Old 04-29-2016, 06:34 AM   #15
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by gandttimes View Post
Lewster, I'm sure that I'm not the only one who would be interested in hearing about your test on the new flex panels from Grape.
It won't happen for a few weeks as I'm in packing mode for my trip back to Oregon and depart Sunday. I should arrive in OR around the 15th of May, and will hopefully get set up with enough time before my first scheduled installation to get the new panels up on the roof for a test.
Old 04-29-2016, 06:58 AM   #16
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Solar Price question?
Originally Posted by BoldAdventure View Post
I post what I post.
It is not that I care about that comment, (It does not bother me, I think you were making a joke), for all I know it might be true, (or not), but there is a fine line that if perceived to be crossed, can get a person a summons to civil court.
Careful!!
Simple Definition of LIBEL
: the act of publishing a false statement that causes people to have a bad opinion of someone.
Superat stultitia.
Old 04-29-2016, 08:41 AM   #17
JJ1
2009 23' International
Redondo Beach , California
Thanks for the advice all! I thought it seemed like a high price as well, but I just don't have enough solar knowledge. Clearly more research needed on my end.
Thanks again!
JJ1 is offline   Reply With Quote
Old 04-29-2016, 08:45 AM   #18
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Other than a 200w Zamp Portable system I'm new to solar. Just ordered AmSolar 100w Deluxe package plus a 2nd SF100 panel and tilt bars. $12 shipping is good considering its almost 70lbs.
I'm planning on modifying the Zamp portable panels so I can connect them into the trailers roof solar.
Kelvin
Old 04-29-2016, 01:59 PM   #19
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Perfect timing. By the way, is the flex panel on their website the new one or the old one.
gandttimes is offline   Reply With Quote
Old 04-29-2016, 03:32 PM   #20
lewster's Avatar
I would think the new one but you might call them to confirm.
Lew Farber
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
Old 04-29-2016, 04:26 PM   #21
2016 23' International
Salem , Oregon
For a trailer, would not a person be better off with the Zamp 200 watt portable and possible a second 100 or 200 watt panel without a controller on the second panel.
The problem I see is that many state parks, and other sites are in the shade. You can move the panels, but no place to put the RV in the sun.
Look like a lot of expense for all the trouble of installing on roof unless you live in Florida, or Arizona.
I am in Oregon, need rain powered panels.
Dave
NoResults is offline   Reply With Quote
Old 04-29-2016, 04:44 PM   #22
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Lew Farber
541-490-6357
No confirmation but apparently up here in Canada where they may make them, the only source is Amazon.ca and they want,you'd better sit down, $432/ panel. WOW!
That's No Power territory.
Old 04-29-2016, 06:21 PM   #23
lewster's Avatar
WOW is right!!
I would check with Grape Solar in Eugene, OR to see if they are/will be available in the US. I'll check with my 'sources' as well.
Old 04-30-2016, 12:03 AM   #24
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Thanks Lew.
Old 04-30-2016, 03:44 AM   #25
54 Flying Cloud
KrisE MN's Avatar
1967 20' Globetrotter
1954 22' Flying Cloud
Grand Rapids , Minnesota
Isn't that like $125.00 US dollars?
KrisE MN is offline   Reply With Quote
Old 04-30-2016, 04:40 AM   #26
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We were able to install five 100 watt solar panels on our 2015 23D International Serenity roof by removing the Winegard crackup television antenna and replacing it with the WineGard auto tuning television antenna. They are charging a 12Vdc 300 amp-hour lithium battery (14" x 16" at 84 pounds) that weighs less than the two stock Interstate batteries and is installed under the sofa just in front of the plastic wheel well. The Magnum MSH-3012 inverter is mounted immediately forward of the furnace along with a new main 30 amp breaker panel and an automatic transfer switch attached to the new 120Vac power inlet on the front of the trailer.
Solar panels have a sales power rating baed upon a laboratory test environment. The reality is about 75% of that rating is real world capability. Thus our 500 watt literature rating could make 375 watts on a good day.
Running the furnace over night in cold weather can use 55 to 60 amps. Since each panel we have is capable of 5.5 amps, the five could generate 27.5 amps. So we are looking at at least two to three hours of sunshine to recover just the power the furnace used. A single 100 watt panel would need at least ten hours to recover the battery power ups in one night. Also, only lithium batteries will allow about 85 to 90% use of the amp-hour power rating. All other batteries are limited to 50% or less of their amp-hour rating.
The so-called "free solar power" party has a real expensive admission ticket. So lots of research before signing a purchase agreement will be time well spent. As mentioned above, AM Solar is a good source and has an excellent solar primer to help bring the novice up to speed on the terminology and concepts involved.
http://www.amsolarrv.com/rveducation/
Both the 23D 300 watt solar system and the 800 watt solar system on our 31' Classic were sourced from AM Solar.
Old 04-30-2016, 09:39 AM   #27
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Or less😆
Old 04-30-2016, 10:59 AM   #28
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
For what it is worth I have 480 watts of go power hard panels on my roof and a 30A go power controller. They work well for me. Just added a go power 1500 watt pure sine wave inverter hard wired into my electrical panel (enabling all 110v outlets in the trailer with the exception of the fridge and AC.
When I was shopping for the inverter the go power was a bit cheaper than the magnum, and draws less amps when idol.
Maybe I overpaid for the panels. Hindsight is always 20/20. Oh well.
When I upgrade to lithium in the next couple years I will definitely look to AM solar.
wulfraat is offline   Reply With Quote
Airstream solar pre-wiring compatibility with AM solar robi Electrical - Systems, Generators, Batteries & Solar 6 06-11-2014 09:31 PM
AIRSTREAM 2004-34 ft-EXCELLA- PRICE REDUCED- QUEEN-BED.-DINETTE-SOLAR-.FLORIDA eBay Watch Airstreams on eBay 0 06-11-2013 03:20 PM
AIRSTREAM 2004-34 ft-EXCELLA- PRICE REDUCED- QUEEN-BED.-DINETTE-SOLAR-.FLORIDA eBay Watch Airstreams on eBay 0 04-20-2013 05:30 PM
Price Paid to Price Asked BillWill Trailer Values 46 08-11-2009 05:03 PM
