Old 04-25-2011, 08:01 PM   #1
DaCosta's Avatar
2007 22' International CCD
fLUSHING , New York
Solar is not charging my batteries. Help!
Hello everyone please I need so advice. I own a 22" international It has a solar package I cannot get the solar panels to charge my battery.
DaCosta is offline   Reply With Quote
Old 04-25-2011, 09:36 PM   #2
1975 29' Ambassador
Reno , Nevada
Trace it out.
There should be a wire from the solar panel to the charge controller and voltage on that line should be 18v or better in full sun. There should be a wire from the charge controller to the battery and that should read 13 to 14 volts or so without the battery connected. With the battery connected, you should be able to get some current going from the charge controller to the battery.
Motorhomes, and Charging Batteries.... Keyair General Motorhome Topics 18 10-15-2011 08:21 AM
Controller wiring to bus bar or batteries? txstreamer Generators & Solar Power 4 04-26-2011 06:10 AM
Solar Power Quandary for my '58 mello mike Generators & Solar Power 7 04-06-2011 08:05 PM
Only one battery charging heslinhotel Batteries, Univolts, Converters & Inverters 11 02-21-2011 08:49 PM
looking for info on solar battery charging Globie64 Generators & Solar Power 11 02-21-2011 11:03 AM
