Old 03-01-2019, 05:07 AM   #1
2018 22' Sport
Mt. Tremper , New York
Suitcase solar plug in to onboard solar.
I recently purchased a new 22' Sport FB with factory solar. I have "left over" a Zamp 120 W suitcase solar from my last AS. I have read on this forum that I can plug in my Zamp to the outlet on the battery box but because each array has its own controller the one that is receiving the most light will take over rather than obtaining the benefit of the combined panels. Can I run an "extension cord" from the solar plug-in three way on the roof, by pass the Zamp controller and plug the Zamp into the on board system that way thereby combining the two panels?
Hank
HankStarr is offline   Reply With Quote
Old 03-01-2019, 05:16 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Hank,
Why not try plugging into the 7way, you may be surprised at how well it works. 🤔
ID:	334661   Click image for larger version
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 03-01-2019, 05:46 AM   #3
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Originally Posted by ROBERT CROSS View Post
Hank,
Doesn't the 7-pin plug charging wire go directly to the battery just like the Zamp socket at the battery box? How would this avoid the problem of the two solar charge controllers?
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 06-10-2019, 03:44 PM   #4
2019 23' International
st augustine , Florida
Hank
Did you ever find an answer? I too am wondering if I can just plug into front port and have it work with rooftop panels.
The Boot is offline   Reply With Quote
Old 06-10-2019, 04:18 PM   #5
Dave-n-Janet's Avatar
Moss Point , Mississippi
When I ran a test some months back my 180 watt Zamp portable was additive to the 400 watts on the roof plugging into the front Zamp connector.
Dave-n-Janet is offline   Reply With Quote
Old 06-11-2019, 05:32 AM   #6
thank you
Old 06-11-2019, 08:21 AM   #7
I now use two 180w Zamps. I use a Y SAE harness,(two into one), that connects thru the 7 pin.
The two controllers play well together as long as both are plugged unto the Y and then into the 7 pin. 👍
Previously I set one panel up at a time, the time difference, usually 5-10 min gave a different SOC to the second panel...one at 'full', the other still charging.
W. H. Auden
Amanamus
"Tahawus"
Old 06-11-2019, 10:59 AM   #8
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
Question - when you charge though the 7 pin does the charge go directly to the battery?
I didn't understand the schematics when I looked it up. Looks like it goes through the oem charger.
Mattirs is offline   Reply With Quote
Old 06-11-2019, 11:16 AM   #9
Direct on our '03 Classic.
W. H. Auden
Amanamus
"Tahawus"
Old 06-12-2019, 08:56 AM   #10
2018 22' Sport
suitcase PV add on
Checked with Colonial after my initial question. All you have to do is plug it into the port on the battery box and it adds the suitcase array to the roof top. Couldn't be simpler.
Old 06-12-2019, 09:23 AM   #11
2019 22' Sport
Malibu , California
Will have to ask my dealer about that. Mine is 2019 and was no zamp connector at battery. When I had a 2017 16 there was but it just ran to battery. I had to connect suitcase wires to roof panel in parallel and no controller on suitcase.
Garfish is online now   Reply With Quote
Best 200 W portable suitcase solar setup ??? Milo1952 Electrical - Systems, Generators, Batteries & Solar 17 08-21-2018 09:38 PM
Renogy 100 Watts 12 Volts Monocrystalline Foldable Solar Suitcase Panels jamienate Airstream Classifieds 0 07-01-2018 03:39 PM
Zamp 160 watt portable solar kit (suitcase) dasams Airstream Classifieds 0 09-01-2017 11:28 AM
Using Two Portable Solar Suitcase Panels tjwoods1 Generators & Solar Power 1 08-29-2017 08:58 AM
