Old 11-03-2011, 08:41 PM   #1
2002 25' Safari
1988 25' Excella
1967 20' Globetrotter
Seattle , Washington
Strange noise-Solar?
Every night shortly after sundown I hear a noise from under my sofa. There is a solar panel on my recently purchased 2002 25' safari. Sounds like a fan running back behind the fuse box. Is this normal? Should I worry? Should I take some action?
Martha
2002 Safari 25'A
clemdogmom is offline   Reply With Quote
Old 11-03-2011, 08:48 PM   #2
dznf0g's Avatar
Oswego , Illinois
Sounds like your converter. Are you plugged into shore power when this occurs?
-Rich-
Old 11-03-2011, 08:50 PM   #3
6PackCharlie's Avatar
1995 30' Excella
Logan , New Mexico
Maybe a cooling fan on you power converter?
Charles & Annette
WBCCI # 1407 -- Member 4CU
1995 31' Excella
Dodge 2500 Diesel-Tow Vehicle
___________________________________________
6PackCharlie is offline   Reply With Quote
Old 11-04-2011, 06:10 AM   #4
2002 25' Safari
1988 25' Excella
strange noise - solar?
Yes, I am plugged in to shore power. I assume it is extra power being dumped? Could there be such a thing?
I carry my mobility scooter in the back of my TV, Dodge Durango. When I need to recharge Scooter I run a heavy duty electric cord to the back of the Dodge. I am trying to convince fellow campers that I have an electric power assist car. Now how to link excess solar power into this wild story???
Martha
2002 Safari 25'A
Old 11-04-2011, 07:22 AM   #5
dznf0g's Avatar
Oswego , Illinois
It's the fan on your converter supplying 12 to the trailer systems and keeping the batts topped off.
-Rich-
Old 11-04-2011, 08:05 AM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
I hear my converter cooling fan more when I have more 12 volt accessories. More lights on in the evening? The converter warms up while doing its job and the fan comes on more.
5 meter Langford Nahanni
Help my solar controller caught on fire bmklawt Generators & Solar Power 28 03-24-2016 11:02 AM
Airstream solar pre-wiring compatibility with AM solar robi Electrical - Systems, Generators, Batteries & Solar 6 06-11-2014 09:31 PM
Solar Battery Charger Prewire t7389sg Classic Motorhomes 0 08-18-2011 08:01 AM
Solar Power for Battery Maintenance Tumajin Generators & Solar Power 10 08-12-2011 06:10 AM
How much solar do I really need sgoetz Generators & Solar Power 12 05-19-2011 08:28 AM
