Old 08-19-2008, 10:07 AM   #1
2010 27' FB International
austin , Texas
Solar Panel - 2006 Bambi?
I'm new to the Airstream family so excuse me if this info already exist. I have a 2006 19ft Bambi and would like to install a solar panel to the unit for recharging the batteries. Is there a particluar brand/system you would recommend?
boblomquist is offline   Reply With Quote
Old 08-19-2008, 12:05 PM   #2
wagnerda's Avatar
2006 19' Safari SE
Central Part , Maryland
factory solar panel
Hi,
I am sure others will tell you different/cheaper ways, but in my case I prefer to stick with the Airstream factory components so when I got solar added to my '06 19 footer I had Jackson Center put the factory panel on and connect it up. Note, I also replace the batteries with two new AGM batteries and presuming your batteries are the original it is probably about time for new ones also.
In addition to the solar panel on the roof they also installed the charging controller inside right above the battery/water system status panel, All in all a nice installation that I personally think helps maintain your Airstreams value better than the cheaper, after-market non-standard components (although I am also quite sure that some of those are probably better etc etc.)
regards, Dave W.
Dave&Shari Wagner
2006 Bambi SE,
2008 Ford F350 Diesel 4x4
AIR#23096
" I am lost and have gone Airstreaming to find myself, If I should return before I get back, please ask me to wait..."
wagnerda is offline   Reply With Quote
Old 09-01-2008, 01:40 PM   #3
I ahve a 2005 Bambi and am thinking about adding the factory solar panels. How much did it cost at Jackson Center?
hobiedog is offline   Reply With Quote
Solar Panel for 16' Bambi hdhegedus Generators & Solar Power 33 09-05-2016 11:25 AM
Solar panel installation jglase Generators & Solar Power 9 11-30-2006 09:47 PM
Solar Panel and Inverter Issues on 19ft Bambi campadk Generators & Solar Power 10 10-28-2006 09:59 AM
Solar Panel gilmorris Generators & Solar Power 14 12-05-2005 05:33 PM
Help on solar panel installation Les Gilliam Generators & Solar Power 3 11-27-2002 08:28 PM
