Old 04-29-2016, 10:59 AM   #323
2012 25' FB Eddie Bauer
Springboro , Ohio
Just purchased exact same system as Tsunami from AM solar. Replacing factory solar on a 2012 Eddie Bauer. Wish me luck. Install will begin this weekend.
Indigo is offline   Reply With Quote
Old 04-29-2016, 11:28 AM   #324
Springboro , Ohio
Lew. I am replacing factory solar on a 2012 FB Eddie Bauer. Purchased the AM Solar Sun Runner Signature 25mppt. Do you think it is possible to fish the cable from the NEW AM solar system from the roof, thru same path as the current factory solar? Can I just pull the factory wires from the roof to the interior with the new cable attached just to fish them thru. Not sure how they wind thru the unit. Any thoughts on how to do this?
As purchase 2 100 watt panels but thought it would be nice to keep one of the factory panels as well. Can I do this? Do not want to mess up the new system. The factory panels are good. The Controler is what quit working.
Old 04-29-2016, 01:13 PM   #325
lewster's Avatar
Naples, FL , Hood River, OR
Indigo,
I doubt it very much if you will be able to pull anything with the premier, as it is fastened inside the walls at multiple points.
There is a far simpler way to bring your solar cable into the cabin. PM me if you would like the skinny.
As far as keeping a factory to add into your new system, the output voltages nest be within a couple tents of a volt or the disparity will confuse the MPPT function and will not provide the solar boost benefit.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
Old 04-29-2016, 02:33 PM   #326
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Good Luck
For me, I just planned, planned, planned and then hacked the plan. Good luck.
tsunami is offline   Reply With Quote
Old 05-03-2016, 12:20 AM   #327
eheffa's Avatar
2008 25' Safari FB SE
Victoria , BC
Parallel Vs Series Panels
Perhaps Lew or another wise resource person can answer this question:
I just sold my Airstream because I bought a Nordic Tug 37 (boat) & can't afford the cost or time to run both. The Airstream, sadly, had to go to some nice new owners.
I am installing Solar panels on the boat (2 x 275 W panels) with a TriStar MPPT-45 Controller feeding 4 x 260 Ah 6V AGM batteries in the House Bank (12V System). Boats don't have Propane fridges or freezers, they run on 12 VDC increasing the draw significantly. OTOH we won't be camping under the trees so should have access to lots of sky and sun.
So my Question: I am advised by the solar vendor that we should install the panels in series to give a nominal output voltage of 48 V & maximum current of 11.5 A. He doesn't think shading should be an issue.
BUT, I am told by other folks that if there is any shading of the panels (by the mast or Radar dome, for example) that the system output can drop dramatically.
Would this be less of an issue if the panels were connected in Parallel vs Series? If so, I would need to increase the wire size to accommodate the higher current load at the lower 24 V output.
Any advice appreciated before I start running wire and commit to one strategy...
Thanks.
-evan
eheffa is offline   Reply With Quote
Old 05-03-2016, 10:05 AM   #328
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Have we already purchased the 275w panels?
I'd be of the bent to use four (or five) smaller panels to accommodate shading better, Canadian sun angles on a flat collector certainly can use help ten months out of the year.
I'm in seriously like with your Nordic Tug 37 boat choice:
Image borrowed from http://www.knot-workin.com/ sailing the Chesapeake Bay...
Old 05-03-2016, 09:45 PM   #329
eheffa's Avatar
Victoria , BC
Thanks Wabbiteer.
Your suggestion of multiple panels makes sense but these panels fit the free space so nicely & I frankly didn't think of the advantages of multiple panels... I did buy them so my options are limited. We get a lot of sky though compared to camping in the trees.
Introducing 'Tugaway', a 2006 Nordic Tug 37:
It's not nearly so aerodynamic as the Airstream but it floats a lot better and gets us to marine parks the Airstream never could...
Old 05-04-2016, 12:11 AM   #330
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Originally Posted by lewster View Post
The Blue Sky is a better system. Plus, Bogart's reasoning for not offering an MPPT controller seems spurious at best. He's beginning to sound a lot like 'Angry Bob' 😄
Lew Farber
541-490-6357
I took " Angry" Bob and Ralph's( Bogart Engineering) and many other publications advice that MPPT for less than 400w is overkill and used the TM2030 in conjunction with the PWM TC 2030 and was totally satisfied with the performance till my Renogy panels went south.
I like the small footprint and total intigration of the 2 units. I don't need some big flashy panel in my living area to show what my solar is doing
gandttimes is offline   Reply With Quote
Old 05-04-2016, 04:37 AM   #331
Wabbiteer's Avatar
1972 29' Ambassador
eheffa: With panels in hand I'd heavy up the wiring for use as parallel and then try both ways, perhaps begin with series? The magic of MC4 connections makes small changes stay small changes. And money invested in heavier copper will pay dividends every minute the sun shines...
Old 05-04-2016, 06:22 AM   #332
eheffa's Avatar
Victoria , BC
Thanks. I think I may put a DPDT switch in the helm station that allows me to toggle back and forth between a Series and Parallel setup. I will report back on my findings.
-evan
Old 05-04-2016, 08:51 AM   #333
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Angry Bob and Ralph are the only two making those grandiose claims about PWM.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 05-04-2016, 09:00 AM   #334
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Ok. You know best.
George
Old 05-04-2016, 09:05 AM   #335
Nomadic , USA
uh huh
I didn't say that. I just said their claims are grandiose at best. Right in line with what Lew said.
If there are dozens of publications saying that, please post some links for all of us. It would be news to me. And I'd like to correct my position.
Old 05-04-2016, 09:54 AM   #336
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
You can have your choice of parallel or series...
My trailer has (2) 100 Watt panels, with a heavy duty DPDT relay in the connector box. The default (no coil power) position is parallel, but applying +12V to the coil through a remote cable switches the panels to a series configuration.
In camp sites with shade spots, I go for the parallel; with full sun all day, I use series.
Of course it's overkill, but I'm a serious geek.
So there!
Solar Panel Installation 69Overlander Generators & Solar Power 28 03-03-2013 08:18 PM
AM Solar installation on a Safari hshovic Generators & Solar Power 12 04-09-2011 10:27 PM
Solar panel installation jglase Generators & Solar Power 9 11-30-2006 09:47 PM
Help on solar panel installation Les Gilliam Generators & Solar Power 3 11-27-2002 08:28 PM
Solar Installation cactushead 2001 Safari 19 10-21-2002 05:56 PM
