Old 12-19-2017, 09:00 PM   #1
1973 31' Sovereign
Richmond , Virginia
Solar recommendations?!
Hey folks!
Iím looking for a recommendation from those who have gone before me.
Weíre renovating a 73 sovereign and plan on doing a lot of dry camping on public lands. We want to be as self sufficient as possible. We wonít be using microwave but will have a small fridge. And other results electronics like charging phones and computers, running vent fans, etc.
Iím looking for a 400+watt system I can install and donít know whether to go with lead acid or lithium. We did a camper van last year and I used 3 deep cycle lead acid and two 100 watt renology panels.
Does anyone have brands or systems they recommend? Looking to keep it around a budget of $2,000
Thanks!
Arlene2 is offline   Reply With Quote
Old 12-20-2017, 01:18 AM   #2
2015 30' Classic
Pleasanton , California
Your budget precludes lithium. But 400 W sounds like a good target. Victron and Bluesky make great MPPT controllers. Grape (AM Solar) and Renology make good panels. I highly recommend a battery monitor. Check out AM Solar for everything. If you go with Renology, shop on Amazon or eBay.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 12-20-2017, 02:16 AM   #3
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Of the "Renogy" panels to buy, I would go with the Eclipse which are back in stock at Renogy and nit usually available on Amazon. That's usually the cheaper panels.
Basically going to do the same system myself. Already have the TV2030 controller and TM2030 integrated monitor from Bogart Engineering wired in.
George
gandttimes is offline   Reply With Quote
Old 12-22-2017, 05:45 PM   #4
2018 22' Sport
Chino Hills , California
Solar parts
I just install a solar set up on my new 2018 Sport. The dealer wanted
$1500 for very basic solar set up. I ended up getting 2 100 w GrapeSolar panels for homedepot on sale for $100 each, a Victron MPPT 100/30 SmartSolar controller for $200. With the cost of some misc items like wire, panel feet, 3m tape and sealant, I spent about $600.
I still using my factory battery but will be swapping it out for 2 6v golf cart batteries. Thats about another $300 or so.
Gape solar has great customer service which I called several times. Victron is just fool proof and my unit has build in bluetooth which makes it very easy to monitor and setup. After doing the research, setting up the solar equipment was very easy and I'm glad I didn't pay the dealer $1500.
Good luck and I hope you enjoy your solar system when its done. I know I do.
Andrew
roadkill367 is offline   Reply With Quote
Old 12-22-2017, 07:52 PM   #5
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Andrew
A setup like this with 2x100ah battle born lithium batteries would just crack $2000. Very close to the OP's budget.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 12-23-2017, 06:56 AM   #6
dmbecke's Avatar
2014 25' FB Flying Cloud
Des Peres , Missouri
George
When you install your new monitors do you keep the airstream monitor connected?
dmbecke is offline   Reply With Quote
Old 12-23-2017, 12:00 PM   #7
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Yes. My micropulse didn't work from square one and Airstream paid my dealer to install the See Level , but there is no interference in connecting the TM2030.
Old 01-15-2018, 06:50 PM   #8
1972 23' Safari
Middletown , Rhode Island
You mean crack just $1000.
Mx468 is offline   Reply With Quote
Old 01-15-2018, 06:58 PM   #9
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
If you steal a battery...
https://battlebornbatteries.com/shop...cycle-battery/
Old 01-16-2018, 04:20 PM   #10
1972 23' Safari
Your right ROADKILL was referring to 6volt golf batteries in his post not lithiums, my bad, doh!
Old 02-12-2018, 09:44 PM   #11
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Andrew
Thanks Andrew!
Based on your post I snagged 2 Grape panels from HD and a Victron 15 amp smart solar controller from Amazon for $130. I will probably set these up as portable units. What do recommend for wiring?
Dan
Old 02-13-2018, 12:17 PM   #12
2018 22' Sport
Originally Posted by TouringDan View Post
Thanks Andrew!
Dan
Hello Dan
I glad to see that my post was helpful. I'm not sure what you are referring to as far as wiring goes. I'll include a link to my YouTube video I posted for my solar panel project and hope that might help you.
If you are going portable with your panels then I guess you will be hooking them up to the Zamp connector by the batteries (that's if your trailer is prewired with Zamp connectors). If so, then you will need to buy an adaptor so you can connect the Grape panels to the zamp plug. You can get the adaptor on Amazon for $5.00. As for the wire, it depends on how far you plan on placing the panels. So if not too far then 10 gauge would be fine but if any distance then I would go with 8 gauge. You could just buy a set of solar panel extension cable wires and the adaptor and you would be set to go. I'll include the amazon link to both products I used.
Links to amazon.
I hope I made sense and this helps you out.
Old 02-14-2018, 07:22 AM   #13
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
I run 10 gauge wire for my 30ft run with my 200 watts of portable panels. 10 gauge is still flexible enough to easily handle and the voltage drop is well with bounds. If you go 50ft you might want to go 8 gauge.
The critical distance vs wire gauge is between the controller and the battery. Low is better there, short run with a low gauge wire.
Mattirs is offline   Reply With Quote
Old 02-14-2018, 07:35 AM   #14
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
A single 100ah lithium battery ranges from $850-$1,500. If you want a 400w lithium setup as you describe I would say your looking at the 5-10k range. Depending on if you are going to do it yourself, or have someone install it.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Solar installer recommendations Breezinalong Electrical - Systems, Generators, Batteries & Solar 4 10-26-2016 12:24 PM
Recommendations for Solar Panel for Argosy / Classic Motorhome Belle Classic Motorhomes 7 01-09-2016 01:08 PM
Solar recommendations Nomadic1 Boondocking 3 06-21-2013 06:48 AM
#2 attempt--any recommendations for a solar charger? Kistler Generators & Solar Power 6 02-16-2005 08:01 AM
Best Solar Panel recommendations please! westeagle Generators & Solar Power 2 11-16-2003 12:31 PM
