Old 09-16-2014, 09:41 AM   #29
interstateflyer's Avatar
2017 25' International
Los Osos , California
As crazy as it may seem, you may have to remove your radio when not using, when not plugged in to AC. It's a one button operation vs a confusing and unpredictable menu setup.
The Pioneer in my 2014 re-programs itself every time there is any kind of service interruption. It consumes 2 amps+- just sitting there and flashing it's light show.
Also, if you leave your tow vehicle cord hooked to the A/S you may get a 2+- amp draw back into the TV.
And....turn off the antenna booster.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is online now   Reply With Quote
Old 09-16-2014, 10:07 AM   #30
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Most tow vehicles have a battery isolator in the wiring to prevent what you said about leaving the TV connected. Is there something different about this particular unit?
Larry C
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 09-16-2014, 10:25 AM   #31
Larry C
I was surprised that the solar control panel showed that draw when the TV was attached. It's a 2013 RAM with a full tow package.....you'd think that there would be an isolator. Had the same issue with a 2002 Tahoe. I always unplug when parked over night.
Old 09-16-2014, 10:52 AM   #32
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
John's 2012 is the same as mine and nothing is connected when in Store except the propane detector and the tongue jack. I guess the inverter is wired directly to the battery so if he left that on, it would be a draw for about 1 amp, even with nothing connected to it.
Larry
lsbrodsky is offline   Reply With Quote
Old 09-16-2014, 11:00 AM   #33
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Wouldn't you know it. While checking my Battery Disconnect red light to answer urnmor's question I see that my Battery Disconnect is malfunctioning. Damn the bad luck.
With no external power the red light stays on and I am able to use all 12v equipment in either "USE" (correct) or "STORE" (not correct). When switching between "USE" and "STORE" I hear the relay clicking loudly as usual, so that's a head scratcher. It had worked properly for three years since new.
urnmor, I suspect the discovery is that your system works properly and mine does not.
So your turn, help me out. Larry, what do you think?
Doug and Cheryl
Old 09-16-2014, 11:29 AM   #34
urnmor's Avatar
Berlin , Maryland
Doug
I have greatly appreciated all of your assistance and am sorry to hear that you are now having problems with your system. As to the red light. When you switch does the red light go out? I found that I had to hold it for a second or two then let it go for it to turn off. It does not go out right away.
urnmor is offline   Reply With Quote
Old 09-16-2014, 11:38 AM   #35
dkottum's Avatar
Thanks John, you might have a good idea there. I usually do hold the switch for a moment to ensure the relay engaged, I'll try that again. I suppose if I hear a single click that would be correct, a double click would mean the relay is moving over and not holding. I'll see.
Doug and Cheryl
Old 09-16-2014, 11:42 AM   #36
lsbrodsky's Avatar
Doug,
My first try with a relay, always, is to try a horizontal slam adjust. Beat on it sharply. I have seen some posts on the forum reporting failures of the relay. I am assuming you have enough voltage to energize the relay.
Larry
Old 09-16-2014, 11:48 AM   #37
dkottum's Avatar
Thanks Larry. Yeah I know about beating on relays from my many years as aircraft electrician. If they work when you beat on them you need a new one. Everything wears out sooner or later.
The voltage is good, 12.7vdc.
Doug and Cheryl
Old 09-16-2014, 12:16 PM   #38
dkottum's Avatar
Yep, hold the switch momentarily and the relay worked as it should. Not reason to replace yet but I'll keep an eye on it.
Thanks guys.
Doug and Cheryl
Old 09-16-2014, 12:29 PM   #39
lsbrodsky's Avatar
good deal!
Larry
Old 09-16-2014, 01:10 PM   #40
urnmor's Avatar
Berlin , Maryland
Great now all we need to do is get the AS hooked up and head on out.
John
Old 09-16-2014, 07:18 PM   #41
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Heading out sounds like a great plan.
Meanwhile, if you replace your trailer's stock Parallax 7355 converter with a Progressive Dynamics 4655, you can stop worrying about turning the battery to "Store" when plugged into AC power. The PD converter is a smart 3 stage unit that will not damage your batteries, unlike the stock PLax unit. That PLax unit has two strikes against it. First, as has been noted, it can boil your batteries. Second, it's a very slow-charging unit. The PD unit charges faster and is much safer for your batteries.
As for why AS installs a crappy PLax converter vs. the PD unit, it's most likely all about the Benjamins. Nobody makes a purchase decision based on a converter, and the PLax unit probably saves them money...
Anyway, I made this upgrade and now I only turn the switch to "Store" if I'm trying to eliminate potential drains on the battery when the TT isn't plugged into AC power.
Rocinante is our 2014 International Signature 27FB
Old 09-16-2014, 11:12 PM   #42
dkottum's Avatar
As for changing converter/chargers, I probably will when the factory one wears out. For now, using the solar charging and the battery disconnect in "STORE" when on external power we are getting along.
The reason is simply cost, the idea of replacing something that works to get a minor improvement in function bothers me, not good economics and perhaps wasteful.
Doug and Cheryl
Confusion on "weatherstripping" vs. "gasket" pinkflamingoes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 03-20-2005 02:55 PM
12 volt confusion?? COArgosy78 Electrical - Systems, Generators, Batteries & Solar 7 09-21-2004 03:51 PM
Replacing Univolt and 12V confusion sander17 Batteries, Univolts, Converters & Inverters 8 06-29-2004 09:09 AM
Wheel confusion Sneakinup Wheels, Hubs & Bearings 11 02-15-2004 09:22 PM
Confusion-1957 bubble parts smallfry General Interior Topics 5 11-21-2002 05:09 AM
