Old 03-09-2009, 10:22 AM   #1
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Solar panel, getting wires into trailer
I would like to add a solar panel some day and thought while I have the interior out I should add the wiring for the solar panel.
I would like to avoid running the wire through a vent and am looking for ideas on how I can get a watertight screw terminal post on the roof or if someone has a better idea I sure would like to here it and see it.
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 03-09-2009, 11:36 AM   #2
pbearsailor's Avatar
Port Hadlock , Washington
Feed Through Connectors - Blue Sea Systems
pbearsailor is offline   Reply With Quote
Old 03-24-2009, 09:42 PM   #3
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Steve, thanks for the information.
I bought two of them from West Marine.
Bruce,
Old 03-30-2009, 08:48 PM   #4
campadk's Avatar
2007 19' Bambi
Ottawa , Ontario
Connecting a Portable Solar Panel
I'm currently working on my new solar panel project. Its a 135W panel that I will be placing nearby the trailer (wherever the sun is) and want to run the 25 ft cable to the charge controller, either located by the batteries, or inside the trailer somewhere.
Unfortunately the battery box doesn't have an ounce of room to put the Morningstar MPPT controller in (its about 7"x3"x3"). So I either need to mount a box for it outside, or put it inside the trailer. Any suggestions? I know if it is located inside the trailer, that may limit the length of cable I have running to the panel. If its outside, I need to find an appropriate weather proof box for the controller.
campadk is offline   Reply With Quote
wires? "other DC panel? cyote@ptsi.n Electrical - Systems, Generators, Batteries & Solar 2 10-28-2006 03:27 PM
Solar Panel gilmorris Generators & Solar Power 14 12-05-2005 05:33 PM
Best Solar Panel recommendations please! westeagle Generators & Solar Power 2 11-16-2003 11:31 AM
Solar Panel Mounting JaceBeck 1999 Safari 2 02-26-2003 03:55 PM
