Old 01-17-2015, 06:38 PM   #1
2018 23' Flying Cloud
Eagle Creek , OR
Send a message via Skype™ to almcate
Troubleshooting dead solar kit controller
Hi all,
Full time and working from the road, so mostly we look for hookups, but maybe once a month, head off to dry camp. Decided a full solar setup wasn't cost-effective for our circumstances and instead bought a portable 100 watt solar kit from Renology. Control module is built-in and on the half dozen occasions we've used it, it's worked flawlessly to keep batteries topped off.
Yesterday everything worked fine with good voltage indicated and happy batteries. This morning, however, got anxious to switch over from generator (toast and ground coffee, you know) and while idling down to clear out the fuel line, I hooked up the solar to the batteries while generator had not yet shut down.
Solar controller appears to be dead, no display, and no power to the batteries. Hindsight tells me I must have damaged the controller ... does anyone have any troubleshooting suggestions (or confirmation this a lost cause and I just should replace the controller)?
—Al
Question: better to be a successful pessimist or a failed optimist?
Al & Robin
2018 Airstream 23FB Flying Cloud
2015 F150 XLT 3.5L EcoBoost, 4WD
almcate is offline   Reply With Quote
Old 01-17-2015, 07:05 PM   #2
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
Do you have and have you checked for any fuses that may be protecting your controller. If not, sounds to me like it's dead, but then I'm no solar expert. You need Lewster, the solar expert. Try to p.m. him for his opinion.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 01-22-2015, 02:29 PM   #3
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Assuming you have the suitcase 100 watt setup there is a 7.5a fuse on the positive lead according to the instructions. See if that fuse has blown.
Kelvin
Old 01-23-2015, 06:27 AM   #4
Eagle Creek , OR
Head slap. Back and forth with Renology service support emails and turns out about as simple as plugging in the TV before you call the repairman. Reversed the terminal hookups. Knew the fuse was good, but it was clear the controller wasn't powering. The real tip off was finding out the BATTERY provides power to operate the controller, not the PV. Knew the PV cells were all sunny... but if they're not powering the controller... oh, maybe it's operator error and not controller error. Head slap.
Al
Al & Robin
What do you guys think of this solar kit available at Costco? wacnstac Generators & Solar Power 14 01-16-2013 07:05 PM
dead dead bolt Jim from SB Doors & Locks 3 09-09-2012 11:32 AM
Prodigy Brake Controller/Dead Battery in TV OB Bambi Brakes & Brake Controllers 7 05-02-2009 06:54 PM
Dead ...really dead Melody Ranch Batteries, Univolts, Converters & Inverters 17 06-13-2007 12:23 AM
Airstream vrs. Go Power Solar Kit jglase Generators & Solar Power 0 09-13-2006 08:05 AM
