Old 12-31-2008, 11:47 AM   #1
safari25-05's Avatar
summerfield , Florida
solar power use while towing...
I have a solar panel with solar controller, Sunsei claims you do not have to disconnect the solar system while using the charge line from tow vehicle while towing. However.. Sunforce solar company, warns you to disconnect the solar system while towing using the charge line on the vehicle, or the converter at the campsite for safety reasons. What do all you solar guys do out there? I want to add my 2¢ here, because of the delicate electronics in the solar controller it would seem to me a wise idea to disconnect the solar system from the battery while the other systems are in use, either the vehicle to tow or the converter at the campsite. Appreciate any feedback..
safari25-05 is offline   Reply With Quote
Old 12-31-2008, 12:07 PM   #2
A good solar system would have a diode on the output.
That would prevent the system from any exterior source of power damage.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-31-2008, 12:33 PM   #3
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I too have the Sunsei ("Solarcharger") and it says, as you say, not to disconnect. Even the most irresponsible company would have to guard against this kind of problem or they would quickly be out of business from warranty claims. It's best to ask because who would think people would be so irresponsible as to put melamine in milk.
Gene
Old 01-01-2009, 10:11 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
The factory solar system on our 06 Bambi is "connected" all the time...however the controller will not allow over charge of the batteries and there is no adverse effect to the solar system while on shore power or through tow vehicle charging.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 01-02-2009, 07:29 PM   #5
Stray
1987 32' Excella
1978 28' Argosy 28
Springfield , Missouri
I have used by solar system 4-5 years and have never disconnected it when towing or under shore power. I have had no problems whatsoever. This appears consistent with what Andy is saying.
Stray
nohillgrish is offline   Reply With Quote
Newbie Solar Power Question Toronto_Guy Generators & Solar Power 4 09-03-2008 07:25 PM
Grease burning diesel and solar power LucyPepper Modifications 1 03-23-2008 03:49 PM
Solar power capacity? ldetsf Generators & Solar Power 22 03-10-2007 08:01 PM
Airstream vrs. Go Power Solar Kit jglase Generators & Solar Power 0 09-13-2006 08:05 AM
towing and the Banks Power Pack kooblekidz Airstream Motorhome Forums 11 10-31-2002 12:09 AM
