Old 12-06-2010, 01:59 PM   #29
1986 25' Sovereign
Plant City , Florida
Is there a reason to run 8 awg? The person that installed mine with 3 panels used 10 awg service cord from the panels to the charge controller and then 10 awg THHN from the controller to the batteries. The controller is a xantrex c35 however i have been considering upgrading to the XW MPPT 60 Amp Solar Charge Controller with control panel. Do you think there would be any advantage to this?
Chris
ck21084 is offline   Reply With Quote
Old 12-06-2010, 03:09 PM   #30
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Chris
Hi Chris,
You'll have less loss by going with 8 awg vice 10 awg, but it really depends on the length of your wire run. What are you solar panels rated at in watts?
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 12-06-2010, 03:23 PM   #31
1986 25' Sovereign
My panels are around 100 watts each. The run from the panels to the controller is 15ft and another 15ft to the batteries.
Old 12-11-2010, 03:56 PM   #32
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I did some more testing today in the full sun of the afternoon. The charge controller (top pic) varies the voltage based upon the needed load. When I was running a fan and my radio the charging voltage read 14.4 volts. After turning these items off, the charging voltage dropped to 13.5 volts (bottom pic). I have the say the system works great, I'll never need to plug my trailer in again to recharge the batteries.
ID:	116852   Click image for larger version
1958 Overlander
4CU 1st VP
Old 12-12-2010, 09:25 AM   #33
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Very nice thread. Bookmarked.
I was able to bend the aluminum by using my vice.
My vices have bent any number of things . . and my bench vise, too.
Old 12-13-2010, 09:34 PM   #34
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Got it..
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 12-15-2010, 02:11 PM   #35
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I have been considering upgrading to the XW MPPT 60 Amp Solar Charge Controller with control panel. Do you think there would be any advantage to this? Thanks,
Chris
Chris,
I think a MPPT upgrade would be beneficial for you. I, personally, don't have any experience with them, but I hear they're as good as adding another solar panel on the roof. But I also hear they're expensive. If you want more efficiency and have limited roof space, going this route might be the right thing for you.
Mike
1958 Overlander
4CU 1st VP
Old 12-15-2010, 04:21 PM   #36
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
If you want an MPPT controller I have used the Rogue 3024 for a year and it works great . It costs 295.00
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 12-15-2010, 05:40 PM   #37
elfirebob's Avatar
2007 25' International CCD FB
1970 23' Safari
1956 16' Bubble
Jamul , California
Images: 159
Keeping the juice up.
Looks like a great install Mike. Thanks for posting the process. I too plan on comming down the refer vent. Panels forward of the AC aft of the first front vent.
Anthony's controller seems like the ticket for this as well. Looking forward to seeing these units, I have so much other work still to do on our Safari... Panels well be a summer project in 2011, lord willin" .
Stream Safe,
Bob U-
San Diego, CA.
The " TinDen "
2007 25' International FB
1970 Safari 23' Land Yacht
1956 Bubble 16' California Whale Tail
Charter Member 4 Corners Unit
(View all of elfirebob's images)
elfirebob is offline   Reply With Quote
Old 12-15-2010, 07:25 PM   #38
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Anthony, is this the unit you showed me in your '69? Does it display voltage and amps? What other features does it have?
1958 Overlander
4CU 1st VP
Old 12-15-2010, 07:27 PM   #39
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Thanks, Bob. Are you coming to the New Years Rally? I can show you my install if you attend.
1958 Overlander
4CU 1st VP
Old 12-15-2010, 07:37 PM   #40
Ottawa , ON
I understand what they are talking about with this unit except for "power point tracking".
What does this mean, please?
Old 12-15-2010, 08:01 PM   #41
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Wikipedia has your answer.
TX-16
Dave Park is offline   Reply With Quote
Old 12-15-2010, 08:09 PM   #42
Ottawa , ON
Originally Posted by Dave Park View Post
Well, what a clever device! Thanks.
sovereign
Solar Panel Installation 69Overlander Generators & Solar Power 28 03-03-2013 08:18 PM
AM Solar installation on a Safari hshovic Generators & Solar Power 12 04-09-2011 10:27 PM
Solar panel installation jglase Generators & Solar Power 9 11-30-2006 09:47 PM
Help on solar panel installation Les Gilliam Generators & Solar Power 3 11-27-2002 08:28 PM
Solar Installation cactushead 2001 Safari 19 10-21-2002 05:56 PM
