Old 04-12-2016, 06:54 PM   #1
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Surging EU 2000i
My Honda EU 2000i surges when the eco mode is engaged. even with no load. By closing down the choke part way I can smooth it out. Do I need to adjust the carb? Is this even possible?
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 04-12-2016, 07:06 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I've had both of mine do that after extended periods of non-use. I connected them up to the trailer, filled them with fresh gas, turned off eco mode, started them, and switched on the air conditioner. After about an hours' running, they no longer surged when I shut down the air, and turned on the eco switch.
Old 04-12-2016, 07:56 PM   #3
aftermath's Avatar
Spokane , Washington
Mine started to do this and I started using premiun gas treated with seafoam. Haven't had a problem and it has been about 8 years now. Never touched the carb.
aftermath is offline   Reply With Quote
Old 04-12-2016, 07:58 PM   #4
1974 Argosy 20
Kooskia , Idaho
What Overland63 says, plus fresh gas. Non alcohol gas if possible. Find that at stations listed on this site, if any are close to you. Worth a drive out of the way for it. Will make a world of difference in the long run.
http://pure-gas.org
Old 04-20-2016, 03:08 PM   #5
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
If that doesn't cure it, remove and clean the carb. It's easy.
2012 Dodge Durango Hemi/AWD
Old 04-20-2016, 03:19 PM   #6
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
and get a new bowl gasket before you remove to clean.
DoublTrouble is offline   Reply With Quote
Old 04-21-2016, 07:06 AM   #7
2013 25' Flying Cloud
Middleton , Idaho
Not sure about your Honda generator, but I fought this all the time with motorcycles when I lived in CA. When the low speed jet in the carb clogged, I would have to leave the choke on to keep the bike running. I haven't had nearly the problems in Idaho since it is easy to get non-ethanol fuel. Small in-line fuel filters also helped. The previous suggestions about running fresh clean fuel, maybe with something like Seafoam, might clean yours out.
Trailbob is offline   Reply With Quote
Old 04-21-2016, 09:36 AM   #8
Johnco's Avatar
2006 19' Safari
Anaheim , California
Google "surging Honda 2000i" and you will find several you tube videos on servicing the carb for this exact problem. It's a 15 minute job and will restore a steady idle.
Johnco is offline   Reply With Quote
Generator Surging jking Classic Motorhomes 13 04-11-2011 08:24 PM
Why does my electrical seem like its surging dmcinfo Lights - Interior & Exterior 1 07-08-2010 10:48 PM
Honda 2000i companion + 2000i or just 2 2000i's??? socdiva Generators & Solar Power 5 10-27-2009 02:53 PM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 11:52 AM
Surging Generator Alumi-Naught Mechanics Corner - Engines, Transmission & More... 7 11-14-2006 06:18 PM
