Old 06-08-2014, 02:09 PM   #1
2014 30' Flying Cloud
Dandridge , Tennessee
Solar installation Puzzler
I will try this again, the first time I received little help. I have a 30foot 2014 Flying Cloud that works perfect.
I have installed an 18 Watt solar panel and its working fine.
I am in the process hooking up a controller to maintain correct voltage's .
When I hook up the controller I get the following.
With the coach batteries hooked up. The controller charge light goes out when I hook it up to the batteries. If I disconnect the Batteries from the chassis and hook up the controller it works as it should. The charge light comes on and the batteries charge.
If I unhook the only the Negative battery terminal from the chassis the controller works as it should. If I unhook only the Positive battery terminal the controller does not indicate charge.
The best answer I have so far is False Polarity and have no idea what that is.
Seems to me if I have a ground issue it would have shown up before this.
dmotwell is offline   Reply With Quote
Old 06-08-2014, 02:16 PM   #2
Refugee from Napa, CA
Photobum's Avatar
2015 25' FB Flying Cloud
Madison , South Dakota
Check in with Lewster....he should be able to guide you.
Photobum is offline   Reply With Quote
Old 06-08-2014, 02:26 PM   #3
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
I would suggest you call the company that you bought the controller from.
George
gandttimes is offline   Reply With Quote
Old 06-08-2014, 02:39 PM   #4
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
I'm guessing your on-board city power/charger system is trickling power to the batts and interfering with your solar controller.
Jeepers! is offline   Reply With Quote
Old 06-08-2014, 04:14 PM   #5
Would this be true even if I'm not plugged in to power
Old 06-08-2014, 10:22 PM   #6
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
Sounds like a circuit is being made, no? I'm no expert, just guessing.
It could always be worse.
Old 06-09-2014, 01:43 PM   #7
I removed the two 30 amp fuses from the main 12 volt circuit, hooked up the controller, and replaced the fuses, and the controller charge lamp came on.!!!!!
It is working, but i still do not understand what is going on. Must be a sticking something???
I'll report any conclusion that resolves the issue.
Thanks for the input.
Dave
Vent lift installation & Astrodome installation jessejane Roof Vents, Skylights & Fans 4 01-10-2014 04:34 PM
Solar Panel Installation 69Overlander Generators & Solar Power 28 03-03-2013 08:18 PM
Puzzler - what the heck is this? airfoil Off Topic Forum 6 07-04-2009 10:05 PM
Help on solar panel installation Les Gilliam Generators & Solar Power 3 11-27-2002 08:28 PM
Solar Installation cactushead 2001 Safari 19 10-21-2002 05:56 PM
