Old 04-06-2016, 04:34 PM   #1
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Solar Panel Install Clarification
Having exhausted reading all the solar panel install here in the AS forum and searching on-line, I'm looking for clarification on installing the solar panels I purchased from AM Solar. The instruction for the feet that are shipped with the panels says to use isopropyl alcohol as a surface prep before sticking the feet down. Here in the forum, specifically the Generators & Solar, I read a thread that said to use a mineral spirits like carb/brake cleaner. So,just wanting to make sure that when I pull the 3M VHB tape tab off and expose the glue and adhere the feet to the roof of my AS, I won't be the first AM Solar customer to have a solar panel dislodge. Please assist so I can move forward with the install.. Thanks
tsunami is offline   Reply With Quote
Old 04-06-2016, 06:14 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
AM Solar uses alcohol because they seal the feet after placement with Dicor self-leveling sealant.
I don't use Dicor due to it's high VOC content which exhibits shrinkage and cracking in the sealant within a year or two.
If you are using a single part polyurethane adhesive/sealant around the panel feet like SikaFlex 221, then NO ALCOHOL!!! as it inhibits the strength and curing of the sealant. I use carb cleaner exclusively, but mineral spirits will also work well.
I prefer the additional adhesion that the SikaFlex provides, along with the bonding power of the VHB.
Old 04-06-2016, 06:57 PM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Lew,
What about using Vulkem or Alcoa Gutter Seal?
Bill
Just my personal opinion
Old 04-06-2016, 08:06 PM   #4
lewster's Avatar
Definitely not gutter seal as it has little adhesive properties. Perhaps Vulkem, but I have little experience using it and the formula that I tried was grainy in texture, which definitely did not suit my purposes.
I have been using SikaFlex 221 for 15 years with no failures. Can't ask for a better track record than that.
Lew Farber
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters
541-490-6357
Old 04-06-2016, 08:41 PM   #5
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
SikaFlex 221 and mineral spirits here too.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 04-08-2016, 05:37 PM   #6
Tampatomgirl
1990 34' Excella
Zephyrhills , Florida
I recently purchased a 1990 Excella. 34' long. I would like to add solar as well. Can you tell me what you bought, so i can do more research? I have no experience with solar & need enough power to run everything but the gas stove.Thanks, Michele
Tampatomgirl is offline   Reply With Quote
Old 04-08-2016, 06:15 PM   #7
2015 30' Classic
Pleasanton , California
Start with AM Solar's website, www.amsolar.com. There's good information for the novice and they are also quite generous with information if you contact them.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 04-09-2016, 03:12 AM   #8
tsunami's Avatar
Images: 20
Just as an FYI, their new url is www.amsolarrv.com
They updated their website.
Old 04-09-2016, 06:45 AM   #9
lewster's Avatar
No worries. The old links to the new.
Old 04-09-2016, 06:19 PM   #10
2005 22' International CCD
Cambria , California
Attaching Solar Panels
I've had a great solar set up for more than 10 years on my 22ft International. The solar panels are attached using a Z like bracket that can be bent to fit the curve. Where there are rivets, there is a part of the frame. Using rubber expansion nuts will seal the holes and hold the panels forever. I can't believe that any mobile use of panels would rely on adhesives. Sounds like a really bad idea.
Ziggy2 is offline   Reply With Quote
Old 04-09-2016, 07:22 PM   #11
lewster's Avatar
Tell that to the thousands of clients that AM Solar has provided with mobile solar solutions for almost 30 years.
I have yet to drill a single hole in the roof of any Airstream where I have placed solar panels.
Rubber riv-nuts have their place, but don't allow for a panel to be tilted in off-season applications. Z feet also require you to follow the roof contour with your panels. We use adjustable feet of varying heights that not only allow for the tilt feature, but also allow the panels to ride flat and parallel to the ground; a position that gets you maximum input of solar radiance over the course of the solar day.
The incredible bonding power of 3M VHB tape and advanced polyurethane adhesive sealants is a proven application method which is used quite successfully in many industries including automotive.
I'm glad that your several panels are still solidly secured to your roof. So are the over 1000 panels that I have placed on my clients roofs.
No holes........NO LEAKS!!!!!!!
Lew Farber
541-490-6357
Old 04-11-2016, 07:01 PM   #12
My apologies
This just goes to show what a dinosaur that I've become. Technology is just incredible. Enjoy.
Old 04-11-2016, 07:33 PM   #13
2016 30' Classic
Erie , Colorado
Now Ziggy... don't go insulting dinosaurs VHB is incredible stuff. Heavily used in the signage industry. If you see some fancy stores with big pieces of aluminum mounted on the walls etc good chance it was done with one of the VHB products. I tested a 3/4 x 3/4 piece for shear tension. After 24 hours pulled about 40# before I saw any movement. Digital fish scale went to 50#. It did finally release but with the amount that is on the feet of the AMSolar mounts times 4 attach points it would take a tornado or hurricane to pull them off as Lew has pointed out. Add the SikaFlex 221 and if you could hook a crane to the attach points on 4 roof panels you could probably lift the trailer. Wouldn't that be a great commercial to film?
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 06-02-2016, 06:18 PM   #14
RankAm's Avatar
1956 22' Flying Cloud
Dallas , Texas
Which version of VHB?
Lewster (or anyone else with experience), which version of VHB tape do you use on solar panel mounting feet?
Thanks, Hank
See my 1956 Flying Cloud renovation thread.
RankAm is offline   Reply With Quote
Clarification on year model Astrodokk Classic Motorhomes 15 06-30-2009 10:32 PM
What's This? Monocoque's Pic needs clarification Distantdrummer Repairing/Replacing Floor &/or Frame 10 02-19-2009 08:47 PM
Clarification with the blue paint please harestream Clearcoat, Exterior Paint & Trim 5 09-20-2006 02:44 PM
