Old 04-22-2014, 09:16 PM   #29
Bigcgar's Avatar
2015 25' FB International
2011 23' International
Larkspur , Colorado
SSquared:
Thanks for you feedback, I also connected with Lewster and I am now in a much better position to understand what I'm faced with as I evaluate my options. Lewster recommends upgrading the standard wiring as it will basically support a 100 watt solar panel but if I decide to go up from that I should consider the bigger gauge wire.
Allan & Vicki
Larkspur, CO
Be well, fish on!
Bigcgar is offline   Reply With Quote
Old 04-26-2014, 05:31 AM   #30
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Request
Originally Posted by Gary W Wong View Post
Swift, they are installing 200wats on mine and on a 23' I am sure there are limits to the locations from the standpoint of the airstream layout.
If possible, would you please post a photo of the solar panels after installation. I'm interested in seeing how they are positioned. Thanks
tsunami is offline   Reply With Quote
Old 04-27-2014, 12:07 AM   #31
Gary W Wong's Avatar
Milpitas , California
Name:	ImageUploadedByAirstream Forums1398578484.295757.jpg
ID:	210663Click image for larger version
Name:	ImageUploadedByAirstream Forums1398578495.596180.jpg
ID:	210664Click image for larger version
Name:	ImageUploadedByAirstream Forums1398578504.651052.jpg
ID:	210665Click image for larger version
Name:	ImageUploadedByAirstream Forums1398578522.281620.jpg
ID:	210666Click image for larger version
Name:	ImageUploadedByAirstream Forums1398578534.332871.jpg
ID:	210667Click image for larger version
Name:	ImageUploadedByAirstream Forums1398578559.680794.jpg
Here is the installation photos. They did a great job at the dealership and the panels are riveted to the frame and the the alumn skin with expansion anchors. This is the preferred mounting method by Airstream.
Non shrink seal prevents the weather from penetrating the exterior.
Gary W Wong is offline   Reply With Quote
Old 04-27-2014, 12:17 AM   #32
200 watts (2-100watt zamp solar class A monochrystaline silicon panels mounted on the roof with a 30 amp 5 phase digital PWM solar charge controller.
12.8 amps per hour approximately.
Old 04-27-2014, 01:33 AM   #33
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Not to nit- pick but depending on the way you park in the sun, you are going to get massive shadows from your a/c unit on the panels which will affect your charging ability.
GM
gandttimes is offline   Reply With Quote
Old 04-27-2014, 01:46 AM   #34
Fully understood. I know someone who had their portable solar panels stolen as they are set on the ground. And to save me the time and effort of set up portables, this solution worked the best for me. Majority of the time my International will be parked on the project site as my architectural office. No shadows will be a concern there.
Old 04-27-2014, 07:35 AM   #35
lewster's Avatar
Naples, FL , Hood River, OR
Many other mounting techniques exist to NOT put holes in your roof and NOT position your panels where they will get shaded. I hope that you get the performance you anticipate from your system.
Old 04-27-2014, 09:39 AM   #36
Name:	ImageUploadedByAirstream Forums1398612890.646893.jpg
ID:	210706Click image for larger version
Name:	ImageUploadedByAirstream Forums1398612902.639760.jpg
They did am awesome job preventing any leaks with Airstream recommendations for mounting and sealing the connections.
I don't see a problem with my panel locations for I will be in non shaded construction sites majority of the time.
This will be my architectural mobile office and once in a while on recreation at open rv parks.
Old 06-08-2014, 06:56 PM   #37
Tincampers's Avatar
Sneedville , Tennessee
I am late to the party here, but the shading everyone is referring to is from the A/C unit as shown in your picture not from trees or other buildings.
Tincampers is offline   Reply With Quote
Old 06-08-2014, 08:19 PM   #38
lewster's Avatar
Very true. Narrower 100 watt panels could have been placed further forward so that the panels never saw any shading.
Experience and the use of the right components teaches one the optimal placement for the best exposure. Anyone can install panels on a roof. Not everyone can do it for maximum output.
Old 08-15-2014, 11:16 AM   #39
interstateflyer's Avatar
2017 25' International
Los Osos , California
AM Solar installed two GS-100, 100 watt and one GS-135 panel on a 2012 International 23D. Two 100s lengthwise behind the AC and one 135 crosswise in front.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 08-15-2014, 11:28 PM   #40
I have two factory installed solar panels on my roof. They are hard wired and physically mounted on my roof to the structure.they use non hardening sealant approved by airstream. The two panels sit side to side the width of my airstream and directly behind the air condotioner. We have been boon docking two times and we have run the tv, refrigerator, water heater, DVD player and for half the day on a sunny day we did not run out of juice. Of course we went to bed at 10pm. But next morning we woke at 7am and I check the meter and my batteries were 3/4 charged.
We had our 5 iPhones charging that day and tv running and still
Did not run out.
Works well until probably a less sunny day.
The Zamp solar airstream package works great. I had the factory install it for I did not want to void the warranty.
Old 08-15-2014, 11:30 PM   #41
I have not have shading from my air conditioner yet. I will post a photo
Old 08-15-2014, 11:51 PM   #42
lewster's Avatar
Gary,
Could you elaborate a bit on exactly what a ' 5 phase digital PWM solar charge controller' actually does. That's a new description that I am not familiar with. The '5 phase' is what's throwing me a bit.
Thanks!
2008 AIRSTREAM SAFARI SPORT 17 w/ SOLAR PANELS eBay Watch Airstreams on eBay 0 03-29-2013 02:20 PM
1985 airstream 31ft sovereign travel trailer ,loaded ,solar panels ,mint cond eBay Watch Airstreams on eBay 0 06-14-2012 05:50 PM
1985 31 ft airstream sovereign ,mint condiion ,1 owner ,solar panels loaded eBay Watch Airstreams on eBay 0 11-13-2011 11:30 AM
Solar Panels or Generator? Ron C Generators & Solar Power 7 07-11-2005 11:19 AM
Solar Panels VONZIPPER Generators & Solar Power 7 03-18-2002 07:47 AM
