Old 10-22-2017, 10:17 AM   #1
2007 27' International CCD FB
San Diego , California
Solar monitor CAT5 prewire?
Now that the major parts of my solar is up and running. Working on the remote monitor. Anyone use the cat5 prewire from the buss area? It says the other end can be found below the tank monitor.
Anyone have tips or hints here? Do I just pull the tank monitor and I should see it in the wall?
pteck is offline   Reply With Quote
Old 10-22-2017, 10:34 AM   #2
2015 30' Classic
Pleasanton , California
I've repurposed the CAT5 cable with the Blue Sky IPN Pro remote. The CAT5 cable includes 4 twisted pairs. I used one twisted pair for the shunt connection, and two of the twisted pairs to create a 4-pin RJ-11 connection for data. I left one of the pairs unused.
Yes, just pull the monitor and fish around with your hand.
I carefully cut a rectangle in the aluminum with a Dremel, I've read that other folks use a Multitool. That was my biggest fear in the entire installation!
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 10-22-2017, 08:12 PM   #3
Thank you. That's exactly the info I need.
I took the face off the tank monitor and there is the cat5 cable ready for my solar remote panel. Both ends of the cat5 are un-terminated. Dug around my electronics tool kit and had the right terminals and crimper. Made quick work fo it all.
There's also a handy phone cable marked and ready for an inverter.
Old 10-25-2017, 06:20 PM   #4
Pic of my completed solar monitor install. The cat5 prewire sure is handy.
3" holesaw to cut the interior skin to fit the MT-50 monitor.
Next project will be an inverter.
Old 10-25-2017, 07:24 PM   #5
2015 30' Classic
Nicely done. That space below is screaming for a battery monitor!
Al, K6IV
Old 10-25-2017, 08:29 PM   #6
It sure is!
Where is the CAT5 Data Cable for the Solar Controller Remote CarolynSteve 2016 - Current Flying Cloud 4 09-09-2022 10:40 AM
CAT5 for Blue Sky IPNPro Remote? mikebee Electrical - Systems, Generators, Batteries & Solar 1 12-01-2014 07:23 AM
Weatherproof CAT5 connector box perryg114 Computers, Internet & Satellite 10 06-07-2014 04:47 AM
solar/use prewire? billiards Generators & Solar Power 4 07-30-2008 01:54 PM
Solar Prewire, What Does It Mean? dottie dawglips Generators & Solar Power 6 08-06-2003 07:30 PM
