Old 10-05-2011, 09:10 PM   #1
2011 25' FB Flying Cloud
chalk hill , Pennsylvania
Solar system questions
Considering buying an 87 Excella and it has a solar charging system, but the owners passed away and there's no one to explain how it works. There are 4 solar panels on the roof and a magnun energy control box with 2 meters. Under the cabinet behind the control box are 2 other boxes, one with 3 on off toggle switches and another box behind it with 2 positive and 2 negative wires connected to it. There are 2 AGM betteries. Can anyone explain how this works?
thanks,
Dave
"I've got the fever and the only cure's an airstream"
ID:	141842   Click image for larger version
Getahobby is offline   Reply With Quote
Old 10-05-2011, 09:43 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Well, the black controls are for a Magnum Energy inverter-charger. They're still in business and you can find instructions on their web site for those or at least for similar successor products. Magnum Energy make an excellent product.
No telling what the switches do without taking off the cover and observing the wiring and poking around with a tester.
The voltage and amperage meters may be wired any of a number of ways so it's hard to say exactly what they measure. Probably battery voltage for the voltmeter. Ammeter might be wired to show solar panel charge rate or it might show something else, or be controlled by the switches.
Airstream solar pre-wiring compatibility with AM solar robi Electrical - Systems, Generators, Batteries & Solar 6 06-11-2014 09:31 PM
Worth $2600 for the Airstream solar system? scubadog Generators & Solar Power 22 10-14-2012 09:35 AM
Questions on solar system on 390XL jwitwer Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 09-26-2011 09:55 AM
Solar Power for Battery Maintenance Tumajin Generators & Solar Power 10 08-12-2011 06:10 AM
How much solar do I really need sgoetz Generators & Solar Power 12 05-19-2011 08:28 AM
