Old 09-02-2016, 11:53 AM   #15
Stay CazuaL
cazual6's Avatar
2014 19' Flying Cloud
Reseda , California
Depends on your application.
I use mine to top off batteries with a 100w panel when in storage.
I considered removable but I am too lazy to keep lugging it around. I always have my gens anyways.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 09-04-2016, 10:51 AM   #16
Llittle54's Avatar
2016 16' Sport
Port Angeles , Washington
Still trying to think it all through. Leaving for the Canadian Rookies this week so it will have to wait. I have just installed a TM 2030 and SC 2030 in anticipation. I hooked up a portable 80w with its own controller through the trailer and the TM 2030 so now I can watch as the electricity travels.
Right now I am leaning towards a roof mount system. Everything is in place (monitor and controller) and I have identified the factory installed solar wiring. The TM 2030 is working great and I know the portable works. Now I just have to decide if I have the guts to rip off the TV (television) antenna and start putting holes in the AS. (One idea was to cut the post on the mushroom antenna low enough for the panel to sit over and cap it off. Comments?)
Lew I'll probably purchase the AM panels and mounts. I've read most everything posted here. With the 2030's and the pre installed wires any additional points of wisdom??? THAANKS
Llittle54 is online now   Reply With Quote
Old 09-04-2016, 01:43 PM   #17
2007 22' International CCD
A nickel says Lew will tell you not to bother with the pre-installed wiring. It's too small.
KE4GNK/AE
Old 09-04-2016, 02:40 PM   #18
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Little 54, I used the same TM2030 with SC2030 hooked up to an Anderson plug at the battery box so I could plug in the 22ft umbilical to a connection on my truck where I had 3 Renogy flexible 100w panels mounted. All was we until 2 of the 3 panels went south. Renogy fully reimbursed me for the panels and shipping.
gandttimes is offline   Reply With Quote
Old 09-04-2016, 02:42 PM   #19
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
And I meant to say before my fat fingers got in the way, I will do it again when I can find the right panels. But this time I will leave air space and mount them on some sort of tilt arrangement.
Old 09-04-2016, 02:48 PM   #20
lewster's Avatar
Naples, FL , Hood River, OR
Make it a quarter and you have a deal!!! 😁
Lew Farber
Old 09-04-2016, 02:56 PM   #21
Solar on TV?
Meh. In my opinion the factory installed pre wire is only worth s nickel. 😀
KE4GNK/AE
Old 09-04-2016, 04:25 PM   #22
lewster's Avatar
OK then........ No deal for you!!!!!
Lew Farber
Supplement Factory Solar with Portable Solar dkottum Generators & Solar Power 10 06-16-2016 04:28 PM
Best Quality Solar Panels & Solar Controllers to use | Opinions Wanted BoldAdventure Generators & Solar Power 54 03-17-2016 07:04 AM
Airstream solar pre-wiring compatibility with AM solar robi Electrical - Systems, Generators, Batteries & Solar 6 06-11-2014 10:31 PM
Solar Install AM Solar outdoors717 Generators & Solar Power 3 07-15-2012 08:11 PM
