Old 11-21-2012, 06:54 PM   #29
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Originally Posted by Keyair
At the risk of sounding rude...
I have a Kohler.
Send me the money for the Honda and I will put it in, otherwise please be sensible and keep reminding yourself that not everyone has a budget for that.
Not only that but it probably won't fit.
Any thoughts on the Open neutral issue?
I'm no expert but I sort of thought that was normal for a generator. Doesn't have to do with the grounds not being an earth ground?
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 11-21-2012, 07:24 PM   #30
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Open neutral is a bad thing and very dangerous.
In my SOB with a 7KW Kohler I found the neutral wire in the distribution box in the generator compartment was burnt open.
Was OK on shore power.
Reread your post I would suspect the cord reel
Garry
Old 11-21-2012, 07:46 PM   #31
Steve,
The Kohler generator has a voltage regulator module that can go bad. Check out this thread: Kohler voltage regulator
I also use a Kill A Watt to monitor voltage in the motorhome. Very handy device.
Old 11-21-2012, 07:57 PM   #32
Thanks for that Gary!
I was concerned with good reason then!
I did test the portable genset at its outlet and it showed good.
Last year I pulled out the cable reel and did a refurb on it and the water and electric reel box.... the cable looked and felt good, but I did not think to test it...
Looks like that is on the suspect list, but I will have to check I did not miss something when I reinstalled it, as I disconnected it from the MH and the juction box under the bed.
Before..
After..
Completed compartment..
Also monted the Kohler on drawer slides for easier service..
