Old 12-12-2012, 09:41 AM   #1
clicker187's Avatar
2013 25' FB Flying Cloud
San Gabriel , California
Solar Controllers...
Can I use two different solar controllers to charge the two batteries in my rig? The controller on the roof is a 30 amp controller. I have an installed solar panel on my roof and I want to add a portable panel that already has it's own controller. Will this cause any problem?
Thanks, John T
clicker187 is offline   Reply With Quote
Old 12-12-2012, 09:50 AM   #2
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I hope not...I basically have a similar situation with a 3 stage converter and a 3 stage solar controller... I will be interested to see what the responses are.
I guess I was thinking the two controllers would basically come into synchronization before long - after all, they're both sensing the battery voltage and would come to similar conclusions about the battery states.
Skater is offline   Reply With Quote
Old 02-28-2013, 11:59 PM   #3
alumascoupe's Avatar
1966 26' Overlander
Frozen , Tundra
Make sure your charge controllers voltage sensors are attached at the same location to get the most accurate voltage reading possible, this way one controller isn't constantly sensing a different voltage than the other controller therefore being forced to work harder.
alumascoupe is offline   Reply With Quote
Old 03-01-2013, 06:30 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
As long as each system contains a blocking diode to keep power from one from feeding back to the other, you should be okay. Fortunately most solar charge controllers already contain a blocking diode to prevent current from other charging sources (such as shore power) from flowing the wrong way through the panel and controller.
