Old 10-23-2014, 03:06 PM   #21
Naples , Florida
There is ABSOLUTELY NO REASON to put holes in your Airstream roof to attach solar panels……especially large ones the sizes of rivnuts, when there are proven surface bonding alternatives. Guess you guys just don't get it !
It's your trailer. Go right ahead and put as many unnecessary holes in your roof as you please…………...
lewster
Old 10-23-2014, 04:08 PM   #22
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
....I got the "Lew no-hole lecture" before I installed 4 panels on me roof. After over 16,000 miles with the panels in place, there was not a single issue with a loose or lost panel. In fact, I put zero holes in the roof. I used the VHB tape on the combiner box and ran the cables down the vent to my gray tank. Oh, and I will be doing this same process with my '15 Classic.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 10-23-2014, 04:42 PM   #23
1974 Argosy 20
Kooskia , Idaho
I have no big problem with putting properly sealed holes for solar panel mounting in the roof, but now that I know there is a good alternative, VHB tape, I would not do it again. The only problem that I can see with VHB tape is that it is so strong, and so good, that if you ever do wish to totally remove it, it is almost impossible.
Go with the VHB tape system if you are doing solar systems on the roof of an Airstream.
Old 10-23-2014, 04:49 PM   #24
1999 30' Excella 1000
small town , Maryland
If this dealer doesn't make it right, can you tell us their name? This would save someone else the same ''solar install'' aggravation. The thought of this might show the dealer the right direction to take. I do not believe in rewarding bad behavior.
streaminwild is offline   Reply With Quote
Old 10-23-2014, 04:59 PM   #25
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
You'll have to do it by private mail; the Forums have a policy against badmouthing dealers. Even if it's justified. I offer this advice because I don't want to see anyone get banned for a couple of weeks by the moderators.
Old 10-23-2014, 05:44 PM   #26
Naples , Florida
It certainly IS strong, but there IS a way to get the stuff off cleanly! PM me if you are in need of this proprietary information.
lewster
Old 10-23-2014, 06:51 PM   #27
Thanks for the heads up Protag. The last thing I want is a forum member being banned for anything. This is my third draft because my first would have had me banned for life.
Old 10-23-2014, 08:16 PM   #28
2004 22' Safari
Albuquerque , New Mexico
Not so fast...
Aircraft manufacturers such as Boeing use 3M Scotchweld tape to hold their airplanes together; I imagine it would work just as well on an Airstream.
I am unaware of a single structural application where an aircraft is bonded with an adhesive. Non-structural yes, many, but not structural.
Silver.Sanctuary is offline   Reply With Quote
Old 10-23-2014, 08:32 PM   #29
Rolland's Avatar
1967 30' Sovereign
Chiefland , Florida
I think you will find many modern aircraft are made entirely of bonded composites, including the rotor blades on newer helicopters. The newer bonding agents, applied properly,(and that is the key) are stronger than the parent material. Chevy has been holding the doors and hinges on their vehicles with glue for years, no bolts. A properly installed solar panel should never come off. Just my 2 cents- Rolland
Rolland is offline   Reply With Quote
Old 10-23-2014, 09:50 PM   #30
interstateflyer's Avatar
2017 25' International
Los Osos , California
AM Solar used a combination of adhesive tape, screws and Sikaflex on our installation this summer. They were concerned that the curvature of the narrower roof of the 8' wide 23D International might not be ideal for an adhesive tape-only application and decided to err on the side of caution. They felt the effects of heat over time on a non-flat surface tape application were not completely understood.
Your 16 foot International has the same roof curvature as the 23D. They might be well advise to follow AM's lead on the redo.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 10-24-2014, 05:24 AM   #31
Not pertinent. Solar panels on a trailer are non-structural, too. We're not talking about replacing all of the rivets in an Airstream with adhesive.
Old 10-24-2014, 07:42 AM   #32
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
Solar panel blown away!
Too late. I already drilled all my rivets, and replaced them with 3m adhesive tape... Why didn't I look into this a little further???
-Red, jumping the gun...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 10-24-2014, 07:51 AM   #33
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Be advised the 3m tape comes in a variety of speeds. Strong, really strong and super strong.
Seriously they are rated in pound ratings per sq inch.... Like 15, 25,45, 90.
If I recall, they start at a light grey and go to black, black being the high test stuff. There is also a cleaner and primer product available, should you desire a 3 step program!
Old 10-24-2014, 07:57 AM   #34
Panama Red's Avatar
Obrien , Florida
I used the light pink... So, my trailer is likely to fly apart at any second.
-Red, waiting on panels to fly off...
Actually, I never knew any of this about the two sided tape, so this thread has been very informative. Unfortunately, I have a hard time refraining from being a smarty pants... No malice intended, of course.
Old 10-24-2014, 08:05 AM   #35
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Pink is for sissies with under 100 watt panels!
VHB tape is the best thing to come along since sliced Velveeta and Spam.
No malice intended either!
Old 10-24-2014, 08:07 AM   #36
Panama Red's Avatar
Obrien , Florida
I originally installed my solar panels with sliced Velveeta and Spam... That crap didn't work at all!
-Red, hoping the pink works better...
Old 10-24-2014, 08:08 AM   #37
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Of course but did you prep the surface?
Old 10-24-2014, 08:14 AM   #38
Panama Red's Avatar
Obrien , Florida
Ooohhh, I didn't think of surface prep. No wonder...
-Red, getting rid of the pink sissy tape and going back to sliced Velveeta and Spam...
Old 10-24-2014, 08:37 AM   #39
2020 Classic 33
Box Elder , South Dakota
Do the AS factory tour and you will quickly learn that the rivets are only there to hold the double sided tape that is between the skin and the ribs in place. Carefully watch the guy on the inside that is allegedly holding a bucking bar. It is for the tour show. Bar has a hole in the end of it. No bucking takes place. It's all about the double side sticky tape.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 10-24-2014, 08:55 AM   #40
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
I had exactly the same experience with my install, using AM Solar equipment and a local RV solar specialist. He was not confident in using the 3M tape only (even though I supplied it to him for his use) due to the AS curves. He used the 3M, screws, Silkaflex, and Dicor. Shouldn't blow off.
Bob and Nancy
https://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Getting 1 solar panel, should I just get 2 right away? JustSomeGuy Generators & Solar Power 24 01-28-2014 08:22 PM
blown away sawyerpoint Roof Vents, Skylights & Fans 3 04-28-2012 04:37 PM
I wasn't blown away! CalamonTin On The Road... 10 11-12-2011 08:03 PM
Blown away. njloco Roof Vents, Skylights & Fans 18 07-22-2011 06:38 PM
