07-05-2010, 05:57 PM
2010 27' FB Classic
FTW
Don't know if this is what you are looking for but I bought one of these a few weeks ago.
Valtera Fridge Cool Solar Fridge Vent Fan. Model Fridgemate-A10-2900VP
www.valterra.com
I think I bought it thru Amazon. Camping World is completely out of them.
07-05-2010, 07:15 PM
1974 27' Overlander
1977 24' Argosy 24
Jeromesville
, Ohio
Yeah, I saw those in my web searching earlier today. Where do you mount that? Down at the bottom of the column so that it blow air upward? At the top so it draws air out? Either way, what did you screw it to and how big is the fan (diameter)? I know from just having replaced my fridge that there's not much room back there. I was looking more for the self-container roof mount style as a result.
07-05-2010, 08:13 PM
2010 27' FB Classic
FTW
The instructions show the fan mounted above the coil in the back of the fridge. I don't think I would be able to put it that high behind the fridge so I would mount mine lower but have it blow air up toward the coil and out the roof vent. The fan measures 3" dia.
The solar panel for it measures 5'L x2 1/4"w x 1/4"h. and mounts on the top of the trailer or fridge vent.
It runs independantly and draws no power from the trailer batteries at all. I will add a on/off switch to mine so that when the trailer is in storage the sun is not running the fan while the fridge is not in use.
2 thin wires run from the solar panel to the fan thru the fridge vent.
Valterra says that this fan will increase the efficiency up to 40% and it's quiet.
I think that anything that moves air over the coil and out the vent will help the fridge work well in the hottest weather.
I have no idea which fan is better, or easier to install, or which would last longer.
I just went with simple, and less cost and the Valterra name brand.
Let us know how you make out with your project.
07-05-2010, 09:46 PM
1993 30' Excella
Lakeland
Originally Posted by atobols
Someone made a good point in another forum. A solar fan is great except when you are parked in the shade, as many do on these hot days, then it's useless. The drain on a 4" fan usually is only .2 amps and if your battery can't take that then you probably need a new one. Valterra also makes a 12 volt that has a temp sensor with a shut off switch for it.
I'm ordering one for my 76 to help it cool better.
07-06-2010, 07:18 AM
1974 27' Overlander
1977 24' Argosy 24
Jeromesville
, Ohio
I guess my persepctive is complete opposite of that. If I can find shade to park in, then my fridge doesn't need auxiliary cooling, thus I don't need the fan. If it's hot out then there's a pretty good chance the sun is a blazin'. So, the fan only runs when it really needs to and the very thing (the sun) that's making it hard for my fridge to keep cool now helps the fan run.
And it's a green option. Even that small current draw for a battery powered fan has to be replenished somehow and that's going to be via shore power, generator, or the tow vehicle. None of which would be as green as solar.
07-06-2010, 07:57 AM
2010 27' FB Classic
FTW
Correction to post #4 above:
I said that the solar panel measures 5' long, I meant 5" long.
Sorry 'bout that!
| Thread Tools |
| Display Modes |
