Old 10-13-2019, 09:39 PM   #1
steilkurve's Avatar
2020 22' Bambi
2022 25' Globetrotter
St-Laurent , Quebec
Solar panel ‘idle’
Hey all. Local dealer installed a WattMobile solar system on my new 2020 Bambi 22FB. Boondocked for the first time this weekend. Was unable to get the panels to charge the batteries. There was full sun on the panels but the Remote Meter was showing a moon next to the panel icon (meaning it thinks it’s night time) and had the mention next to solar charge. Scoured the manual and I cannot find a solution. My portable Zamp panel connected to the Zamp outlet worked fine, but not the fixed panels, even when the portable panels were disconnected. Any thoughts? Below is a link to the controller I have.
http://azimuthsolar.ca/product/mppt-...-1224v-ml2440/
steilkurve is offline   Reply With Quote
Old 10-13-2019, 10:52 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Some photos if the install might help. Maybe there is a panel disconnect switch Between the panels and the controller that is turned off. Or maybe a breaker tripped.
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 10-14-2019, 06:40 AM   #3
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Thanks. I don’t believe there is a switch between the panels and controller. The latter is hidden away (not sure where it is to be honest) and the dealer never mentioned one at delivery. I’d be surprised they would have put a switch next it if tucked away like that. And I f a breaker tripped, would the remote meter not be off? I was more thinking it’s a controller config thing. Manual is cryptic. I park my AS a local warehouse. Will go and visit today to bring back pictures.
Old 10-14-2019, 06:49 AM   #4
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Ok,
If it was properly installed there should be a “disconnect” between the solar panels and the controller. As you know Solar panels put out voltage any time they are exposed to sunlight. The purpose of the panel disconnect switch is to have the ability to turn off the panels and remove that voltage source from the system for maintenance and or service without having to cover the panels on the roof.
A proper install should have this disconnect.
I’m not familiar with your brand charge controller, but with the “moon” displayed it is telling you that the voltage coming from the solar panels is zero or below the threshold to turn the charger on.
(Best Guess)
Old 10-14-2019, 06:58 AM   #5
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
If it was properly installed there should be a “disconnect” between the solar panels and the controller. As you know Solar panels put out voltage any time they are exposed to sunlight. The purpose of the panel disconnect switch is to have the ability to turn off the panels and remove that voltage source from the system for maintenance and or service without having to cover the panels on the roof. A proper install should have this disconnect.
Thanks again. I will search for such a switch. Guess it would be in the storage compartment under the bed (22FB) as the meter is mounted on the base of the bed (terrible location BTW) and the panels are right above on the roof. I suspect the controller is somewhere in there. At any rate, will head over to my AS today and bring back photos/findings. Appreciate your help.
Old 10-14-2019, 07:11 AM   #6
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
Call your local dealer who installed it. I realize they were closed for the weekend, but they'd be my first call when the manual did not help.
Good luck.
rowiebowie is offline   Reply With Quote
Old 10-14-2019, 10:00 AM   #7
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Ok,
(Best Guess)
Ok so just went to my AS. Could not locate a panel disconnect switch. Only thing is a 30 AMP fuse between controller and battery connector inside the trailer or that’s what I believe it is. Only anomaly I as a newbie was able to pickup is that the green negative wire from the solar panel seemed connected to the positive terminal of the controller. The cryptic manual seems to say the fat left terminal is positive. Not sure if that matters though I’d suspect yes. Thought of trying to reverse the two but before I do, thought I’d check in with the experts here! I’ve attached a few photos. All thoughts welcome!Click image for larger version
ID:	354226Click image for larger version
ID:	354227Click image for larger version
ID:	354228Click image for larger version
ID:	354229Click image for larger version
Old 10-14-2019, 11:50 AM   #8
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
That sounds like your problem. If you can confirm the polarity of the solar wires is correct then swap them that should solve your problem.
If that turns out to be the case. NEVER go back to that installer. They should have checked that system before releasing it to you.
If that is the problem then that means they never check the output before returning it to you.
Sloppy work.....
Old 10-14-2019, 12:58 PM   #9
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Sloppy work.....
Yep. Will for sure talk to the dealer about this. Two more quick questions for you if I may:
1) Aside from swapping the wires, is there any other way to determine polarity of what’s coming from the panels?
2) Any precautions I should take before swapping the wires? Turn off all the beakers I assume? What about the controller? It’s on even when I disconnect the battery.
Thanks again.
Old 10-14-2019, 05:45 PM   #10
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Solar panel ‘idle’
Thanks again.
Only thought I had is if they put the neg green prewire on the pos side of the controller—is there a chance they did that because they used the green as the positive up at the combiner box and were too lazy to change it? Just a thought! Nothing surprises me any more!
Also, it’s ok not to have a switch before the controller if the fuse has a trip switch which some people use to isolate the panels. (See yellow tab on attached pic) I have a dedicated switch as well, but might be worth seeing if the breaker is manually tripped.
pcskier is offline   Reply With Quote
Old 10-14-2019, 06:06 PM   #11
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Thanks again.
You can determine polarity with a volt meter. Place the positive lead (red) to the wire marked Positive and negative lead (black) to the wire marked negative. If you get a positive reading i.e. (12 volts) then your wire polarity is correct if you get a negative reading i.e. (-12) your polarity is reversed.
Also not picture below. Using a high-flow DC breaker is a much less restrictive choice.
Old 10-14-2019, 06:07 PM   #12
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Here is a pic of the disconnect switch needed between the panels and controller.
Old 10-14-2019, 08:07 PM   #13
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Thanks. Got a volt meter. Will swing by my AS this week and test this.
If they are reversed, do I just swap them or should I disconnect the controller from the battery first, I guess by removing the fuse?
Old 10-14-2019, 08:41 PM   #14
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
If they are reversed, there's a pretty good chance the controller has been damaged by the reversal. If you have any sort of warranty on the device, you might want to look into that.
A call to the manufacturer probably is a good idea if this is some sort of packaged system.
If this into enough of a mess that you rip it out. Do the next one with more normal ( = commonly used ) components
Old 10-14-2019, 11:55 PM   #15
The Aluminum Tent 3
pcskier's Avatar
Park City , Utah
Solar panel ‘idle’
Attachment 354254
Doh!! Disregard my comment. The switchable fuse like the one I pictured is between the controller and battery, not between the panels and battery. I have a switch like GMFL pictured between panels and controller.
Old 10-15-2019, 06:15 AM   #16
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
Ok so I went and tested he wires with a volt meter. I just a reading of zero. What would that mean?
Old 10-15-2019, 06:27 AM   #17
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
We’re the panels getting sun.
Old 10-15-2019, 07:58 AM   #18
steilkurve's Avatar
2020 22' Bambi
St-Laurent , Quebec
How silly of me. No sun. My small AS is sandwiched between two very high class As and it was early. Sun was low. Will return when sun is higher.
Have also emailed my dealer with photos of install. Awaiting reply.
Old 10-15-2019, 08:29 AM   #19
Half a Rivet Short
2022 Interstate 24X
Hi
I would go direct to the manufacturer. If the dealer didn't know enough about the system to wire and test it correctly, there is little chance he is very familiar with this system.
Old 10-15-2019, 08:52 AM   #20
2004 30' Classic
California , MD
Ok so just went to my AS. Could not locate a panel disconnect switch. Only thing is a 30 AMP fuse between controller and battery connector inside the trailer or that’s what I believe it is. Only anomaly I as a newbie was able to pickup is that the green negative wire from the solar panel seemed connected to the positive terminal of the controller. The cryptic manual seems to say the fat left terminal is positive. Not sure if that matters though I’d suspect yes. Thought of trying to reverse the two but before I do, thought I’d check in with the experts here! I’ve attached a few photos. All thoughts welcome!Attachment 354226Attachment 354227Attachment 354228Attachment 354229Attachment 354230
Wiring is kind of a mess. Only a few more minutes, and some care, and they could have cleaned this all up.
cru-in is offline   Reply With Quote
Honda 2000 rough idle after storage....???? crazylev Generators & Solar Power 31 12-07-2011 01:37 PM
Sprinters: to idle or not to idle? briborg Sprinter and B-van Forum 12 06-04-2007 10:14 AM
Cooling at idle bkahler Mechanics Corner - Engines, Transmission & More... 15 04-08-2007 12:52 PM
Yikes! No Idle Adjustment - Fast Idle. lebolewis Tow Vehicles 97 08-27-2006 05:20 PM
idle ?s about quality of space, life suspiria_2 Full-Timing 21 10-22-2003 06:53 PM
