Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 05-26-2007, 07:36 AM   #1
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Solar Panel Combiner Box
I have a question concerning the combiner box I received from AM Solar. I figure they are closed for the holidays and I am about to mount the combiner box under the refrigerator roof vent. I received the combiner box with 4 weatherproof strain relief connections, two of which are pictured are installed in the pictures shown. My question is, are the other two for the connecting box under the solar panel or are they for the additional one or two panels I could mount in the future?
ID:	37929  Click image for larger version
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 05-26-2007, 07:55 AM   #2
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
is there a knock out on the panel?
if so i would say you need one on each end of the cable. and the plugs on the junction box is for future use or a larger system.
john
you call them ferrets, i call them weasels.
Old 05-26-2007, 08:13 AM   #3
davidz71
davidz71's Avatar
Hi John,
Thanks for the reply. There are four knockout areas wich look to be the same size as on the combiner box. I tried to knock out one with a screwdriver while supporting the panel box from inside. You could the one I was hitting flex but would not break free. I drilled a hole in the center of one large enough for the cable but am concerned that I'm not "doing it right". Like you, I am thinking that the other two strain relief connections go onto the panel connection for support.
Craig
AIR #0078
3.73 rear end
Old 05-26-2007, 11:31 AM   #4
john hd
john hd's Avatar
madison , Wisconsin
Images: 40
craig
if you do not have a knockout die try drilling a little larger hole until you can get a needle nose in there to rock the slug out. sometimes the slug is not cut all the way around and just indented.
short of that a hole saw works too! a uni bit in a drill works fast also.
i would use the strain relief fittings on both ends because of road vibration and the possibility of the metal edges sawing through the wires.
john
Old 05-26-2007, 11:52 AM   #5
davidz71
davidz71's Avatar
You've talked me into it John. I think I have a small keyhole bit around here somewhere that may be the right size. If not I'll work it out with a drill bit and pliers.
Craig
AIR #0078
3.73 rear end
Help on solar panel installation Les Gilliam Generators & Solar Power 3 11-27-2002 08:28 PM
Solar Panel Installation 69Overlander Generators & Solar Power 23 11-19-2002 09:25 AM
Doctor Box Pahaska Our Community 7 11-18-2002 08:53 AM
Solar battery charging Charles Q Treichel Generators & Solar Power 23 10-17-2002 10:22 AM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 10:21 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
