Old 09-05-2015, 11:11 PM   #29
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
Blue - No splicing. Picked up a set of MC4 connectors with 4ft of #10 wire connected. Pic doesn't show it very well...but the connectors fit right into the cable inlet (just below the curved portion) and the wires feed through water tight nuts. And the 4ft of cable will be plenty to attach to my controller, which is up front and very close to the batteries.
Originally Posted by Gsmblue View Post
Arktos- that looks great! Did you have to deal with splicing wires? If so how?
arktos55343 is offline   Reply With Quote
Old 09-06-2015, 02:18 PM   #30
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Gotcha! Thanks!
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 09-06-2015, 06:10 PM   #31
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
I just ran the # 6 cable from the charge controller out the front to an Andersen connector. Click image for larger version
Name:	ImageUploadedByAirstream Forums1441584311.675849.jpg
This connects to the other half of the connector on 30 ft of # 6 welding cable with the male half of a Pollack connector.
This goes to the female half which is attached to my truck. Click image for larger version
Name:	ImageUploadedByAirstream Forums1441584510.218810.jpg
Where I happen to have my panels mounted on the truck cap.
It could just as easily go to a portable setup in reverse order.
George
gandttimes is offline   Reply With Quote
12V Receptacle henw Batteries, Univolts, Converters & Inverters 16 11-29-2017 09:02 AM
Electrical Help - Splitting a receptacle COArgosy78 Electrical - Systems, Generators, Batteries & Solar 4 07-03-2005 03:57 PM
Antenna/TV receptacle Al1 All Argosy Trailers 11 07-06-2004 12:20 PM
Electrical receptacle in storage compartment Kistler Our Community 4 06-27-2003 07:18 PM
receptacle replacement 1960 overlander rod Electrical - Systems, Generators, Batteries & Solar 3 10-31-2002 07:19 AM
