Old 04-30-2011, 06:25 PM   #1
Solar Panel Question
We have a Sunexplorer Charge Controller Display kit. Would like to know what the following mean:
  • Solar Charge Amps
  • Solar Amp Hours
Both are staying at zero. When should they show something? Seems our batteries (when not connected to shore power) run down over a few days. We have the battery disconnect on "use" even though we are not using anything (AS in our driveway). Believe I read someone on the forum state that he always leaves his on "use".
Can't figure out if the solar panel is working or not. We have a 2009 International CCD.
Marvin
marvinr is offline   Reply With Quote
Old 04-30-2011, 08:53 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We had this same problem with our unit when we first got it. There was a mis-wiring with the solar panel and just like you, we were not getting a charge. In sun you should have an indication on the charge amp setting that you are receiving a charge. Of course, you also need to determine if it's actually the solar wiring or the monitor itself. (Your posting info does not list your model, but I presume this is a factory solar install). It needs to be checked out...your are not hallucinating that you should see some activity.
TB & Greg and Abbey Schnauzer
#3954
Old 09-20-2011, 04:06 PM   #3
DaCosta's Avatar
2007 22' International CCD
fLUSHING , New York
i have the same problem, did you get it to work and if so how.
DaCosta is offline   Reply With Quote
Solar panel to AS battery hookup question txstreamer Generators & Solar Power 12 04-25-2011 03:32 PM
Roof mount Brackets for Solar Panel Bo2020 Generators & Solar Power 2 04-11-2011 01:20 PM
Solar Power Quandary for my '58 mello mike Generators & Solar Power 7 04-06-2011 08:05 PM
Solar Panel Prices Dropping tbro Generators & Solar Power 11 03-30-2011 08:21 PM
'67 Caravel Restoration Electrical question vonzellen 1966-68 Caravel 1 01-15-2011 07:25 AM
