Old 10-21-2019, 06:52 PM   #41
2016 16' Sport
Miami , Florida
Hi
A system that has no documentation, no support, *and* that does not work is a suspect system. It will not "get better with age". The only point you are likely to be able to do a zero (or low) cost swap out is up front.
That said, fuses (specifically a fuse in the box on the roof) have been mentioned much earlier in this thread.
Additionally no where was an in line fuse prior to the roof top junction box mentioned. My new panels have an inline fuse very close to the panel. Depending on how they are mounted they could be very difficult to notice if one wasn’t specifically looking.
So sorry Bob but I wasn’t just parroting your post about a fuse in the roof box but just trying to point out one more simple explanation rather then jump straight into persecuting the installer and manufacturer.
Shiny16 is offline   Reply With Quote
Old 10-21-2019, 07:20 PM   #42
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Well, the stock box used by Airstream for their pre-wires normally *does* have a fuse in the box on the roof .....
uncle_bob is online now   Reply With Quote
Old 10-21-2019, 07:26 PM   #43
2016 16' Sport
Miami , Florida
Hi
Sure. So why would you be dismissive about me pointing out an additional possibility?
Old 11-10-2019, 09:21 AM   #44
Hey. OP here. Realized I never circled back to tell everyone the verdict! Dealer fixed the issue and said it was indeed an MC4 cable on the roof not fully seated, as I had suspected myself towards the end of my investigation.
System fully functional now. In fact, tried it a few times before shipping my AS to storage for the winter. Charged the batteries very well despite the low Fall sun. Not crazy about the fact it seems to be a tier B system as evidenced by support/info available but given how well it works now that it’s properly set up, I will tough it out.
Thanks all for the help provided. As a newbie, your advice helped me learn a ton.
steilkurve is offline   Reply With Quote
Honda 2000 rough idle after storage....???? crazylev Generators & Solar Power 31 12-07-2011 02:37 PM
Sprinters: to idle or not to idle? briborg Sprinter and B-van Forum 12 06-04-2007 11:14 AM
Cooling at idle bkahler Mechanics Corner - Engines, Transmission & More... 15 04-08-2007 01:52 PM
Yikes! No Idle Adjustment - Fast Idle. lebolewis Tow Vehicles 97 08-27-2006 06:20 PM
idle ?s about quality of space, life suspiria_2 Full-Timing 21 10-22-2003 07:53 PM
