Old 10-03-2011, 07:50 AM   #1
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Solar controllers - how smart are they?
I'm working on upgrading the converter in the trailer, but I'm wondering about whether I need to worry about the solar controller too.
We have three Siemens 70 or 75 watt panels mounted on the roof of the camper. Due to their age, they're probably 60-65 watts now. There is a solar charge controller mounted under the arm of the couch. I'll have to take a closer look at it tonight to get the make and model number for it.
I'm replacing the converter because I don't want it overcharging the new AGM batteries. Do I need to worry about the solar charger too? Or have they always been multi-stage?
I'm guessing the controller is approximately 15 years old, installed when the trailer was new, and I remember reading that it checks once a minute to see what mode it should be in (there are LEDs on it indicating what it's doing).
Thanks in advance!
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 10-03-2011, 09:51 AM   #2
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
I would change the controller to an MPPT controller. They are more expensive but there are some that are not that high in cost. Maybe the Morningstar SunSaver 15 Amp MPPT Solar Charge Controller From the Arizona Wind And Sun Website "The AGM battery has an extremely low internal electrical resistance. This, combined with faster acid migration, allows the Concorde AGM batteries to deliver and absorb higher rates of amperage than any other sealed batteries during discharging and charging. In addition, AGM technology batteries can be charged at normal flooded lead-acid regulated charging voltages, therefore, it is not necessary to recalibrate charging systems or purchase special chargers. Concorde AGM batteries can be bulk charged at high rates without damage - up to 10 times as fast as most gelled cells, and 4 times as fast as flooded batteries."
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 10-03-2011, 10:07 AM   #3
1974 Argosy 20
Kooskia , Idaho
Solar charge controller technology has changed a lot in the past 10 years. I would consider a new charge controller. I personally like the Xantrex C35 or C40 series. They are relatively inexpensive and always do the job.
Old 10-03-2011, 10:20 AM   #4
1975 29' Ambassador
Reno , Nevada
Only very recently have solar charge controllers been getting any reasonable smarts from what I can tell. Your old one is likely just a voltage driven gate. PWM and MPPT technologies have been around a while but small systems really haven't put much real need for multiple stage battery charging.
While the AGM internal resistance and high current features sound really nifty, when it comes to most RV uses, it is irrelevant. The only time most RVers get into a high current mode is when running a microwave off an inverter or something equivalent.
RV solar systems just don't have the oomph to produce much charge current because there is only so much area on an RV to collect the sun.
The key issue from what I see is storage maintenance. It is only recently I have seen any solar charge controllers feature consideration for sulfation inhibition and float charge tempering (to avoid plate corrosion and electrolyte loss). (it intrigues me that this issue, while a major failure cause for RV batteries, is also not a big item in converters, either)
It is also just recently that I am seeing MPPT charge controllers that will handle higher input voltages, such as putting your three panels in series. That leverages the MPPT idea for slightly improved system efficiencies.
The Morningstar linked is an example of the newer ones out there but its 200 watt rating is rather marginal for your 3 panels. Note that NAWS doesn't say anything about storage maintenance issues for this controller.
Old 10-03-2011, 01:05 PM   #5
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Thanks for the replies so far. If I can summarize them (and please correct me if I misunderstood):
1. You do not expect the solar system to cause a problem with overcharging the batteries, simply because it really doesn't produce that much current in the first place.
2. However, a new controller might not be a bad investment anyway. It looks like the new ones demand a temperature sensor that I'm pretty sure mine doesn't have, giving weight to the theory that mine is just a voltage sensing model.
On the AGM batteries: my main purpose for going AGM is that I don't have to worry about them as much. I quickly destroyed one wet-cell deep cycle that I bought new by not keeping up with it, and I never checked the level in the deep cycle battery in the trailer we bought in June until yesterday (don't ask what the level was...). I just know it's not something I'm going to do regularly, so I want the maintenance free-aspect of AGMs.
But I don't want the solar system to kill them on me, either.
Old 10-04-2011, 10:14 AM   #6
1975 29' Ambassador
Reno , Nevada
re: "my main purpose for going AGM is that I don't have to worry about them as much. I quickly destroyed one wet-cell deep cycle that I bought new by not keeping up with it"
An AGM will not solve a neglect problem. If anything, AGM and other sealed batteries are more sensitive to charging abuse than wet cells.
That is why it is important to use equipment that features storage maintenance as well as charging smarts. Storage maintenance means doing something to inhibit sulfation and techniques to maintain a full charge without gassing or plate corrosion.
With the right equipment, even wet cells don't need much attention. Plug in the RV when home, check water levels every 6-12 months just to make sure and that should be about it.
Old 10-04-2011, 11:52 AM   #7
1969 25' Tradewind
1983 34' Limited
Images: 85
Rogue Power Technologies - Affordable, Renewable, Accessible Energy The Rogue which I have on the Tradewind does have an equilization mode and also has a temp probe included. This is the second gereration of controller. I have a zantrez c40 and a morning star 15 mppt controller . I prefer the Rogue.
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
Old 10-04-2011, 12:41 PM   #8
Skater's Avatar
1995 30' Excella
Bowie , Maryland
No kidding. Hence why I started this thread.
Help my solar controller caught on fire bmklawt Generators & Solar Power 28 03-24-2016 11:02 AM
Airstream solar pre-wiring compatibility with AM solar robi Electrical - Systems, Generators, Batteries & Solar 6 06-11-2014 09:31 PM
Solar Battery Charger Prewire t7389sg Classic Motorhomes 0 08-18-2011 08:01 AM
Solar Power for Battery Maintenance Tumajin Generators & Solar Power 10 08-12-2011 06:10 AM
How much solar do I really need sgoetz Generators & Solar Power 12 05-19-2011 08:28 AM
