Old 06-17-2015, 04:09 PM   #225
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Remember when using the NEC tables for wire size, they are talking AC.
DC looses energy quickly in small wire. Otherwise why is 4-0 okay for five feet but over five feet it needs to be 2-0 wire between the converter and the battery bank? The answer is power loss.
That is why we have AC power to our homes. In the beginning, Edison wanted to run DC power, but the wire sizes were huge for short distances. George Westinghouse came up with AC and the rest is history.
Old 06-17-2015, 07:18 PM   #226
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
The chart I am using has a drop down that you chance to the voltage being used. It has DC and 1 phase AC as the same. Yes, really long distances and lots of watts definitely make a difference. I have large wire for my inverter but the panel on the roof is only 150 watts or 9 amps max. At 15' it is a 2.3% loss in DC with 10AWG wire by the chart.
BTW, my roof run is much shorter than I envisioned. I will get a footage figure soon. It appears to be about 8 feet total to the prewire plus whatever it is to the controller. My panel is wide and the mounts short but will bow in/out. My panel will be touching the roof in the middle. hmm.
Question to anyone familiar with the fridge vent.
Tonight I was trying to figure out how to get my solar cables down it and found a place in the screen at the top I could squeeze them through so I did. When I got down to get the wires there were no wires to be found in the fridge vent. Is there something up there between the screen and the bottom besides the fridge and that arched filler wood piece? I cannot understand why I cannot see anything.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 06-21-2015, 11:55 AM   #227
2006 25' Safari
Images: 8
OK, I found out for myself. Yes, there is a problem when just sticking wires through the screen. apparently there is a second screen or something there that blocks anything from getting through. I had to drill through the vent shaft like before to clear it and get the wires down the shaft. It is done. Here are my pics.
ID:	241235   Click image for larger version
ID:	241237   Click image for larger version
Old 06-21-2015, 12:06 PM   #228
2006 25' Safari
Images: 8
BTW, for some interesting reading regarding AC versus DC. Check this out. DC is starting to replace AC primarily due to energy loss that does not impact DC.
Tesla turns in his grave: Is it finally time to switch from AC to DC? | ExtremeTech
Old 06-21-2015, 12:19 PM   #229
2006 25' Safari
Images: 8
Here is another one- I added these SAE2 ports on each side of my battery box to just plug in easily with the portable units:
ID:	241239   Click image for larger version
Old 12-16-2015, 04:34 PM   #230
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Having read this entire thread 3 time, I noticed that that the installer ventilated the controller box that was installed in the cabinet. How much heat is generated by the controller? Is this something to be concerned about?
tsunami is offline   Reply With Quote
Old 12-16-2015, 05:05 PM   #231
2015 30' Classic
Pleasanton , California
Solar chargers never operate at 100% efficiency, so for example if your solar charger operates at 96% efficiency and you have 400 W of solar panels, the solar charger will need to dissipate 16 W. Heat is the enemy of electronics so it's always good practice to make sure there's adequate airflow. The Solar Boost 3024 manual calls out, "CAUTION: Mount the unit with heatsink fins oriented vertically to promote cooling and do not enclose in a confined space."
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 12-16-2015, 07:07 PM   #232
Tesla turns in his grave: Is it finally time to switch from AC to DC? | ExtremeTech[/url]
Tesla is fine with all this. He always stated DC had its place.
EddieO is offline   Reply With Quote
Old 12-16-2015, 10:17 PM   #233
eheffa's Avatar
2008 25' Safari FB SE
Victoria , BC
Hi,
I ventilated the box on spec thinking that it should have some ability to dissipate any heat. The front surface plate of the controller does get warm to the touch when operating under higher loads but never to temperatures that concerned me. The enclosing box is slightly warm on occasion but again of no real significance.
The unit is still working flawlessly.
-evan
eheffa is offline   Reply With Quote
Old 01-07-2016, 12:26 PM   #234
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
What are the advantages of 24v panels vs 12v panels?
I have a Zamp 200 watt portable system. I'm guessing they are 12v panels. If I wanted to install 200 watts on the trailer I'm guessing I'd have to find 12v panels. What I'd like to do is put 200w on the trailer and then using a combiner box in the trailer be able to connect my portable panel to the trailer panels then run to an appropriate controller (the portable panel's controller is removed). Looking at AMSolar they seem to sell only 24v panels. Can I just get any 100w Monocrystalline panel to run with my Zamp.
This way I can charge the batteries while towing, charge the batteries if the trailer is in the shade or get 400watts (22 amps) charging in a full sun campsite.
Kelvin
Old 01-07-2016, 01:16 PM   #235
2015 30' Classic
Most of the panels for RV use, including the Zamp portable panels, contain 36 photovoltaic (PV) cells. Since each cell produces approximately 0.6 V, a 36-cell panel will produce approximately 21.6 V open-circuit and less when producing real power from the panel. Even though the manufacturers refer to the panel as 12 V, if you check the specifications you'll find that they operate at maximum efficiency around 18 V or so.
Of course you realize with your planned configuration that you won't be able to use your Zamp solar controller, since the included controller won't support 400 W. If you want to parallel panels, i.e., mount 200 W on the roof and keep another 200 W as a portable option, I would recommend that you purchase the same panels as your portable panels from Zamp so that all your panels are balanced, meaning that when exposed to direct sunlight each is operating at the same current and voltage. It gets very complicated to connect panels from different manufacturers and doing so would likely degrade the efficiency of your system.
The BlueSky Solar Boost 3024iL MPPT controller will easily handle your configuration and also give you an optional battery monitor, which IMHO is essential for caring for and understanding your system. With this system you have the option of connecting all four panels in parallel, or you can configure your system in a series/parallel arrangement which will double the voltage and cut the current in half. I would suggest this configuration since you'll be able to reuse your existing solar pre-wiring without incurring much loss.
AM Solar is a good resource for the solar controller, wire, combiner box, etc. You'll need to procure identical panels from Zamp. Many folks can help with the details. Just ask.
Al, K6IV
Old 01-07-2016, 01:42 PM   #236
KJRitchie's Avatar
2008 25' Classic
When the solar panels on the roof are actively charging the batteries while towing does the charge circuit from the tow vehicle interfere with the solar? It would be nice to have both so when towing at night you still get some charging.
Thanks.
Kelvin
Old 01-07-2016, 02:15 PM   #237
2015 30' Classic
It's a rather complicated relationship. Your solar charger will likely be a 3-stage battery charger with temperature compensation. This is ideal for your flooded or AGM batteries. However the TV alternator doesn't sense the voltage of the AS batteries so although you can allow the TV to charge the batteries in the AS it's not ideal. You won't blow anything up, but in the right conditions you may overcharge your AS batteries if you drive frequently which may lead to some degradation of your AS batteries. Many folks simply pull the fuse to interrupt the power going to the TV when they have a solar installation.
Al, K6IV
Old 01-07-2016, 02:20 PM   #238
KJRitchie's Avatar
2008 25' Classic
Would the Blue Sky Solar Boost 3000i be a better solution for me. It seems to have more monitor functions than the IPN remote.
Kelvin
Solar Panel Installation 69Overlander Generators & Solar Power 28 03-03-2013 08:18 PM
AM Solar installation on a Safari hshovic Generators & Solar Power 12 04-09-2011 10:27 PM
Solar panel installation jglase Generators & Solar Power 9 11-30-2006 09:47 PM
Help on solar panel installation Les Gilliam Generators & Solar Power 3 11-27-2002 08:28 PM
Solar Installation cactushead 2001 Safari 19 10-21-2002 05:56 PM
