Old 11-24-2014, 08:39 PM   #57
2016 30' Classic
Erie , Colorado
This just sounds like it is getting worse. Had a single fastener fail, so let's drill another hole and put in two. You mention concern of it not leaking. What about not having the solar panel depart again and in doing so cause additional damage?
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NōVPN
ghaynes755 is offline   Reply With Quote
Old 11-25-2014, 10:33 AM   #58
2010 16' International
Edwards , Colorado
The only reason the two lower "grommets" pulled out is that the upper two fasteners came loose from the panel. At 60 mph and the panel flapping in the wind, I'm not surprised they couldn't hold.
BudE
BudE is offline   Reply With Quote
Old 11-25-2014, 10:35 AM   #59
Edwards , Colorado
Yes, looks like they used the rubber rivet nuts shown. And they were sealed. As I mentioned previously, I'm sure there will be opinions pro and con.
BudE
Old 11-25-2014, 11:17 AM   #60
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Solar panel blown away!
VHB tape is really the way to go!
The only real caviat is surface prep
After a few days of cure time in proper temps, you'll tear the aluminum skin before you'll get the tape to fail!
I'm guessing the rubber well nuts will fail in very short time with exposure to UV light and ozone.....
You'll be doing this all over again.
Kyocera publishes a great paper on vhb usage. Ill post it later.
On my classic my 500 Watt panels are mounted on feet 5" off the surface.... I have created a wing.
Panels are attached with nothing but 1" vhb tape. Been through hurricanes, and no failure! I do however have stainless tethers to both panels just to limit my chances of killing another motorist in the event one of the monster (4x5') panels should come loose.
Old 01-13-2015, 07:20 AM   #61
2017 25' Flying Cloud
2014 23' FB Flying Cloud
2008 20' Safari
Chino Valley , Arizona
Iím confused. After reading post by Lewster and others on this forum I have been convinced that the 3M tape that AM Solar provides with their mounts is all that is needed to hold the solar panels to the roof. I just order a solar system from AM Solar and Iím excited to get started with the installation. Iíve asked the Techís at AM Solar lots of questions and they have been very helpful. One of the questions that I asked was about using just the 3M Tape for mounting the panels. The answer I got surprised me. I was told that some people use just the tape but at AM Solar they donít for liability reasons. If the people at AM Solar use screws or rivets along with the 3M tape for liability reasons they must believe that there is a possibility that the tape alone could give way. Now I donít know what I should do. Any thoughts? I hope Lewster could give some insight as to why AM Solar is not using just the tape.
AIRTRVL is offline   Reply With Quote
Old 01-13-2015, 08:42 AM   #62
2016 30' Classic
Erie , Colorado
Did they say they were using screw/rivets on an Airstream? Or was there a translation issue? If you asked if they just used tape and the answer was no then that is correct but doesn't mean screws/rivets. They cover the panel base with Dicor or Sikaflex to keep out water which can freeze.
I looked at a recent question I had with Lew and he said to use Sikaflex 221 and clean the surface and mounting plate with brake/carb cleaner on a rag before putting on the tape. I think the kit that comes from AMSolar has the VHB already mounted to the feet.
Gary
2015 Classic
ProPride
NōVPN
Old 01-13-2015, 08:54 AM   #63
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Just my experience, two sided tape is great stuff, but depending on temperature at application and a few days thereafter, and whether the surface is truly clean, it does not ALWAYS stick really well.
For liability reasons relating to DIY installers etc, the manufacturer is going to recommend tape plus screws or rivets.
Additionally, two sided tape is only as secure as the surface it is applied to. In other words, if it is stuck to a painted or otherwise coated roof, and the paint or coating is not stuck to the surface really well, the tape can fail while working perfectly.
I would think that factory paint would seldom if ever be a problem, other coatings and the applications of these coatings are going to be questionable.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 01-13-2015, 09:30 AM   #64
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Originally Posted by AIRTRVL View Post
I’m confused. After reading post by Lewster and others on this forum I have been convinced that the 3M tape that AM Solar provides with their mounts is all that is needed to hold the solar panels to the roof. I just order a solar system from AM Solar and I’m excited to get started with the installation. I’ve asked the Tech’s at AM Solar lots of questions and they have been very helpful. One of the questions that I asked was about using just the 3M Tape for mounting the panels. The answer I got surprised me. I was told that some people use just the tape but at AM Solar they don’t for liability reasons. If the people at AM Solar use screws or rivets along with the 3M tape for liability reasons they must believe that there is a possibility that the tape alone could give way. Now I don’t know what I should do. Any thoughts? I hope Lewster could give some insight as to why AM Solar is not using just the tape.
I got the same response when I called in my order to AM Solar. They suggested tape, screws, and Dicor which we ended up using. My local installer was also not happy with tape. That said, Lew probably has more experience than anyone in this field.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 01-13-2015, 10:13 AM   #65
2008 20' Safari
I called AM Solar back today and asked how they install the mounts to the AS. They clean the roof with alcohol install the mount with 3M tape and install #10 by 1” screws. Then they seal the edge of the 3M tape and screws with nonleveling Dicor.
Old 01-13-2015, 02:40 PM   #66
lewster's Avatar
Naples, FL , Hood River, OR
Here is the 'skinny' on how I mount the panels. The factory and I differ a bit, as they use Dicor self-leveling sealant in the feet. I prefer SikaFlex 221 as is is not only a sealant, but also a super adhesive/bonding agent.
In fact, if I didn't need the immediate bond from the VHB tape, I would use 100% SikaFlex.
I also do custom shaping and angling of the panel feet as required to obtain the largest contact area possible.
Airstream uses SikaFlex 221 to bond the crank-up antenna to the roof. The screws simply hold it in place while the SikaFlex bonds and cures.
I discovered this years ago when trying to remove an antenna base. It literally has to be cut off, as the adhesive power of the SikaFlex bond could NOT bd broken!
In summary, I depend on the SikaFlex bond to supplement the VHB tape and double or triple the bond strength of the VHB.
And BTW, my old Sprinter service van had 4 panels on the roof with no sealant..........just the VHB. None of the feet loosened after 7 years! When I recently removed the 5 panels from my '11 Sprinter to test the Flex panels, it took half a day to get the feet and VHB residue off the roof.
To reiterate, I have NEVER LOST A PANEL in 10 years of installing solar, and I have never used a screw on an Airstream roof!
YMMV! :-)
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 01-13-2015, 04:10 PM   #67
2007 22' International CCD
Lewster,
Didn't you mention that alcohol was not the right stuff to clean with before using the tape?
KE4GNK/AE
Old 01-13-2015, 04:30 PM   #68
lewster's Avatar
Originally Posted by rmkrum View Post
Lewster,
Alcohol is OK for cleaning the roof substrate for the VHB prep and Dicor, but is a very bad choice when using ANY polyurethane sealants like SikaFlex 221, as it inhibits the bonding strength and cure rate (this is direct from Sika tech support).
Any acetone based cleaner or pure acetone will not contaminate the roof substrate when using polyurethane sealants. Just be sure to wear nitrile or similar gloves when using acetone, as it absorbs very quickly into the skin and can cause long term liver and kidney damage.
Old 01-14-2015, 07:33 AM   #69
2008 20' Safari
Thanks for all the great information. It’s always best to ask the experts before taking on a project like this. I’m going to take Lewster’s advice and avoid drilling holes. Thanks again
Old 08-22-2017, 12:05 PM   #70
johnkellygreen
johnkellygre's Avatar
1985 25' Sovereign
Lansdowne , Pennsylvania
Originally Posted by lewster View Post
It certainly IS strong, but there IS a way to get the stuff off cleanly! PM me if you are in need of this proprietary information.
Hello Lewster, Regarding your proprietary method for VHB tape removal, I could really use some advice. I made custom aluminum brackets to fix my 2 160 watt panels to the roof of my 1985 Sovereign. They have been cooking in the sun since spring. Two of the bracket feet popped when I checked by pulling them up with a bit of pressure (25#'s.) I used VHB Adhesive Tape 5952 and installed them according to your recommendations (as far as I know.) Did I use the correct VHB tape? Could you send me the tape removal method you use? Thanks very much. I'm sure I did something wrong during the installation.
johnkellygre is offline   Reply With Quote
Getting 1 solar panel, should I just get 2 right away? JustSomeGuy Generators & Solar Power 24 01-28-2014 08:22 PM
blown away sawyerpoint Roof Vents, Skylights & Fans 3 04-28-2012 04:37 PM
I wasn't blown away! CalamonTin On The Road... 10 11-12-2011 08:03 PM
Blown away. njloco Roof Vents, Skylights & Fans 18 07-22-2011 06:38 PM
