Old 10-18-2013, 07:12 AM   #1
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Trifuel Yamaha EF2000iS better than sex...
...almost!
Just received my trifuel from Central Maine Diesel. Nicely modified, clean factory look. I hooked it up to my AS propane connection, primed it, and it started like a charm. Ran it to charge the batteries a bit, no problem. It is so quiet. There was some question about the hose size and the load, but it is not an issue for battery charging and internal DC use. I did not try heavier load.
I bought this unit for battery charging if solar does not get it done and maybe the microwave. I have no intention of using it for air conditioning although one reason I picked this model is the capability of adding another one and having 4kw for AC.
Larry
lsbrodsky is offline   Reply With Quote
Old 10-18-2013, 07:29 AM   #2
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
catchy title. But it made me feel sorry for you...
I have considered that yamaho though. seems like a sweet option. The only other thing I thought about was having a stainless tank welded up and put between the frame members to keep gas in for a generator.
A motorhome uses gasoline. Why not put a gas tank between the frame members and put in a generator. The only thing different between a motorhome and a trailer is the engine.
robwok is offline   Reply With Quote
Old 10-18-2013, 07:57 AM   #3
SteveH's Avatar
Common Sense , Texas
I received a joke e-mail from a friend the other day, and it was different posters for men.
One of the posters said, "My sex life is just like my Farrari. I don't have a Farrari."
Regards,
Steve
Old 10-18-2013, 07:58 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Nice thing about having the multi-use option is not having to bring more than a 1/2gal of gasoline.(just in case)
I did the conversion on our Honda 4 Seasons ago, best generator up-grade I did, along with the gasoline shut-off valve and tach/hour meter. Runs cooler,cleaner and longer between fill-ups. Another nice feature is being able to adjust the mixture to compensate for altitude.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 10-18-2013, 09:13 AM   #5
lsbrodsky's Avatar
Why would you need gasoline with 60 lbs of propane capacity? I have a 11 lb propane tank and regulator that I thought about taking along as a backup, but I am not sure I would ever need it. Just more junk to put in the truck.
Old 10-18-2013, 09:15 AM   #6
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Either I know nothing about generators,
Or
You know nothing about sex.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 10-18-2013, 10:59 AM   #7
Thumbs up
Whats the point of multi use if you don't multi use.
If I need to generate other than when Streaming I have that option.
I always start the genset on gas just to make sure everything is OK.
LPG can be hard starting in the colder weather.
It's easier to start on gas let it warm-up, shut off gas supply, when starts to stumble, switch on the LPG.
When winterizing I start on gas, warm-up, shut off petcock, when it stalls drain what little gas is still in the float bowl. Remove spark plug, fog the cylinder, add Sta-bil and change the oil.
We 'dock a lot and it's nice running the genset away from the AS in it's own tent.
Consequently it runs on it's own pancake tank.(18-22hrs,no ac)
Sweet Streams...
PFC
"Tahawus"
RLC
John Prine
Old 10-18-2013, 11:18 AM   #8
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
my impression was that propane has a lower burning compression than gasoline. (something like that) End result is that generators that run on propane cannot generate the same number of watts that a generator running on gasoline can.
As far as the two 30 lb tanks, I've heard of folks running out of propane in the winter. If I'm in a place that gets freezing at night, I may have to conserve propane.
Just thinking through if I could create the best case scenario, it seems easier to drive up to the gas station and fill my trucks gas tank at one pump, and the trailer's gas tank at the 2nd pump. Just seemed like an easy option, and the generators could run a long time if needed.
I didn't realize there was a propane kit for the Honda. I like that option. Robert, can you post where you got that?
Rob
Old 10-18-2013, 11:50 AM   #9
Thumbs up
LPG does produce fewer BTU's, slightly less efficient, but I doubt if it effects the gen's output.
I got the kit from US Carb.
They were suffering from some bad press for awhile here on the Forums.
From what I understand the CS has improved a lot lately.
Best to give them a call and find out.
If your at all handy the conversion is not all that difficult. They do require that the carburetor be sent to them for modification. (folks were screwing it up on their own).
PFC
"Tahawus"
RLC
John Prine
Old 10-18-2013, 06:03 PM   #10
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I was thinkin' you needed to hang out with different girls.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 10-18-2013, 07:57 PM   #11
gaylejoe's Avatar
2007 25' Safari FB SE
St. Hedwig , Texas
Received my new Yamaha 2400iSHC this afternoon. Haven't had a chance to run it yet. I did a lot of reading and decided this gen was the best buy for the money.
gaylejoe is offline   Reply With Quote
Old 10-18-2013, 09:54 PM   #12
jdalrymple's Avatar
Jay , Oklahoma
Typically, genset output is derated by about 10% when powered by LPG or natural gas.
Due to the reduced BTU output of these fuels compared to gasoline.
Regards,
JD
Jeff & Cindy
'91 350 LE MH
Old 10-19-2013, 07:35 AM   #13
BDBLUEGRASS
bdbluegrass's Avatar
1975 31' Sovereign
HEBER SPRINGS , Arkansas
Down at the home we use Adolph's sex substitute. just my luck I bought two Hondas. Have a fun day. bdbluegrass.
bdbluegrass is offline   Reply With Quote
Old 10-19-2013, 07:40 AM   #14
Thumbs up HP-output.....
Regards,
JD
Power (hp) yes, but......
.......the electrical output, would remain the same @ a given RPM.
Our Honda runs @ 3000rpm in eco mode, on LPG or petrol.
As long as I'm not maxing the load on the 2000is I don't think the lower hp will ever be a concern. 4 years now SFSG.
PFC
"Tahawus"
RLC
John Prine
