Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 07-14-2007, 07:56 PM   #1
2007 25' International CCD
Arlington , Virginia
Question Thinking about purchasing a diesel generator
Since I drive a 2006 F250 Powerstroke, and I am thinking about an auxiliary tank for the pickup truck bed to carry additional diesel, I have been thinking it would be nice to have a generator that used the same fuel as my truck. I could refuel both the truck and the generator from the aux tank in the bed when necessary. Problem is most PORTABLE diesel generators I have come across have continuous wattage maximums of about 6100 watts. This would provide about 25.4 Amps which sounds good, but it ain't the 30 amps needed to power the Airstream. The next size up diesel generator is either a "tow" job or a "stationary" monster. I could easily just go with the two little Honda EU2000s, but was trying to stick with ONE fuel for both tow vehicle and generator. Thoughts anyone?
Streamer1 is offline   Reply With Quote
Old 07-14-2007, 08:57 PM   #2
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Lunar Park
Streamer1
Hi,
Most SOB motorhomes come with a 5000k Genset. The 6100K would be more than enough to run your Airstream, unless you have 2 AC's you want to run both at once, or all your lights, the microwave oven, fridge, furnace and your AC at the same time.
I'd go with the 6100K
Michael
ArtStream is offline   Reply With Quote
Old 07-14-2007, 09:15 PM   #3
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
My Dometic Penguin 13.5k unit compressor draws 12.4 amps and the fan motor 3.1 amps. I don't know if this is startup or continuous so I would find out what it draws and go from there. My Yamaha EF3000iSEB handles the Penguin just fine but occasionally will kick off the breaker to the Intellipower on initial startup. If I reset it then it does not do it again.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-14-2007, 09:22 PM   #4
cosmotini's Avatar
2021 27' Globetrotter
Saint Louis , Missouri
Images: 83
25 amps at 120v? Wouldn't that = 3000 watts?
Dennis
BRN #20321 Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 07-14-2007, 09:31 PM   #5
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
What's the noise level on that "portable" diesel generator?
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 07-14-2007, 10:18 PM   #6
davidz71's Avatar
1986 25' Sovereign
The Yamaha EF3000iSEB has rated current of 23.5 amps and max of 25 amps. If the diesel generator puts out at least that then you should be good to go for your A/C and lighting.
Craig
AIR #0078
3.73 rear end
Old 07-15-2007, 05:06 AM   #7
I believe the calculation is: 6100 watts divided by 240 Volts = 25.4 Amps
Old 07-15-2007, 05:14 AM   #8
75 dba at 7 meters. I am not that concerned with noise level cause it would be used on private property, not a campground situation.
Old 07-15-2007, 05:18 AM   #9
Sounds good Craig. So, for Airstreams that use a 30 amp circuit, does this mean you can use a power source that provides LESS than 30 amp power (may not be able to power all requirements) but you cannot use a power source that provides MORE than 30 amps?
Old 07-15-2007, 07:13 AM   #10
2003 22' International CCD
Whittier , California
Streamer-----You used 240v in your calc to determine max amps while the other folks are talking 110v since that is what the AS uses as input from shore power. Maybe that's the difference?
bobkelly is offline   Reply With Quote
Old 07-15-2007, 07:20 AM   #11
Retired.
. , At Large
6100 watts/125 volts =48.8 amps. I think your Airstream can operate on that amperage. We have a 6,000 watt generator that doens't even hiccup when you turn on the air conditioner, microwave, and television at the same time. I suppose we could try turning on a hair dryer, too, but that would probably trip the 30 amp breaker int he coach.
Old 07-15-2007, 10:32 AM   #12
Hi Bob. I used 240 Volts cause that's what an engineer at Kubota was using in her calculations. So far I've seen or been informed about 240V, 120V, 110V, and now 125V. My head is spinning!
Old 07-15-2007, 10:36 AM   #13
Sounds like the coach (AS) electrical ckt is the "weak" link, not the generator's ability to pump out amperage?
Old 07-15-2007, 11:46 AM   #14
HowieE's Avatar
Princeton , New Jersey
Images: 12
The same fuel idea is worth considering but since I assume you will be using the generator while using the trailer I would suggest you consider a propane generator, less expensive per KW, propane engines will last longer than gas, and a wider varity to select from.
If you look at my site Page 3
you can see how I take propane from the trailer to fuel my truck when I want real power. The same idea could be used to fuel a generator.
Honda and Yamaha both make propane generators in the 3000 watt size that will meet the needs. yes the Airstream has a 30amp service but that does not mean it has to be supplied with 30 amps just to work. I assume your hause has at least a 200 amp 3 phase service but I doubt you ever draw 1/3 of that.
2004 Excursion 4x4
Old 07-15-2007, 01:45 PM   #15
HowieE,
was actually looking at a DIESEL generator NOT gas. I like Diesel (less volatile) than both gas and propane.
Old 07-15-2007, 02:40 PM   #16
HowieE's Avatar
Images: 12
HowieE,
Hi Steamer1
Popane is a completly contained fuel and would be be no less dangerous than ant other propane equipment in your trailer. Give it some thought.
2004 Excursion 4x4
Old 07-15-2007, 03:17 PM   #17
Streamer----Sorry for the confusion. 110v, 120v, 125v are all labels for the same thing. The household voltage we use for lights, TVs, kitchen appliances and airstream lights and appliances. Your local power company provides a nominal 120v and slight variations don't matter. Your engineer friend may have used 240v to show you how the calculation is made, not meaning it to apply to the airstream electrical system in particular. The amp capacity is the maximum load you may safely pull through a circuit before it over heats. when in fact the radio or light bulb is drawing only one amp.
Hope this explanation helps.
Old 07-15-2007, 03:49 PM   #18
davidz71's Avatar
1986 25' Sovereign
I wondered about the 110, 120 and 125 volt thing for years until I ran across an article that explained there really is no more 110 A.C. unless you have a really bad line. The voltage was increased so you will usually see more in the range of 120-125 volts. I went out to the trailer and my voltmeter registered 121 volts. When it drops down to 113 volts then it goes into the red area. Fortunately I have a Hughes Autoformer which will keep the voltage up or shut the system down should I hook up to a line with low or very high voltage.
Craig
AIR #0078
3.73 rear end
Diesel tow vehicle-tips? maxandgeorgia Tow Vehicles 27 08-27-2006 10:28 PM
Generator filters ViewRVs Mechanics Corner - Engines, Transmission & More... 7 04-05-2004 08:17 AM
Onboard generator bhsl8 Generators & Solar Power 39 07-29-2003 05:31 PM
Generator Paul Daugherty Airstream Motorhome Forums 19 08-09-2002 08:47 AM
Generator for a Tradewind uwe Generators & Solar Power 6 08-02-2002 08:51 AM
