03-25-2019, 09:30 PM
2007 27' International CCD FB
San Diego
The Everyday Man's Lithium Upgrade
We've all seen and read the extents and investments people go through to upgrade their systems to lithium. Some of them exceedingly impressive, complex, and intimidating. Just the way their proud owners like it.
I design systems for a living. I guide large teams of multi-functional engineers to build forward leaning technology. I've learned over the years, that give an engineer enough time and money, and they will over engineer the crap out of something to the degree that no one else will understand. Because complexity in and of itself shows their worth!
Well, it takes real engineering chops to make things work elegantly and simply. Apple would be a great example here (except those cost an arm and a leg).
Enter the Everyday Man's Lithium upgrade.
I'll caveat that this is not for everyone. Especially those that have a great need to power built in large draw devices. But for 95% of us...
Upgrade via a standalone lithium battery like a Goal Zero 1000, or the like.
Consider:
1) Keep the stock AS battery system for "house" battery chores as it was designed for - furnace, pumps, lights, etc. It's always worked exceedingly well for this. Upgrade this with low cost flooded golf cart 6V house batts for a great 120-140 Ah of power.
2) A standalone lithium battery adds "accessory" capacity above and beyond the "house" battery, and one is not wasting money just replacing capacity. 140Ah of 6V house + 80Ah Goal Zero = 220Ah usable power. Now that's a real capacity upgrade
3) A Goal Zero style battery has built in 1500W inverter built in. 12V/USB. Anything and everything you'd like to power. Without being tethered or tied to only the travel trailer. It also has great monitoring tools to help one meter their "accessory" usage. It could power the whole trailer if one plugged the 120V output to the trailers main power input in a pinch.
So how does one integrate this accessory lithium power pack to the trailer?
We know that key to any power upgrade for long term power is solar. No different here. And one will want to size the solar appropriate to both the house battery and accessory battery.
Goal Zero style battery packs can charge through a 12V input. That's how one would integrate it to charge off the DC 12V trailer wiring that is fed by solar. Key to this would be adding an "Automatic Charge Relay" type device. There are many on the market, but these basically detect the presence of charging voltage (>~13.1V) and will tie the auxillary "accessory" battery to the circuit. This keeps the aux battery from charging from the house battery and pulling it down when there isn't active extraneous charging power available.
If one wants more power, get a Goal Zero 3000 type device. ~250Ah + 140Ah house = ~400Ah.
03-26-2019, 06:26 AM
2015 27' Flying Cloud
Newberg
, Oregon
Hmm. Interesting concept. I'll be thinking about this.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
03-26-2019, 07:21 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Mike
Very interesting for sure...but three batteries, I'm brain-tapped with two. KISS, for me. 😂
03-26-2019, 08:26 AM
2017 25' International
Niagara-on-the-Lake
, ON Canada
I understand your desire to have more 12V - amp hours. There are other low cost alternatives to your idea.
I have found that with two AGM group 27 batteries I have enough capacity to power the trailer (including the furnace) for at least 24 hours.
If off grid I prefer to quickly recharge the house batteries from my running TV (at a much higher rate than a portable generator) by using a 2-gauge quick connect power cable kit in the tow vehicle (incorporating a battery isolator) to short a quick connect cable set connected to the house batteries. I can even use my remote start from inside the trailer to recharge the batteries in the middle of the night if needed. This probably costs less than the Goal Zero and saves the weight of carrying around the Goal Zero.
I do carry a portable lithium jump start kit. This will charge USB devices as well as start your TV if needed, or run an air pump. It can also be charged from your car cigar lighter.
If you wanted to have a second pure sine wave inverter you could use the CarGenerator that can provide up to 1000 watts.
Ray B.
03-26-2019, 09:52 AM
2018 27' Flying Cloud
Atlanta
, Georgia
Sungzu battery
I did something similar to what you are doing except that I used the newly introduced Sungzu 1010 WHr battery which is a bit cheaper than the Goal Zero. These batteries (I have two) are light enough that they can be taken to a “dry camping” campground outlet (usually in men’s room) and recharged in a pinch. Also, the 110V charger that comes with the Sungzu is 250 watts which allows recharging in 4-5 hours compared to the 18 hours of the smaller Goal Zero charger.
The other decision I made was to buy a NOCO Genius G7200 12V/24V 7.2A UltraSafe Smart Battery Charger,connect it to the Sungzu 110V outlet, and use that to continually charge the AGM house batteries I have. The current draw from this device is low and makes the lithiums last longer.
03-26-2019, 09:56 AM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
pteck
I like your concept. I might have taken this route if I hadn’t already planned on replacing my two flooded 8 yr old golf cart batteries with BB and installing a 2,000 watt inverter so I could run my microwave. I did what I planned on doing, it is not complicated and it works well.
A couple of comments. I might be concerned about theft if the Goal Zero is connected to the trailer. My second concern would be warranty of the Goal Zero. I know my BB batteries are warranted for 10 years and my inverter for 2 years, I believe.
Here is my simple power plant. It operates everything in my Airstream.
Dan
03-26-2019, 10:03 AM
2018 27' Globetrotter
Mooresville
, North Carolina
Thanks Pteck
I appreciate all your posts on various topics. You think outside the box and explain things in a way that us non-engineers can understand.
I had actually considered this as an option myself but want to use my RV a little more to determine my specific needs. To date, I see this as a boondocking option for;
1. Using an alternative energy source for those times when it is quiet time for gas generators. Running a fan outside to keep cool or coffee maker / TV in the morning as the 1000W inverter is lacking.
2. Using to power a space heater at night to keep from running the house batteries down with the furnace.
3. Powering all sorts of other battery draining items from the RV house batteries.
We already have the Goal Zero lithium lights for night time and a lithium powered portable fan to move air at nighttime when sleeping.
We currently have 2 AGM batteries / factory solar and a Honda EU2000. It just seemed it would fit our use as a simple add on to what we currently have as a source for power,
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
03-26-2019, 10:17 AM
Niagara-on-the-Lake
, ON Canada
It would be much more efficient (electricity-wise) to use a DC to DC charger rather than converting 12V to 110V and then back to 12V.
Ray B.
03-26-2019, 10:26 AM
Niagara-on-the-Lake
, ON Canada
1. I don't understand why one would want an 'alternative' 12V power source when you have perfectly adequate AGM batteries. Use an alternative, such as your TV, to keep your house batteries topped up as needed.
2. You would need a massive battery bank to power an electric space heater during the night. You might want to consider a heating alternative like our Dickinson Newport propane fireplace that doesn't require 12V power to run. Some folks use the Mr Buddy catalytic heaters, but they add a lot of water vapour to the cabin air.
3. Just charge your house batteries from time to time as needed rather than having to charge another portable battery. That is what there for.
Ray B.
03-26-2019, 11:19 AM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
GOUSC
It really is good to just go camping so you can figure out what your needs are.
The 1,000 watt inverter should be fine for an outside fan, TV and most other stuff, just not for a microwave, a hairdryer on high or a coffee maker.
Your furnace fan probably uses about 100 watts, where most all electric heaters are 1,500 watts. Don’t use an electric heater unless you are plugged in.
I agree that a Goal Zero, or an alternative, would work well for you if you really do need more battery power.
Dan
03-26-2019, 12:10 PM
2015 25' Flying Cloud
Bend
, Oregon
This is a very interesting thread.
What I am taking away from this is some people do not want to get into the details of upgrading batteries and chargers etc.. as they do not have the confidence or maybe experience to tackle something that is outside of their comfort zone.
The goal zero approach takes a nicely packaged system that people are more used to dealing with and people are finding creative ways to implement it, even if it may be less efficient it is something they understand and can use.
With that being said, I am firmly in the camp that we have batteries in our Airstreams and we have charger converters. These are know systems that work well and are not too difficult to upgrade. The goalzero product, in my view, is a nice product but is not optimized for glamping.
It is interesting to read about other solutions, keep up the great work everyone! Question everything, challenge everything!
03-26-2019, 12:12 PM
Apollo Beach
My thought on this topic is that using a Goal Zero would be equivalent to using portable solar panels. I don't want the hassle of setting up portable panels, just as I don't want the hassle of charging the Goal Zero with the need to move it around while plugging and unplugging appliances to use it. I just want to seamlessly turn on the appliance to use it.
I think the drop-in Lithium battery is beginning to simplifying the path to Lithium. This recent post by ChrisCow http://www.airforums.com/forums/f448...ml#post2222227 looks like a Lithium self-install is closer to reality. The only scary looking piece of that install was the 4/0 cabling. If 4/0 cable is needed, I'm a little bit scared of what a short could do. (I didn't like that the battery cutoff switch was behind the batteries in that installation. I wouldn't want to reach across those 4/0 cables while they are glowing to cut off the power!) I think the drop-ins are lacking the technology to cut off battery charging when they are full, which is why the complicated engineering masterpiece installations are still needed.
My point here is that it appears drop-in Lithium is getting more mainstream and will someday make Lithium installations no more difficult that a standard battery installation. I'll be watching the Lithium drop-in market develop while getting by with my measly 230AH wet-cells, tiny 1000W inverter, and my Champion 3400W Dual Fuel Generator to make up for my battery bank weakness.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
03-26-2019, 12:32 PM
Niagara-on-the-Lake
, ON Canada
Originally Posted by AirMiles
... it appears drop-in Lithium is getting more mainstream and will someday make Lithium installations no more difficult that a standard battery installation. ...
I too would love a drop-in lithium battery solution, but living in a northern climate and often camping in below 0° C conditions, a drop-in lithium batteries wouldn't work as they can't be charged when outside the Airstream in freezing temperatures.
Ray B.
03-26-2019, 01:47 PM
Apollo Beach
When I say drop-in, I mean a simple installation, not tongue located. If I were installing Lithiums, I would relocate them inside the secure and controlled environment of the Airstream to facilitate very short and thick cable runs to a newly installed large inverter. Wet Cells are the only batteries I would leave tongue located, because of the gassing and acid mess, and then I would just keep using the stock inverter and cables. In other words, do it right or not at all.
03-26-2019, 06:17 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
AirMiles
I am a bit confused. My understanding is that the converter or the solar controller controls the charging of the batteries. When they are full, about 13.5 volts, they receive no charge from the converter or the solar controller. I have only a solar controller with no complicated engineering masterpiece and it stops charging my lithium’s at the 13.5 volt setpoint.
Dan
03-26-2019, 06:38 PM
Fort Davis
Originally Posted by TouringDan
AirMiles
Dan
Dan,
Yes, that has been the standard for years. However, with the new BMS technologies, the batteries control the charging sources. You have to admit, that makes sense. Who better to know what they need than the batteries themselves.
Pat
03-26-2019, 07:24 PM
San Diego
Thanks all for the discussion. As is expected, everyone has a different perspective which are all legitimate to how they like to use things. Though there's more versatility and practicality here than some acknowledge. While Goal Zero's and battery power stations are not new nor never discussed, there's something new which some may have missed.
What's new is the integration. No one wants to daily manage the charging of a separate battery device or plug in portable solar panels. Idea is to size the rooftop solar to adequately cover the house battery and additional accessory battery. Because more capacity is after all what we're looking for.
Enter the "Automatic Charge Relay". Picture might help:
https://www.amazon.com/Blue-Sea-Syst...48928063&psc=1
What this device does is allow the power station to be plugged into the travel trailer 12V circuit and automatically enable charging when solar is producing. Thus truly tying in with full automatic charge management. To clarify, the ACR device is tied into the travel trailer 12V. Then a 12V charger on the power station side it plugged into this relay. Both "house" and "accessory" battery are charged when solar (or 120V converter power) is available. Then decoupled when charging power is not available.
Those proposing lithium house battery upgrades are missing the point. That is a whole other proposition entirely. One that perhaps adds complexities that may not be understood like potentially drawing down TV batts with the mixed chemistry, poor temperature thresholds, low state of charge without full upgrades, $$$. And then one has only gold plated the capacity that was already there with standard batteries. Unless one goes to extremes and gets 2X+ lithiums. Devices don't care if they are powered by flooded batts, lithiums, nuclear, or coal. It's ultimately about capacity.
That's where a portable "accessory" battery comes in. It's instant expansion (not replacement!) of battery capacity. It's flexibility to run a hair dryer anywhere, brew coffee outside, charge power hungry devices in the tow vehicle on a daytime excursion, and so much more.
It's priced better considering all its functions, enables more use cases, expands capacity, works as a backup should a primary system fail, and so on. Expand with as large of a accessory battery as you like. Chain them. There's no practical limitations here.
I'm as much of a DIY modification junkie as any, sometimes to the extreme. Yet I tempter that with value when I invest the time and money. Looking at the whole life-cycle when considering return on investment.
That's where my monies would go. Now if only Goal Zero will update their Yeti 1000 with USB-C PD ports as they've done with their other larger units.
03-26-2019, 10:04 PM
2017 30' International
Lincolnwood
Goal Zero 3000
I see 2 major stumbling blocks to my purchasing this item
Cost-$3000 + tax
Life cycle- 500 charges to 80 %. NOT GOOD !
Very Expensive !!!
LI-ion NMC technology ???
You can get lithium batteries that accept 2000 charges for the same price per A/H.
My wife and I are increasing our capacity by replacing house batteries with
2 -6 volt Lifeline Batteries, giving us 110 ah of usable power.
Will charge when needed with Champion dual/fuel generator, or electric hookup every 4th day. Long days driving will also charge the batteries.
Has anyone put 240W solar on the roof and simply plug in to the
Zamp exterior plug? Would help deter theft of portable system.
03-27-2019, 04:57 AM
Apollo Beach
Zamp exterior plug? Would help deter theft of portable system?
Yes, read the "Solar Show and Tell" thread http://www.airforums.com/forums/f448...ll-181608.html which describes how I installed 400W through the Zamp rooftop box using a series-parallel configuration. With a 30', I'd be the first to put 600W up there using the series-parallel configuration, Zamp rooftop box, and factory prewire. Bring any further solar discussion over to that thread and your questions will all get answered.
