Old 11-01-2014, 07:52 PM   #1
2014 16' Sport
Sheboygan , Wisconsin
Solar Panel Mounting Considerations - 2014 Sport 16
Would appreciate your opinion regarding installation of a solar panel. Not a lot of available space so probably am looking at a 50 watt panel. Given the estimated cost from the factory of $1000 plus, would this be a wise investment?
Marty
Born2kayak is offline   Reply With Quote
Old 11-01-2014, 08:15 PM   #2
ottawa (greely) , Ontario
I wouldn't go with factory system, due to the charge controller is not very good it's not a mppt charge controller and doesn't have a battery equalizing function, and the solar panel from airstream is too expensive , yes your right you can put a panel aprox 50-60 watts just to the left side of the a.c( street side) a very good charge controller is sold by midnite solar called the kid, and for solar panels check out northern Arizona solar web site.
Don ( freely Ontario Canada)
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 12-27-2014, 05:18 PM   #3
2017 25' International
2014 16' Sport
Cardiff , California
Hey Marty, I have a sport 16 too. I have been doing some research and am leaning toward the Go power solar flex 100w. (About $600)The panel is flexible and measures 21" by 41". I have not put a ladder up yet but I'm thinking it should fit on our tiny roof. I'd be interested to hear if anyone has had success with theses panels. Looks like you can use adhesive to install (no screws!) and our sport 16 is pre wired so the install may not be too bad.Solar Flex Kits and Modules (Flat, bendable solar) | GPElectric
A Do-it-Yourself Airstream Solar Installation with Go Power! Solar Flex Panels | The Snowmads
armstrs is offline   Reply With Quote
Old 01-13-2015, 12:29 AM   #4
ODSCS's Avatar
2013 22' FB Sport
Seal Rock , Oregon
Images: 8
I've been looking at www.amsolar.com out here in Oregon. They seem to be very knowledgable about RV solar and installations.
ODSCS is offline   Reply With Quote
Old 01-13-2015, 12:46 AM   #5
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Have a look at Renogy. Also have a read of " handy Bob's solar blog. AM solar is fine, but there are a lot more options and opinions out there.
George
gandttimes is online now   Reply With Quote
Old 01-27-2015, 10:24 PM   #6
Jessi64's Avatar
2014 16' Sport
Alliance , Ohio
How do u know if the trailer is pre wired? Can u use any set up?
Jessi64 is offline   Reply With Quote
Old 02-02-2015, 07:58 AM   #7
2014 16' Sport
If you have a 2014 sport 16, you are pre wired. It just takes care of the tricky part of how to run wires from the roof to the battery. If you look under the dinette seat (where the fresh water tank, pump, etc are) you will see a loose green wire and a yellow wire. I believe they are labeled too. The manual says the other end is near the vent fan. You would have to pull the fan trim to get to it. I decided on portable instead of roof mount though for my first solar attempt.
Old 02-02-2015, 09:09 AM   #8
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
Please some one tell me why anyone would put a panels on the roof.
(1) They leak up there.
(2) They limit where you can park because they need to be in the sun
(3) They are less efficient because they are flat.
(4) The Airstreams I have seen from the factory with panels installed the wire size is to small,ECT. ECT.
(5) The panels are to small.To me you need 180 watts min.
(6) You need them where you can move them around and change the angle so you can get best use of the sun.
(7) Here are photos of the 4 of use here in Quartzsite AZ this AM.Note Pauls camper they are mounted on roof so he has to park this way to do the best he can.That is facing SE.We all have 180 to 200 watt of panels.
(8) There are some portable fold up panels now in the 100 watt range that have controler built on them that you hook right to you batteries.They store EZ so two would work well.
ID:	231547   Click image for larger version
ID:	231549   Click image for larger version
ID:	231551   Click image for larger version
Jimmini :
AKA : TUMBLEWEED. Just an old buzzard with a itch to yonder.
Cowboys have a way of looking at things a little differently than most folks.Their wisdom is simple and more down to earth.
jimmini is offline   Reply With Quote
Old 02-04-2015, 07:05 PM   #9
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Harder to steal when you're not looking?
My brother mounted his solar panels on a rack over the bed of his pickup truck and parks the truck in the sun while his trailer relaxes in the shade. Maybe we should mount panels on our truck cap, as we don't put anything else up there and we have a nice cap with mounting rails on top.
Rocinante is online now   Reply With Quote
Old 02-04-2015, 08:43 PM   #10
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
That's what I did. Works great!
George
Old 02-06-2015, 04:05 PM   #11
2014 16' Sport
Hey George, forgot to say thanks for the Renogy tip. I ordered their 100w portable suitcase. It's nice and compact and I'm really impressed with the sturdy construction. It was less expensive than other foldable brands. It was even Less expensive than two 45w panels from HF. Bought those first. They were HUGE especially for the low output. Gonna test out the Renogy this weekend. Thanks again.
Old 02-06-2015, 06:23 PM   #12
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Let me know how they work for you. My 3 100w panels are performing as per specs. Thinking of adding one more if I can design a different mounting system for my truck cap.
George
Old 02-06-2015, 07:17 PM   #13
2015 16' Sport
Pineola , North Carolina
Two thumbs up for the Renogy solar suitcase. Very well made and works great. Easy to deploy and track the sun even when trailer is in shade.
"Certainty on any matter is not one of the human attitudes the Gods admire or tolerate."
A. Cross
D Greene is offline   Reply With Quote
Old 02-06-2015, 07:44 PM   #14
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I just finished installing 6 100W panels on my new Classic. Granted, more real estate up there, but on a cost basis you cannot justify the factory install price. Call AM Solar, they are awesome to deal with (this was my second installation of an AM package). Cost of my panels, controller and all connect-up pieces was right at $2K.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Home RV pad with hookups considerations? aomastu Full-Timing, Winter Living & Workamping 34 01-01-2018 11:37 AM
Solar Panel Mounting BarnacleBill Land Yacht/Legacy Motorhomes 14 12-30-2014 10:46 AM
Considerations when buying an Airstream mello mike Buyer Guidelines 42 09-05-2007 11:49 AM
Route Considerations - International in Vermont overlander64 On The Road... 6 06-22-2003 07:15 PM
Solar Panel Mounting JaceBeck 1999 Safari 2 02-26-2003 03:55 PM
