Old 03-24-2015, 07:35 PM   #21
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Originally Posted by dznf0g View Post
Careful though. Many of the charge ports in modern vehicles are ignition controlled and are an "open circuit" without the key on. My current truck has 4. two are hot all the time and 2 are ignition controlled.
Thank you, well aware of that. My Jeep GC has three 12 volt plugs and two 120 volt AC plugs. They only work when the Jeep is running. Bit of a nuisance.
MICHAEL
Old 03-25-2015, 08:26 AM   #22
dznf0g's Avatar
Oswego , Illinois
I like the choice. I only want items like my dash cam and rear view camera to power up when ignition is turned on. Since I still am using company trucks as TVs, I can't hardwire anything.
-Rich-
Airstream solar pre-wiring compatibility with AM solar robi Electrical - Systems, Generators, Batteries & Solar 6 06-11-2014 10:31 PM
Solar Install AM Solar outdoors717 Generators & Solar Power 3 07-15-2012 08:11 PM
a solar question JohnnieWinon Generators & Solar Power 35 10-29-2006 02:04 AM
Solar Charging System Question Mod-Streamer Generators & Solar Power 1 01-16-2006 11:33 PM
