Old 11-21-2010, 03:01 PM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Solar pre wire
In the process of wiring my 65 Ambie.What should I run for future solar before I put the inside skins on.I assume 6 or 8 ga. but how much? My plan is to use a ladder support that mounts in the 4 holes on the TV pickup bed to mount the panels which could be stored when not traveling.
bwaysteve is offline   Reply With Quote
Old 11-21-2010, 03:07 PM   #2
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
How many watts are you going to put?
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 11-21-2010, 03:17 PM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
and how far from where battery is located?
Where do you store safely between uses?
Old 11-21-2010, 03:23 PM   #4
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Hey Dave,
Batteries will be between rear and last axle.I can put the TV anywhere.I would think 200-300 watts.All lights are led will probably have Microwave as largest Item.Plan on stereo,LCD TV,Laptop.
I would store in my Barn covered.
Old 11-21-2010, 03:55 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
Steve,
Just as a point of reference, we at AM Solar use 6AWG wire now to connect the panels (we use a combiner box at the roof) to the charge controller, and then the controller to the batteries. This is good for systems up to 400 watts in the solar array. We now use 4AWG for larger systems up to 1200 watts.
Let me know if you have any other questions.
Old 11-21-2010, 05:18 PM   #6
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
prewire
Originally Posted by lewster View Post
Steve,
Thanks Lewster.Have your site bookmarked and plan to have you do an install.( will give me an excuse to visit your state.)How much 4g should I run before I button up the panels?1 run,Two?
Old 11-21-2010, 06:49 PM   #7
lewster's Avatar
Never hurts to have too much wire!
You will need one pair for the run up the fridge cavity and out onto the roof that will connect the solar array to the charge controller and one from the controller to the batteries. Best to leave extra length coiled up for each run at both ends.
As a German buddy of mine says (he installs hi-tech wiring in custom homes) " vire ist cheap....labor ist not!". You sure don't want to be a little short on any of the runs, as any connectors or splices have the potential for voltage drop.
While you're at it, it would make for a really easy (and quicker) installation if you got the voltage sense probe and the battery temperature sense probe NOW from AM Solar and ran them from your intended battery location to the intended charge controller location along with the battery charge line.
Old 11-21-2010, 07:06 PM   #8
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Thanks,I will call you after Thanksgiving to get the specifics on this.Steve
Solar pre-wire on a 2005 19' Bambi CCD JDL Generators & Solar Power 23 12-22-2010 05:50 AM
Solar Pre-wire 2008 Safari 25 FB SE - Good enough? eheffa Generators & Solar Power 3 10-23-2009 10:30 AM
Pre-wire in 27FB gowyn Audio, Video & TV 3 05-28-2008 11:32 PM
Pre wire in 28 International CCD rnhunter Audio, Video & TV 2 12-01-2007 02:23 PM
Pre wire in 2006 23" Safari Zugbug Audio, Video & TV 1 08-29-2007 10:51 AM
