Old 01-19-2015, 08:00 PM   #1
2014 16' Sport
Walnut Creek , California
Solar panel wiring
Doing business this way is all new to me so please be kind. I have a 2014 -16' Sport and would like to install a solar panel and what I have read in our pamphlet's says the Sport is already wired for solar but I do not know where the wiring is. Help and thank you. Elbo
Elbo is offline   Reply With Quote
Old 01-19-2015, 08:05 PM   #2
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Not to pass the buck, but you might ask your delivering dealer, if you bought it new, or Airstream because from what I know, the answers will vary.
George
gandttimes is offline   Reply With Quote
Old 01-19-2015, 08:48 PM   #3
1974 Argosy 20
Kooskia , Idaho
It should be in the manual somewhere. On my 2014 FC 20' it was mentioned somewhere I know. Probably in the electrical section of the manual.
Mine starts at the front ceiling vent, tucked in behind the vent trim. It terminates (in mine) under the front bed. There are two #10 wires, as I recall one yellow and the other yellow with a green stripe, but memory has faded a bit on the colors.
Old 01-19-2015, 10:42 PM   #4
peetoe's Avatar
2012 25' FB Eddie Bauer
SLC , Utah
I had a 2006 23' and the prewiring was found in the fridge outside acess door. So installing the wire you simply dropped your new solar panel wire down the fridge vent and connected the two up. The other end of the Prewire is at the electrical bus. My 25' I found the pre installed solar wire in the front fantastic fan just remove the inside cover to the vent and there it was. Airstream told me it would be at the rear fan. After searching around I gave up and found it up front.
peetoe is offline   Reply With Quote
Old 01-19-2015, 11:05 PM   #5
2007 22' International CCD
Do keep on mind that the 'pre-wire' is rather smallish wire.
KE4GNK/AE
Old 01-20-2015, 05:21 AM   #6
lewster's Avatar
Naples, FL , Hood River, OR
[QUOTE=rmkrum;1570300]Do keep on mind that the 'pre-wire' is rather smallish wire.
...............and............the solar charge controller should be wired directly to your batteries. This is especially true when you have the limited space found on a 16. You certainly don't want any voltage drop in your system!
Old 01-20-2015, 05:06 PM   #7
Funny bit is that we searched for the top end of the light gauge pre-wire, never found it (book was wrong). So we wisely gave up, ran all new heavy wire from charge controller direct to the batteries. Wire to junction box to panels is also short and heavy.
System charges nicely all the time, displays voltage on the batteries no matter what is going on with use/store switch. Basically came out good in spite of ourselves. AM Solar made a great kit for our AS and had decent instructions. Only stupidity was drilling holes in the roof for mounting feet instead of using tape. Live and learn...
KE4GNK/AE
Airstream solar pre-wiring compatibility with AM solar robi Electrical - Systems, Generators, Batteries & Solar 6 06-11-2014 09:31 PM
Solar Panel Installation 69Overlander Generators & Solar Power 28 03-03-2013 08:18 PM
Solar Install AM Solar outdoors717 Generators & Solar Power 3 07-15-2012 07:11 PM
Help on solar panel installation Les Gilliam Generators & Solar Power 3 11-27-2002 08:28 PM
