Old 08-21-2012, 10:50 AM   #1
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
Solar power funky idea
Just waxed "Tinbad" and am getting ready to finish the replacement of the plastic chrome trim between lower panels and banana wrap when I remembered that I had removed my body panel rock guards to clean and wax.
Then recalled all the dings in the guards.
Yes, I'm leading up to something so bear with me.
I've always wanted to add solar charging to the trailer so I'm just going to throw this out there for critique.
First I'm going to Rhino the guards outside....probably in black is I've seen pics of others and it looked ok.
Next revise the hinge system for quick removal (the trailer looks cleaner when they're not on.
HERE is The BIG QUESTION:
I would like to consider adhering solar panels to the curved inside of the guards and have a quick connect system and separate "stands" made so I could place them for best effect facing the sun.
I've seen ad's for flexible solar collectors and I'm not too keen on drilling holes in the roof for the standard set up.
The "surface area" looks close if considering both guards used.
In my current situation I would need to run 25' of wire to the outside of the barn (voltage drop?)
What do you think?
Del
Del Gurney is offline   Reply With Quote
Old 08-21-2012, 11:41 AM   #2
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
right on, del!
Placing the collectors on the roof is a compromise; having separate collectors requires a place to store them-pita. What you have suggested is brilliant! I think you should do it; I think Airstream should do it; I think AM Solar ought to do it. I think I will do it. sheez, that is a GOOD idea. Yes, I know the rock guards take a beating, but with the addition of the Rhino Lining, rock impact will be reduced; plus an air gap between the guard and the actual P-V Cells will prevent any damage; the approximate shape will NOT be perfect but will still concentrate rays; if in direct sun, they can be moved to eliminate overheating; if in low sun they can be moved to increase exposure. ZampSolar is the outfit that makes portable collectors, so perhaps they're the ones to contact. (Power to Explore! | Zamp Solar). The wiring can be via a plug or a "drop light" type of reel, or whatever form you wish it to take; controller can be mounted up around the tongue/batteries or wherever most convienient. I think this is a great idea!
wmarsha is offline   Reply With Quote
Old 08-21-2012, 11:52 AM   #3
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I get that my rooftop solar installation might not always be getting the best sun for most power generation. But keep in mind you're out camping, trying to relax, so I'd suggest avoiding the temptation to keep moving around your portable panels to get the best sun. At some point it'll stop being fun.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 08-21-2012, 12:10 PM   #4
Del Gurney's Avatar
1965 26' Overlander
Thank you both for your replies.
I'm just thinking about it so far and realize I'll need to do some more investigation as there may as yet be pit falls I can't see.
In my situation, I'm a full-timer with a trailer in a barn with full sun exposure on south side so placing on the roof at this time would be fruitless.....I need something movable, compact and un-obtrusive.
Anyone else have comment on the more technical (electric) aspects of this idea....I think I've got the mechanics of hinge/stand worked out.
Old 08-21-2012, 02:11 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I have an 85 watt portable solar panel that I plug in to a receptacle on my trailer. While it does take some effort on my part to set up. I feel it is worth it.
During our last 10 day dry camping trip I might have spent 20 minutes out of the day changing the position of the panel to get optimum sun exposure. It resulted in the full 10 day stay using only 1 group 24 lead acid battery and never having even a low battery, not to mention a dead one.
While somewhat conservative on power usage, we didn't feel we were deprived. We watched a few movies on the TV, used the water pump and lights as though we were on shore power. Even ran the 120 volt electric vacuum cleaner at least every other day.
I had been considering a generator, and will still look at one if we need A/C. But at this time I don't see the need.
We are headed out on a 3 week trip soon, about half of it will be dry camping. Still plan on using the solar panel and 1 battery.
I don't think I spend any more time with the solar panel than one would with a generator. Beside the panel doesn't use any gas or oil.
Oh! One other thing. The solar panel dB output is 0 at any distance.
The panels are supposed to be designed for outdoor use, meaning rain, snow, hail etc. So they should stand up to somewhat of a beating.
I think your idea is a great one.
Old 08-21-2012, 06:02 PM   #6
banjobill
wmarsha's Avatar
2000 30' Limited
zampsolar contacted
I have contacted these folks to see what they have to say. I will report back as soon as I know. Now there is another thread asking about solar panels, so this oughta be bumped back on the portal.
Old 08-21-2012, 09:16 PM   #7
mapleton , Utah
With a 25' run you might need some fairly large conductors to avoid undesireable voltage drop. I have seen some professional installs with 4/0 welding cable for runs as short as 10'. If you are not worried about getting the maximum charge, just want to try it out, use what you have. Good luck and be sure to keep us in the loop.
tim
rumrunner is offline   Reply With Quote
Old 08-21-2012, 09:50 PM   #8
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Twinkie
I like the sound of what you have done with your portable 85 watt solar panel. Could you please provide some details.
Thanks, Dan
Old 08-21-2012, 10:04 PM   #9
Del Gurney's Avatar
1965 26' Overlander
Thanks again folks
Thanks again for everyone's input:
To Banjobill: I contacted your source in Everett Wa. and they don't sell flexible panels. In our conversation they did'ent see a problem "right off the bat" other than cost....but offered encouragement saying "this is how progress is made."
Looked into West Marine and they do (I'm a boat guy). So I'll look a bit deeper in to this though it's become obvious it'll be more expensive than a flat panel.
This is more a matter of using the rock guards for more than one purpose and space/weight saving at this point. And no holes in the roof and "possible drag"?
I watched a couple instructional video's today and see that a real pro will be required to ensure I don't make a total ass of myself on this job.
I love "projects" and if I can find a reasonable way to do this I'll provide all details. And if anyone else get's there first please let me follow in your footsteps.
Thanks again
Old 08-22-2012, 09:25 AM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
TouringDan
I bought a single 85 watt solar panel and controller. I built a cover for the panel that is hinged. The cover serves two purposes. One to protect the face of the panel when stored. The other to provide a stand for the panel.
When the cover is folded open to expose the panel to the sun, it looks like a small pup tent. When fully opened the cover holds the panel at about a 55 degree angle. I can adjust the cover from the 55 degree angle down to the point where the panel will lay flat on the ground.
The controller is mounted on the cover and wired to a 15' cord (3 conductor #10 SO type) with a 7 pin plug on the end of the cord. I mounted a 7 pin receptacle in the side of the trailer adjacent to the battery compartment. It is the same 7 pin connector used on the UCord. But only 2 pins are wired. The common/ground pin and the pin for the charge line. I wired the receptacle to the battery and have a 30 amp fuse in the positive wire.
So it is a simple matter of setting up the panel at the right angle and plugging it in to the receptacle on the trailer. When I set the panel up for the morning sun, it is at it's steepest angle, 55 degrees. The sun does not have to be much above the horizon to hit the panel at a straight on shot. As the day progresses I adjust the angle to where by noon or the panel is lying flat on the ground. When the sun has reached it's peak and starts to get lower in the sky I rotate the panel and adjust the angle up as the sun gets lower. I don't use any fancy protractors or device to get the angle perfect. I just stand in front of the panel and use my shadow to adjust the panel left or right and up and down.
At the same time that I wired up the solar panel I wired in an 1100 watt inverter. The meter on the inverter gives me an indication of what the charge level is on the battery. While the inverter is not on continuously I can turn it on momentarily to check the battery voltage.
I do carry a group 27 battery in the back of my truck, just in case there is a need for more ampere hours, such as running the furnace for an extended period. The battery has a male and female 7 pin connector wired to it. With the battery in the truck I can charge it while driving and not towing by plugging it into the receptacle for a 5th wheel trailer inside the box. I can also place the battery next to the trailer and plug it into the same receptacle that the solar panel plugs in using the male connector wired to the battery. At the same time if I choose to use the solar panel, I can plug it in to the female receptacle wired to the battery. Thus charging both batteries.
At this time I carry the panel on one of the twin beds when traveling, I am considering raising the bed platform and making a drawer just below the mattress level to store the panel. But so far the bed storage has worked.
Hope this helps.
Old 08-22-2012, 10:14 AM   #11
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Clever idea. I appreciate the innovative thinking.
One question, though. How vulnerable to damage are the flexible solar panels? Could they be damaged by a rock denting the guard to which they are attached?
Vaughan
Old 08-22-2012, 10:52 AM   #12
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
A couple of points: first, so far as I'm aware, holes in roof are not part of solar install. On mine, for example (AM Solar parts) - a ultra high strength 3m two-sided tape was used to mount the panel feet/standoffs, and I think that's the norm. Scared me when I heard of it, but my trailer's gone many tens of thousands of miles with them up there, with no issues. My reading on this tells me that the surface prep. has to be done right, but that if so it works o.k.
Second, the flexible, amorphous panels have significantly lower output per square meter than monoccrystalline or polycrystalline (rigid) panels ... but on the other hand, that area inside the "segment protectors" is otherwise wasted.
So overall, I think this might be a pretty good idea. I do know that some folks on the Forums have taken amorphous panels and "glued them down" on the roof (I'm not sure how), following the roof curvature. I seem to recall, however, that it works. One big advantage to the on-the-roof position is that the panels are exposed to sunlight and doing their jobs even if the trailer is going down the road and also when in storage.
Intriguing idea. Do, please, keep us posted.
AirsDream is offline   Reply With Quote
Old 08-22-2012, 12:52 PM   #13
2010 27' FB International
La Crescent , Minnesota
This is a very interesting idea. i would like to receive updates.
Thank you,
Jay
mjayjensen is offline   Reply With Quote
Old 08-22-2012, 01:15 PM   #14
jmpratt's Avatar
1969 29' Ambassador
Liberty Township , Ohio
tim
Conductor size is a function current and wire length. For a given conductor size you will have a voltage drop per foot per amp. Figure out what your max current will be then look online at an ampacity chart. Then buy some 10 or 12 gauge wire. 4/0 welding cable is extreme overkill.
jmpratt is offline   Reply With Quote
