Old 12-14-2015, 02:17 PM   #1
2012 27' FB International
Solar inverter question
My wife and I are considering a campground host position at Maroon Bells in Colorado for the summer. For electric, they have solar only and say that I will need to purchase an inverter to connect to the trailer. I am not familiar with solar or inverters. Is this an expensive piece of equipment? Where can I purchase one? What is involved? Will I only be able to run DC using the inverter or can I run the 110 outlets and equipment as well?
flyingfishy is offline   Reply With Quote
Old 12-14-2015, 02:44 PM   #2
2015 30' Classic
Pleasanton , California
An inverter converts DC to AC. In the case of a solar panel installation, an inverter is used to convert the DC voltage of the batteries (typically 12 V, but not always) to 120 V, 60 Hz AC.
To be comfortable in your AS and use all of your resources, I would consider purchasing an inverter that will create enough power to run your AS. So that means you'll need at least a 3300 W inverter (110 V * 30 A). You can find relatively inexpensive converters from Home Depot, such as Power Bright 12-Volt DC to AC 3500-Watt Power Inverter-PW3500-12 - The Home Depot. For $315 your getting something that will probably suffice for the summer. There are different types of inverter technology with pure-sine being the most favored for permanent installations and where folks are concerned about electrical noise. This inexpensive inverter does not produce a pure sinewave, but it's close enough for most tasks.
The other consideration is that this inverter assumes the batteries that you are connecting to are 12 V, so you'll need to confirm this with the campground. If their batteries are running at 24, 36, or 48 V then the inverter you will need will be probably be more expensive.
These inverters are also not designed to be exposed outdoors, so you'll need to make sure the inverter is placed in safe environment (protected from rain). You'll also need an adapter to connect your 30 A AS cable to connect to this inverter as well.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 12-14-2015, 05:38 PM   #3
Alano,
Thanks for the info-exactly what I was looking for
Mark
Old 12-15-2015, 08:56 AM   #4
2016 30' Classic
Erie , Colorado
Flying you may need more than an inverter. You may want to ask them for some type of diagram of the system that you are going to hook into. Are you going to be hooking a set of panels directly? A system that has panels and batteries for storage where you would hook to the batteries? Distance from both to your trailer? If it is panels only what are you going to do for storage as when the sun goes down without batteries you won't have any power. If they have batteries how much capacity. Hopefully they have all of this information available. Post it here and those who use solar can help you sort it out.
Great spot to be a campground host by the way.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 12-15-2015, 09:04 AM   #5
Caroyl's Avatar
1964 26' Overlander
Warner Robins , Georgia
We just visited Maroon Bells this summer while visiting our daughter in the Denver area. They are gorgeous! Hope this works out for you. Post lots of pictures. 😃
Caroyl & Tim
1964 Overlander "Gracie"
WBCCI # 31088
2009 F-150 "Big Red"
Caroyl is offline   Reply With Quote
My 27FB Solar/Inverter Project Documentary kscherzi Electrical - Systems, Generators, Batteries & Solar 20 10-11-2015 10:06 AM
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Solar/Battery/Inverter plan cmreumund Batteries, Univolts, Converters & Inverters 10 02-06-2009 08:54 PM
Solar Panel and Inverter Issues on 19ft Bambi campadk Generators & Solar Power 10 10-28-2006 09:59 AM
