Old 08-14-2019, 06:34 AM   #1
Boise , Idaho
Solar options for 16' Sport.
Hello all,
I have a 2019 16' Sport that i'd like to get solar for. It only has one interstate battery, and I am really just looking for something big enough to keep that charged. I may add another interstate eventually, so maybe enough watts to charge two batteries while boondocking.
The trailer has the Zamp pre-wiring but those panels seem to be very expensive. Are there other panels I can buy that will be able to plug into that pre-wire system as easily?
Thank you!
James3344 is offline   Reply With Quote
Old 08-14-2019, 08:05 AM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
I believe what you have is the pre-wire to the battery as opposed to a pre-wire on the roof. The battery pre-wire is generic and pretty much any portable solar gizmo will plug into it. The controller is in the portable part, the "pre-wire" is just a couple wires, a connector, and a fuse.
All that said, there *is* a bit of nonsense about the polarity of the connector used. Some put the plus side here, others put the plus side there. As long as red goes to red, all is well. If it simply will not plug in that way, you will need to wire up an adapter (or re-wire one of the plugs).
Hopefully that makes sense .....
Old 08-14-2019, 04:21 PM   #3
Vantair
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Solar Option a portable ?
Being in a similar situation boondocking and / or not always able to be in charging sunlight (+ other airforum members suggestions for also “adding” portable) for now, decided on a 120watt folding portable by Aims PV120 Case (Amazon). This tops off our 2)220ah 6volt Fullriver AGMs In @ 4 hours.
Sweet little unit !
Surprisingly ultra compact & light, 5 panel flexible fold out more like a big notebook. Slips in side storage hatch. You must add a small charge controller but for $250.00 all in, get a 120w (5.5+ charging amps in full sun) orienting solar option until figuring on roof top version.
Most alum framed portables in this arena go from $500.00 to $750.00 and far bulkier and heavier although more substantial.
ID:	349415   Click image for larger version
Vantair is offline   Reply With Quote
Old 08-15-2019, 06:49 AM   #4
Half a Rivet Short
Hi
Ok, some math:
A single group 24 battery is likely to be in the 80 AH range. Your typical "stop using" point wold be half of that or 40 AH.
A small single panel is doing pretty well putting out 5 to 6 A. If it does that max output for the equivalent of 5 hours a day you get to 25 to 30 AH in a day. Roughly speaking, it will take more than a day of reasonable sun to get your battery back up to "full". That assumes you aren't pulling anything off the battery. Yes, there's some guesses there, but they are pretty close to what you should normally see.
The "typical" ( = who knows what you have ...) fridge pulls about 1A into the 12V control board. It's going to do that 24 hours a day so that's 24AH. One would *guess* that if you are using the trailer, you are using the fridge . The fridge will pull about what the panel will put out on a good day.
Indeed, if you are going to be out and about "off grid" for more than a day or two, you need more than a single group 24 battery (or you don't use the fridge ....). You also probably need more than a single small solar panel.
Old 08-15-2019, 07:06 AM   #5
skitger's Avatar
2018 16' Sport
Corvallis , Oregon
Bob and the others are correct. I have a 2018 16 Sport and I added a second battery, since just starting out, I added a second Interstate and got and identical battery box from Walmart.com. I had to cut one handle off to fit, a couple of battery cables and you are good. I also got a Renolgy portable suitcase and controller, Bob right about the plug, Zamps switches the hot side on the SAE plug, but red to red from controller to plug. I also added a BVM, Victron 712 to actually see my aH. We use 15-20 a day and and the suitcase adds some back, with we can go 4 days easy being thrifty. By then water is getting low too in the 16 Sport. Have Fun!
Rick & Paula LaMont
2018 Sport 16’
WBCCI #7944
skitger is offline   Reply With Quote
Old 08-15-2019, 07:27 AM   #6
Native143's Avatar
2013 20' Flying Cloud
2014 16' Sport
Dunedin , Florida
What is the size when it in in the case?
"All good things are wild and free."Henry David Thoreau
WBCCI #12814
Florida Unit #027, Suncoast Unit #129, Region 3
Save
Native143 is offline   Reply With Quote
Old 08-15-2019, 07:29 AM   #7
Boise , Idaho
Thank you for the information! I'm a huge beginner when it comes to electrical things so I'm not quite sure what you mean by Zamp switching the hot side on the SAE plug. I was looking at the Renolgy panels as well but not sure how they would connect to the battery. Can you tell me which controller you got? And did you just connect it directly to the battery?
Old 08-15-2019, 10:57 AM   #8
skitger's Avatar
2018 16' Sport
Corvallis , Oregon
This is the Renogy suitcase I have:
https://www.amazon.com/Renogy-Monocr...n%2C195&sr=1-4
But your will need to change from the MC4 connector on the panel to SAE, I used this:
I just connected it at the controller, but here is where the ZAMP plug thing comes in. The Zamp socket on the trailer is switch from the normal SAE setup. Normal SAE is the exposed metal part of the plug is positive, but on ZAMP's the metal plug end is neg, so back to Bob's statement, pos to pos ( + to +), which means you switch the pig-tail wire, so that the + (pos) side coming from the controller runs down the SAE pigtail such that the covered end of the plug is the positive side (+), this will then go into the positive side of the ZAMP socket on the trailer. Just make sure +/pos is connected to +/pos on controller and socket (you can trace the socket to the pos side of the battery to to confirm.
Also, the pig-tail is only 5 feet, I have made a longer one (extension) so I can move the panel around if needed.
I hope this helps,
Any help here explaining this is welcome, also google the zamp plug issues and you will see others dealing with it
Rick & Paula LaMont
2018 Sport 16’
WBCCI #7944
Old 08-15-2019, 06:04 PM   #9
farafield's Avatar
2018 16' Sport
Charlotte , Vermont
I also have an ‘18 16 and would like to do something similar as I mostly boondock. Not handy but learning. Wondering how you installed the Victron, where the shunt went in. Thank you.
Don't let the sound of your own wheels drive you crazy...
Kim
Charlotte, VT
2010 F-150, 5.4l, V8, 3.55; Bramble: 2018 Bambi Sport 16
farafield is offline   Reply With Quote
Old 08-15-2019, 06:19 PM   #10
Boise , Idaho
I hope this helps,
Ok great thank you, it's all starting to make sense now. So if I purchased the panels that you linked. And purchased these two converters, it should work as a "plug and play"?
https://www.amazon.com/gp/product/B0...c=1&pldnSite=1
https://www.amazon.com/Renogy-MC4-SA...XTME36DYS8VGT2
Old 08-15-2019, 06:54 PM   #11
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Two Seasons ago, our first set-up...120w Zamp, charging thru the 7pin.
ID:	349515   Click image for larger version
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
AC replacement-options, options... Belegedhel Furnaces, Heaters, Fireplaces & Air Conditioning 5 09-12-2018 08:56 AM
can three of these ZS90 Solar solar panel fit atop a 22fb sport waninae39 2005 and newer - Bambi all models 1 06-27-2018 07:58 PM
Outside the Box Solar Battery Options perryg114 Generators & Solar Power 0 08-13-2014 06:41 AM
Solar Options bellepente Boondocking 34 08-07-2012 08:27 AM
Solar options for my parked Airstream ? CarolBarrel Full-Timing, Winter Living & Workamping 5 01-25-2011 09:17 AM
