01-16-2020, 08:29 PM
#801
2017 23' Flying Cloud
Parker
Ronnie, which components of your system hookup to victronconnect? Does your multiplus connect via a Bluetooth? To upgrade the firmware, they say with new models use the victronconnect not VEFlash...
Troutboy
01-16-2020, 09:17 PM
#802
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Rich,
There are a couple of different ways to connect to the system.
One is the VE. bus Smart Dongle for the MultiPlus.
https://battlebornbatteries.com/shop...-smart-dongle/
I don’t have one of these yet...
Or over WiFi with a USB WiFi module
https://shop.pkys.com/Victron-Energy...le_p_6689.html
I use this when I have WiFi.
I also took my set up a step further. I have a WiFi Ranger Converge Denali System with an Internal Router. I have my ColorGX monitor connected to this internal router via a LAN cable. This allows me to connect to my internal router and get my setting via the Victron Connect app on my phone even if I don’t have internet. Works like Bluetooth with more range.
Hope that’s not two confusing and helps a little.
01-16-2020, 09:55 PM
#803
Parker
Thanks Ronnie, it makes sense. So question, the smart dongle seems to let you control the multi via Bluetooth. Can you update the multi firmware via this then, or would you still need to use VEFlash?
Troutboy
01-17-2020, 05:04 AM
#804
Overkill Specialist
Dadeville
, Alabama
I “think” the only way to update the Multis Firm ware is with the MK3 adaptor andeither the VE. Configure tool or VE. Connect.
https://www.victronenergy.com/access...erface-mk3-usb
EDIT NEVERMINDEDIT
I just found this. See photo.
01-17-2020, 05:56 AM
#805
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Originally Posted by wulfraat
In theory... in practice it probably doesn’t matter and with an RV you won’t see any issues with 100% charge cycles for a many years and many many many cycles. Hence the recommendation to cycle to 100% [emoji4] Victron will tell you (and has told me) the same thing.
... in case you were wondering why he made that comment
Hi
The other part of this is that there are likely *other* things that will come up over the next 20 years or so that impact your batteries. With a "normal" RV usage profile, you are not going to hit a high cycle count in that period. Even with charge this or that way, again you likely will not hit that limit either. In this case, the issue is not what you do know but what you don't know.
01-18-2020, 07:09 AM
#806
Wolfwhistle
Margaritaville
, Banana Republic
The confusion with LFP, IMO, is marketing hype and the accompanying drivel. Actually, you can pretty much pick the subject and the same thing occurs. I now have a pair of 170Ah Renogy LFPs, because of weight concerns, inside location, and the quick charging cycle. I've heard, LFP state of charge should not be left or kept at 100%... 80% is better. Does anyone have charger that while working with BMS can do this; I've not seen one. I am happy with the TM-2030 and really impressed with the $40 AiLi meter (with shunt) in the cargo conversion. My days of serving technology (rather than being served) and tinkering with software / firmware updates and figuring out how to convince "smart" devices to get along, are over.
WW
Is taking it all with you, really getting away from it all?
01-18-2020, 08:04 AM
#807
Parker
Like it Clint KISS - keep it simple stupid... unfortunately for me I have an early adopter disease. When I first thought about solar, I designed a very similar system with the trmetric, and some stout batteries, all for less than $1800. Then I found victron, lithium, and all the tech that comes with it. $8k later, and here I am...... I actually downsized my trailer purchase from a 25 to. 23D to buy the expensive solar setup. In the end it’s worked for us. That was three years ago. The system has been flawless. I just finally did the upgrade stuff, but that’s because I’m OCD. I didn’t need to touch a thing,,,,, plus I never would have met all the great people in the 23 club, lol
Troutboy
01-19-2020, 05:58 AM
#808
Wolfwhistle
Margaritaville
, Banana Republic
T, I second your opinion of the 23 clubs, both the D/CBers and the FBers. These forums are the best and attract nice folks. I still don't know why they let me in.
Clint
01-19-2020, 06:20 AM
#809
Overkill Specialist
Dadeville
, Alabama
Clint
Clint,
It was a very close vote
Love you brother..
01-20-2020, 02:32 PM
#810
Wolfwhistle
Margaritaville
, Banana Republic
I knew that $20 I slipped you was well spent
01-20-2020, 10:33 PM
#811
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Solar Show and Tell
I do a fair amount of solo traveling and use my VW Golf if the trips are long/short. I have equipped it with an Alpicool 35 liter fridge powered by a Battleborn 100 Ah battery and connected to a Renogy 100 watt compact panel and a Victron 75/15 solar controller.
I power the fridge from the Golf battery when I am driving and from the lithium BB battery when the car is parked. It works fine so far. I generally use more power than I can get from the solar panel but with lithium I have plenty of capacity as I am never gone more than 5 days.
Dan
01-22-2020, 08:00 AM
#812
Wolfwhistle
Margaritaville
, Banana Republic
Dan Attachment 359547Attachment 359548Attachment 359549Attachment 359551
Interesting TD. I wonder if you also charge the LFP from the VW? That would take a DC/DC converter I assume. And, why you wouldn't mount a PV to a roof rack? Then run the fridge and any other 12 accessory from the LFP all the time? Last question, how does the Alpicool perform?
WW
01-22-2020, 11:15 AM
#813
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Solar Show and Tell
WW
Wolfwhistle- My car is a 2015 Golf 1.8 turbo, regular fuel.
I like simple. I could mount it on a rack but I don’t need to. I have plenty of power for my fridge. I was in south Florida last week and had to take about 100 Wh from the BB each day, but I have 1,300 Wh in the BB to start from so no problem.
Yup I could charge the BB from my Golf while driving but then need a DC/DC converter plus wiring. I don’t need it.
The 35L Alpicool is fantastic. I caught it on sale from Amazon for $237. I like it more than my high dollar Dometic 65 qt that stays in my Tundra now. I will be writing a review. When the thermostat is set on 28 the temperature at the bottom of the fridge is 31.5, 36.5 at the top for an average fridge temperature of 34. I like my beer cold.
Dan
01-22-2020, 11:52 AM
#814
2018 27' Globetrotter
Apollo Beach
Beer? I thought someone from Lynchburg, TN would be consuming whisky.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
01-22-2020, 11:55 AM
#815
Overkill Specialist
Dadeville
, Alabama
Ummmmm. That’s Miller HighLife. That’s Champagne
01-22-2020, 12:32 PM
#816
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
AirMiles and GMFL- We live in Lynchburg, Va. My kids all laugh at me because I like an inexpensive beer. They would never be caught drinking Miller HighLife.
Dan
01-23-2020, 06:24 AM
#817
Wolfwhistle
Margaritaville
, Banana Republic
Dan
Frankly all the choices you see confuses me. Pumpkin for example is great in pies, horrible flavor for beer. My favorite is called "on sale".
WW
01-23-2020, 02:49 PM
#818
Overkill Specialist
Dadeville
, Alabama
All the major components are in for the LongLongHoneymoon Install. Going the be a lot of fun working with Sean and Kristy.
400Ah of BattleBorn Lithium
Victron MultiPlus 12/3000
Victron ColorGX monitor
Victron 712BMV
Victron MPPT 100/50 solar Controller
(4) Renogy Eclipse 100 watt panels
Renogy 60A DC-DC Charger
Progress Industries HW30C
BlueSea disconnects
Fuses
and all the other cables, wires, and connectors
01-23-2020, 06:08 PM
#819
2017 30' International
Broomfield
Christmas two months in a row!
01-23-2020, 06:32 PM
#820
2004 28' Classic
Monument
No fair! We are all jealous!!
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
