Old 04-12-2016, 06:00 AM   #295
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Sure!!!
Originally Posted by lewster View Post
NICE SHOP!!!! Can I move in??????
If you get over to the Bluegrass state, come on by. I'll throw a couple grass fed beef T-bones on the grill and of course your choice of either beer or my favorite, Bourbon! Lew, thanks for your assistance and guidance on my solar system. Hope we cross paths, again (2014 ABQ Balloon Fest), in the near future.
tsunami is offline   Reply With Quote
Old 04-12-2016, 06:18 AM   #296
lewster's Avatar
Naples, FL , Hood River, OR
DEAL!!
Old 04-12-2016, 07:56 AM   #297
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Are those larger/taller solar panel feet part of the AM Solar SF100 kit or are they a separate purchase?
Kelvin
Old 04-12-2016, 08:24 AM   #298
lewster's Avatar
Kelvin
Separate purchase.
Lew Farber
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters
541-490-6357
Old 04-12-2016, 09:14 AM   #299
KJRitchie's Avatar
2008 25' Classic
I can't find those at AM Solar. The 160w solar feet are only 5mm taller.
Got a link?
Kelvin
Old 04-12-2016, 01:48 PM   #300
lewster's Avatar
Try calling them and ask for the 'Lewster' feet.
Lew Farber
541-490-6357
Old 04-12-2016, 02:59 PM   #301
KJRitchie's Avatar
2008 25' Classic
I noticed Tsunami's AS is a 2016 with the A/C hump. Mine doesn't have that hump. Looking at the OP photos the panels are almost level using the feet that come with the panels.
Kelvin
Old 04-12-2016, 06:13 PM   #302
lewster's Avatar
Kelvin
Optical illusion!! I have always used extended length feet for Airstream installation. They are placed on the outside rails to level the panels, which is not possible using AM SOlars regular 3-hole rocker foot mounts.
I had the super tall feet made for the new, ducted air raised roof of the 2015+ model years.
Old 04-19-2016, 12:35 PM   #303
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Lew, I do recall you had big feet.
Gene
Gene
Old 04-19-2016, 04:05 PM   #304
lewster's Avatar
Gene
Yep. Even bigger ones now with the higher roof curve for the ducted A/C
Lew Farber
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
Old 04-24-2016, 02:12 PM   #305
tsunami's Avatar
Images: 20
Wondering???
Installed the IPN Pro Remote today, final piece of the system. Agonized over location. So the question is: when I plugged the RJ-11 cable in the IPN Pro it lit up and displayed Battery 13.2V Volt/AMP +773.3A when it finally settled out. Then I connected the 18/2 twisted pair and the Volt/AMP went to +0.0A. Would this indicate a problem. The AS is indoors under florescent lighting.
Old 04-24-2016, 02:15 PM   #306
tsunami's Avatar
Images: 20
Photo of IPN Pro after plugging in RJ-11.Click image for larger version
Name:	ImageUploadedByAirstream Forums1461528941.983247.jpg
Old 04-24-2016, 02:50 PM   #307
2015 30' Classic
Pleasanton , California
If you connected the IPN remote without connecting the twisted pair from the current shunt, the fact that it displayed 773A doesn't surprise me, since the IPN remote is looking for a very small voltage drop across the shunt and you left the IPN remote input unterminated. After connecting the shunt, the IPN remote should indicate the current drain from the battery when you start turning on various loads in your trailer.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 04-24-2016, 02:55 PM   #308
tsunami's Avatar
Images: 20
I'm heading out to the barn to disconnect shore power and start turing on fans, lights, and inverter. More to follow. Thanks
Solar Panel Installation 69Overlander Generators & Solar Power 28 03-03-2013 08:18 PM
AM Solar installation on a Safari hshovic Generators & Solar Power 12 04-09-2011 10:27 PM
Solar panel installation jglase Generators & Solar Power 9 11-30-2006 09:47 PM
Help on solar panel installation Les Gilliam Generators & Solar Power 3 11-27-2002 08:28 PM
Solar Installation cactushead 2001 Safari 19 10-21-2002 05:56 PM
