 Land Yacht daveshrader Land Yacht/Legacy Motorhomes 3 07-01-2011 06:18 PM
2000 Excella Silver Threads Trailer Values 10 05-13-2011 04:39 PM
Honda EU 3000i generator for sale rando Generators & Solar Power 2 05-12-2011 10:30 AM
