Old 02-19-2012, 01:14 PM   #1
2012 30' Classic
Bigfork , Montana
Solar Controller
It is bright and sunny here in California’s Borrego Springs, and this morning, all of a sudden the two aftermarket inverters in our Airstream stopped working.
We charge our system with four large solar panels producing an equivalent of about 600 watts going into our system. We control the flow of energy to our batters and subsequently to our inverters using a Zamp Solar Charge Controller. Once when the Controller showed a spike to 16 volts I wrote the manufacturer and the representative said it was a surface charge and not to worry, because simultaneously the Controller showed a charge of but 0.2 solar amps/hour.
Today, when the inverters stopped working I again thought high voltage and sure enough, it was reading 16-plus. We turned everything off and about an hour later again tried the inverters, and all was well.
Could my problems with the inverters have resulted from a spike in volts to the inverters?
Can someone tell me what’s going on and if we need to worry?
Thank you.
Bert
Bert Gildart is offline   Reply With Quote
Old 02-19-2012, 01:42 PM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
Absolutely - inverters can have over and under voltage protection.
Humph... fully charged batteries should be "floated" at something like 14.2 V (14.7V at most). 16 volts will cause your batteries to use lots of water, and may damage connected electronics.
Does your controller use a temperature sensor to control voltage levels?
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 02-19-2012, 03:51 PM   #3
1975 29' Ambassador
Reno , Nevada
re: "showed a charge of but 0.2 solar amps/hour" -- amps is a rate so this is like saying you traveled at 55 mph per hour.
16 volts isn't a 'surface charge' - a surface charge doesn't go higher than the applied charging voltage and that should not go above about 14.4 volts on your RV system. Bart is on it there.
Check the solar charge controller to see if it has a battery voltage setting. It needs to be at 14.4 for bulk and 13.2 for float (see the battery manufacturer recommendations).
Good question about the temperature sensor, too.
Old 07-23-2015, 04:52 PM   #4
flyingcloud's Avatar
2012 27' Flying Cloud
somewhere , on the road
Images: 8
Hey Bert - For the past few days the same thing has been happening to us. How did you resolve your issue? Did you have to replace your charge controller?
Our blog: Aluminarium
Find & Share Great Campsites: Campendium
flyingcloud is offline   Reply With Quote
Old 07-23-2015, 07:24 PM   #5
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I think Zamp uses Go Power for a charge controller. Does anyone have better recommendations? Not saying that there is any thing wrong with the Go Power but just curious if anyone suggests another brand.
TinCan
graysailor is offline   Reply With Quote
Old 07-28-2015, 03:17 PM   #6
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Solar Boost from Bluesky - you get what you pay for.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
27FB Solar Installation Report Start to Finish z8 hm Generators & Solar Power 52 05-06-2014 10:45 PM
Solar Power Quest Mr & Mrs S Boondocking 58 03-02-2012 02:03 PM
Connecting Brake Controller MKT playared Brakes & Brake Controllers 1 02-19-2012 05:54 PM
Solar panel display blinking HootMon-Frau Generators & Solar Power 0 02-18-2012 10:26 AM
Brake controller on a F-150 King Ranch Lfemat Tow Vehicles 5 02-17-2012 09:08 PM
