Old 06-02-2010, 08:13 AM   #15
1975 29' Ambassador
Reno , Nevada
re "Then you probably have AGM batteries (or you SHOULD!)" -- why? They cost 2x, last maybe 1.5x, still need proper battery compartment. I mean, they are nice but I can't see pushing it too far.
re: "the old Pulse Width Modulation (PWM) style. It surely has it's limitations" -- the advantage of MPPT is not that much for small installations (under 500 watts) like you'll find in an RV.
What is important in either a converter or a solar charge controller is good charging smarts coupled with a maintenance mode that will inhibit battery sulfation during periods of minimal use. Examples of these would be the ChargeWizard based converters or the BatteryMINDer charge controller.
Solar Panel Installation 69Overlander Generators & Solar Power 28 03-03-2013 08:18 PM
Solar panel installation jglase Generators & Solar Power 9 11-30-2006 09:47 PM
Solar Panel gilmorris Generators & Solar Power 14 12-05-2005 05:33 PM
Best Solar Panel recommendations please! westeagle Generators & Solar Power 2 11-16-2003 11:31 AM
Help on solar panel installation Les Gilliam Generators & Solar Power 3 11-27-2002 08:28 PM
