Old 04-24-2016, 03:53 PM   #309
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by tsunami View Post
I'm heading out to the barn to disconnect shore power and start turing on fans, lights, and inverter. More to follow. Thanks
You need a re-boot. Remove the battery power from the Blue Sky system (should be the black marine circuit breaker with the yellow stalk). This will re-set the iPN-PRO remote as well and all should be good to go.
Old 04-24-2016, 05:16 PM   #310
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Rebooted system. See photoClick image for larger version
Name:	ImageUploadedByAirstream Forums1461539756.367255.jpg
tsunami is offline   Reply With Quote
Old 04-24-2016, 05:19 PM   #311
tsunami's Avatar
Images: 20
Disconnected shore power. Turned on all lights, both fantastic vent fans, bath and shower exhaust fans (no refrig or furnace turned on) and watched the volt/amp numbers dropped to about -8.5.
Old 04-24-2016, 06:00 PM   #312
tsunami's Avatar
Images: 20
Only things left to do is a very little wiring cleanup and to reinstall the plywood seating surface and cushions. Ready to get me some free power!!!Click image for larger version
Name:	ImageUploadedByAirstream Forums1461542412.559944.jpg
ID:	261317Click image for larger version
Name:	ImageUploadedByAirstream Forums1461542430.946096.jpg
Old 04-24-2016, 06:06 PM   #313
lewster's Avatar
only things left to do is a very little wiring cleanup and to reinstall the plywood seating surface and cushions. Ready to get me some free power!!!Attachment 261317Attachment 261318
sent from my iphone using airstream forums
LOOKING GOOD!!!:d
Old 04-25-2016, 03:14 AM   #314
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Yes, solar power is free but only after the really stiff initiation fee....
switz is online now   Reply With Quote
Old 04-26-2016, 03:07 PM   #315
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I'm trying to pull the trigger on a 200w roof system and I have two choices for monitor and controllers:
1. Bogart Trimetric 2030 monitor panel pair with the Bogart PWM 30amp SC 2030 solar charger. Cost for this system is $343 which includes the 500amp shunt and 4 wire cable harness and temperature sensor. I like the way the solar controller is paired with Trimetric 2030. There are profiles set up that you can choose for each brand of batteries of which Lifeline is included. One of the charging parameters is to allow the batteries to be charge over 7% which according to what I've read is needed to fully charge AGM lead acid batteries.
2. Blue Sky 2512i HV MPPT solar controller paired with a Blue Sky IPN Pro Remote. The cost of this set up is about $531. If I have to get the surface mounting box for the controller then that is another $40.
Will I really benefit from an MPPT system with only 200w on the roof? I can't see adding more panels to the roof int he future as my roof real estate is limited. I do plan to set up a quick connect to the roof system so I can add 200w of portable panels.
Kelvin
Old 04-26-2016, 04:08 PM   #316
2015 30' Classic
Pleasanton , California
The MPPT controller will be more efficient than a PWM controller and the BlueSky battery monitor integrates well with the charger. I'd pay the difference.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 04-26-2016, 05:19 PM   #317
lewster's Avatar
The Blue Sky is a better system. Plus, Bogart's reasoning for not offering an MPPT controller seems spurious at best. He's beginning to sound a lot like 'Angry Bob' 😄
Lew Farber
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
Old 04-27-2016, 08:08 AM   #318
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
You will be happier with that Blue Sky controller.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 04-28-2016, 01:50 AM   #319
switz's Avatar
2014 31' Classic
Images: 8
Our first system was in the Classic and has the TriStar MPPT 60 because of the 800 watts of initial solar panels. We are adding one and perhaps two more 100 watt panels in May. Two additional panels would will bring the TriStar closer to it's rated capacity of 800 watt at 12Vdc (since solar panels really create about 75% of the lable plate power, the ten 100 watt panels could, in theory, create about 750 watts on a bright day).
Making changes to the parameters is a chore as we have to remove the cabinet it hides in to access a data port to make changes to the firmware. When we changed from the four Lifeline 6ct batteries to one lithium iron phosphate battery with the same 12Vdc 600 amp-hour capacity we had to change several of the parameters in the firmware. We have been pleased with it's performance to date.
The 23D has it's roof completely full with five 100 watt solar panels. We selected the BlueSky 3024iL controller and it does an excellent job as well and is easier to program than the TriStar. In my opinion, the BlueSky IPN-Pro Remote provides more user friendly capabilities than the TriStar Meter 2 remote provides.
YMMV
Old 04-28-2016, 06:41 AM   #320
tsunami's Avatar
Images: 20
As stated in the Young Frankenstein movie, "It is alive!!!". After spending about 5 minutes programming, via the IPN-Pro, and validating inputs, I pulled my AS out of the barn, on this very cloudy day and the system sprang to life. More to follow.Click image for larger version
Name:	ImageUploadedByAirstream Forums1461847247.129516.jpg
Old 04-28-2016, 06:42 AM   #321
tsunami's Avatar
Images: 20
Oh and a really big Bravo Zulu to Cody at AM Solar for the assist yesterday!
Old 04-28-2016, 08:01 AM   #322
lewster's Avatar
Solar Panel Installation Report
It certainly is 'ALIVE' !!!
Just remember to keep it fed or it will get ornery..... :-))
GOOD JOB!!
Lew Farber
541-490-6357
Solar Panel Installation 69Overlander Generators & Solar Power 28 03-03-2013 08:18 PM
AM Solar installation on a Safari hshovic Generators & Solar Power 12 04-09-2011 10:27 PM
Solar panel installation jglase Generators & Solar Power 9 11-30-2006 09:47 PM
Help on solar panel installation Les Gilliam Generators & Solar Power 3 11-27-2002 08:28 PM
Solar Installation cactushead 2001 Safari 19 10-21-2002 05:56 PM
