Old 05-04-2016, 10:18 AM   #337
2015 30' Classic
Pleasanton , California
Originally Posted by eheffa View Post
Thanks. I think I may put a DPDT switch in the helm station that allows me to toggle back and forth between a Series and Parallel setup. I will report back on my findings.
-evan
If you put a DPDT switch in the helm, you'll need to bring your solar panel wiring directly to the switch which might be difficult. However, if you use a DPDT relay near the panels like drboyd did, you can use a SPDT switch at the helm and avoid running heavy gauge wire everywhere.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 05-04-2016, 10:24 AM   #338
eheffa's Avatar
2008 25' Safari FB SE
Victoria , BC
Originally Posted by drboyd View Post
My trailer has (2) 100 Watt panels, with a heavy duty DPDT relay in the connector box. The default (no coil power) position is parallel, but applying +12V to the coil through a remote cable switches the panels to a series configuration.
In camp sites with shade spots, I go for the parallel; with full sun all day, I use series.
Of course it's overkill, but I'm a serious geek.
So there!
That's a great idea. Thanks.
I may try to emulate that as I suspect there would be situations that would favour either Parallel or Series.
-evan
eheffa is offline   Reply With Quote
Old 05-04-2016, 10:30 AM   #339
eheffa's Avatar
Victoria , BC
Yes. You're right.
A more elegant solution comes to mind:
I may just run all four of the Standard 10 AWG cables to the engine room with and install a Relay DPDT switch there just before the MPPT Controller with a Parallel / Series switch at the helm.
Thanks.
-evan
Old 05-04-2016, 12:19 PM   #340
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by BoldAdventure View Post
uh huh
I didn't say that. I just said their claims are grandiose at best. Right in line with what Lew said.
If there are dozens of publications saying that, please post some links for all of us. It would be news to me. And I'd like to correct my position.
I regularly see appreciable 'solar boost' with solar arrays 200 watts+. I measure the amperage coming into the solar controller and then directly to the batteries. Always an amperage increase except for extremely low light situations like morning/ evening very lie sun angles.
I'm with Bold on this one. 'Angry' and Ralph can continue to espouse the virtues of dated, simple modulating technology while most other folks use MPPT to gat the most from their panels.
And wait 'till we get the Victron solar controllers fully integrated. They have the fastest MPPT sampling times in the industry to produce even more 'boost'.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
Old 05-04-2016, 01:46 PM   #341
2015 30' Classic
And you will only need a SPST switch at the helm. I look forward to seeing your results.
Al, K6IV
Old 02-23-2018, 07:16 PM   #342
Silvr_Bullet's Avatar
2017 16' Sport
Woodstock , New York
Solar Controller
I have a 16' Sport it was factory fitted with an 80 watt Zamp Solar Panel mounted on the roof with a SunExplorer Controller in the trailer. I recently purchased a 120 watt Zamp portable unit with its own built-in Controller, I want to attach the portable via the Zamp Plug. Now I would have two controllers, and I have no idea how that would work, what controller would be utilized? Anyone have experience with this? Thanks!
I posted this on an Interstate forum, but I see that this is more an appropriate forum.
Silvr_Bullet is offline   Reply With Quote
Old 02-23-2018, 07:26 PM   #343
2015 30' Classic
Two solar controllers charging the same battery(s) should work fine. The situation is akin to having a solar controller and converter.
Al, K6IV
Old 02-24-2018, 12:03 PM   #344
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Two solar charge controllers attached to the same battery could end up with one back feeding the other and cause issues. A better solution is to use a single controller and wire the solar panels in serial so more power could come to single controller if both panels were connected.
Old 02-24-2018, 12:21 PM   #345
2015 30' Classic
No disrepect to swift, but check with Airstream if there's any question. They (AS) wouldn't provide a Zamp connector connected directly to the batteries with an existing solar controller if they thought there would be contention.
Solar controllers are designed to only source current, not sink current, so connecting two controllers together is allowable provided both are setup for the same target voltage - 12 V in this case.
Al, K6IV
Old 02-24-2018, 12:38 PM   #346
dznf0g's Avatar
Oswego , Illinois
I have an idea....why don't you folks Google something Like, "can you use 2 solar controllers on a single battery bank ". I did, and there's plenty of info.
-Rich-
Old 02-24-2018, 12:43 PM   #347
2017 16' Sport
Alano and Switz thanks for reaching out with help, there is an Electrical Schematic in my Airstream Manual it seems to only show the system from the roof Solar panel and makes no reference to the Zamp Plug on the ‘A’ frame. maybe an option for me is at times that I do not have sun on the roof I could disconnect the roof panel and use the Zamp Portable with its integrated controller I have an 80 amp AGM 12 volt battery. I would have to get some help with this, I wonder if that is something an RV shop is up to?
Old 02-24-2018, 02:07 PM   #348
2015 30' Classic
Unnecessary in my opinion. Connect the portable panels when the sun is out and enjoy!
Al, K6IV
Old 02-24-2018, 02:21 PM   #349
2017 16' Sport
Thanks! I am overthinking and obsessing over this issue!
Solar Panel Installation 69Overlander Generators & Solar Power 28 03-03-2013 08:18 PM
AM Solar installation on a Safari hshovic Generators & Solar Power 12 04-09-2011 10:27 PM
Solar panel installation jglase Generators & Solar Power 9 11-30-2006 09:47 PM
Help on solar panel installation Les Gilliam Generators & Solar Power 3 11-27-2002 08:28 PM
Solar Installation cactushead 2001 Safari 19 10-21-2002 05:56 PM
